09-13-2012, 08:19 PM
#14506 | |
Oddometer: 308
Which part did you break, the center hub or the basket? |
09-13-2012, 08:24 PM
#14507 | |
Oddometer: 609
09-13-2012, 08:46 PM
#14508 | |
Oddometer: 1,382
Yup, just a diffused plate of glass, like most HID car wannabe's. The light isn't DOT and is designed to scatter in all directions. All offroad lights are so you can see branches, etc. The good thing is when I ride at night it's normally on trails or backroads.
Tour of Idaho T1 Challenge - On Dual Sported XR650R's: Coming Summer 2013 Eat. Sleep. Ride - The Great Divide: http://advrider.com/forums/showthrea...4#post19193704 Go, Get Lost - Heading South: http://advrider.com/forums/showthread.php?t=735690 Dirt Donkeys Do Baja: http://advrider.com/forums/showthread.php?t=671095 |
09-13-2012, 09:38 PM
#14509 |
AKA DoctorXRR
Oddometer: 645
Clutch Hub
Its the center hub.......argggg.....
09-13-2012, 10:44 PM
#14510 |
Oddometer: 1,025
Clutch Holding Tool
Can't help you with he hub but I can help you with making a tool for real cheap.
If you have two worn out friction and one steel plate you can make your own tool. Install the three plates, steel in the middle, and clamp them together with vise grips. Remove from the basket and drill three holes, 120 deg apart, through all three plates. Bolt or rivet the three plates together. Now you can lock the inner hub to the outer basket. To break the clutch boss nut loose just wedge a piece of aluminum or copper between the primary drive and driven gear and loosen, or tighten, the nut. |
09-14-2012, 03:56 AM
#14511 |
Exhiled
Oddometer: 187
09-14-2012, 05:17 AM
#14512 |
AKA DoctorXRR
Oddometer: 645
XRR Clutch Hub
Thanks very much for the tips, I will give them a call to see if its in stock!
09-14-2012, 05:44 AM
#14513 |
Exhiled
Oddometer: 187
09-14-2012, 07:17 AM
#14514 |
Oddometer: 207
09-14-2012, 07:33 AM
#14515 |
I've got bike ADD
Oddometer: 1,064
Yesterday's Project
My XR came with a large rear rack with side racks and Cortech saddle bags, too big for my purpose (single track, FS roads and Jenning GP) so I was in the hunt for a small rack I could strap a bag too and carry a few tools, pump, my wallet, phone, ect., maybe a spare tube and patch kit. I have an OGIO tool bag that holds alot around my waste, but wanted to transfer some to the bike.
inmate gmanski from Germany had this thread http://advrider.com/forums/showthread.php?t=760423 and he graciously sent me his CAD drawings. I wanted to build something similar using scrap I had lying around and wanted to keep this project out of the mill shop (i.e., use low tech simple shop tools, band saw, small brake, Tig, grinders, drill press, files and dremels that I have in my shop, or you could find pretty easy). I drew out gmanski's plans to scale, traced them onto a piece of cardboard and then cut my metal (16ga stainless) with the brake and band saw. Then I realized with my aftermarket seat, I was going to have to modify it a little to fit,and then I decided to just punch the holes out with the Pirana and forget milling the nice oblong slots. Because of that I forgot about mounting the flat plate to the fender / subframe and had to make a little bracket which actually raised the rack up flush with the seat which I ended up liking. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I swirled it up with Scotchbrite on a die grider, but I think I'll go back and use some 300 on a DA and give it more of a "satin" look. My tig skill sucks so I ground the outside welds down and re-tacked it on the inside edges. It seems very sturdy, it's very light and should work just I need it to. My XR does have a rear fender support that was part of the luggage rack, so my new rack bolts right into that. |
09-14-2012, 09:41 AM
#14516 |
Exhiled
Oddometer: 187
Very nice fab work.
09-14-2012, 11:10 AM
#14517 |
Oddometer: 52
Just got my Acerbis 6.3 gallon tank the other day. Dang! that thing is big!!
Will try to get it installed tomorrow. Should be a big improvement over the 3.8 I am currently running. Also first day of 106 mile round trip commute. Ride to work was pretty easy. I need to get my Vapor installed so I can see what my speed is in the dark. May try to install that this weekend also. I also ordered a Seat Concepts cover. Can't wait till that thing shows up!! The stock isn't too bad for 50 miles but the SC should be much better. My daily commuter is a full dresser with cruise control and stereo but this will be my Friday runner. Thats all for now |
09-14-2012, 11:55 AM
#14518 | |
Broken Filter
Oddometer: 505
Yeah, it's crazy how people fill this thread up with useless non-technical garbage posts. Way to lead by example Garthe.
"Get the hell out of my way." - John Galt '78 KE100 - '09 K1300S - '09 CRF450X Tagged- '00 XR650R Tagged - '80s XR600/XL600 Project - Giant Trance X3 - PC: SSD-4.2ghzOC - Old mildly stinky hockey gear
09-14-2012, 12:25 PM
#14519 |
we build, we fight
Oddometer: 1,738
calling an illegal alien an "undocumented immigrant" is like calling a drug dealer an "unlicensed pharmacist" "If guns cause crime, then all of mine are defective." Ted Nugent |
09-14-2012, 01:51 PM
#14520 | |
The Cake Baker
Oddometer: 149
![]() ![]() Hope this helps, Chuck |
