Closed Thread
Old 09-14-2012, 10:16 PM   #3106
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Hey there Roger. The techlusion product is a different animal. I appreciate your jumping in. But when you have a go at technical answers, maybe you could clear them with me first? Marketing does.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline
Old 09-15-2012, 03:04 AM   #3107
roger 04 rt
roger 04 rt's Avatar
Oddometer: 2,363
Hey there Jim, Enjoyed your recent photos of the manufacturing process.
BTW, I called tech support and got voicemail, tried marketing and got switched to the front desk--who told me to try later, they were at a three martini lunch. The front desk said something about -30C and I pictured a trail of black smoke and decided just to reply--my bad.
Speaking of the marketing process, there's a great sense of anticipation around iice cool and iice smooth. What's the latest? RB
roger 04 rt screwed with this post 09-15-2012 at 03:21 AM
roger 04 rt is offline
Old 09-15-2012, 06:55 AM   #3108
MSteven
Oddometer: 83
Hey Roger, I have removed the Techlusion unit, and am going to run the IICE Air and the Cool when they become available.
The Techlusion worked pretty well, but it seemed like it needed more tweeking.
So, does the Cat sensor need to be plugged in or disconnected while running the Air?
MSteven is offline
Old 09-15-2012, 07:29 AM   #3109
roger 04 rt
Oddometer: 2,363
Let me check with Poolside's marketing department and get back to you ...
Old 09-15-2012, 08:57 AM   #3110
Ayrshire Bull
why the hell not?
Ayrshire Bull's Avatar
Oddometer: 2,629
"It's not what you look at that matters, it's what you see." - HDT
Ayrshire Bull is offline
Old 09-15-2012, 11:12 AM   #3111
John P
Oddometer: 2
Order
Hi I'm new to the forum but I got here doing research on a fix for my R1100R. I sent you a PayPal for an IICE. Can you tell me where I'm at in the order queue?
John
John P is offline
Old 09-15-2012, 03:11 PM   #3112
MTFYR
MTFYR's Avatar
Oddometer: 66
http://www.advrider.com/forums/showt...9#post18697959 Order list
The only thing necessary for the triumph of evil is that good men do nothing!!!
MTFYR is offline
Old 09-15-2012, 03:21 PM   #3113
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
So, does the [O2 sensor] need to be plugged in or disconnected while running the Air?
No particular reason, you can leave it plugged in or not.
The purpose of the ECU on a fuel injected motor is to control exhaust emissions. In that regard it is sub-optimal from a performance standpoint.
Unplugging the O2 sensor does not transform the ECU into an optimal device. If the O2 sensor is disconnected the ECU does not become optimal, it becomes a different example of sub-optimal.
Poolside is offline
Old 09-16-2012, 04:52 PM   #3114
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,391
Did the install last night and took the rig over to Griffith Park for the Sidecar Rally. I did mention that my 2007 R1200GSA had a sidecar attached didn't I? Anyway, I noticed a much smoother throttle response after the install. It was in the mid to upper 90's today.
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline
Old 09-23-2012, 04:48 PM   #3115
Thunderbird
Oddometer: 59
Hey, I've been meaning to post for a while on this. I've got several hundred miles down now with this gizmo plugged into my bike. I like it. Parking lot speeds are definitely smoother, and throttle response is much improved at highway cruising speeds. Nicely done! Well worth the $$. Thank you.
Thunderbird is offline
Old 10-02-2012, 04:49 AM   #3116
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Hey, I'm back! I was dark there for a couple of weeks due to a PC failure.
Poolside is offline
Old 10-02-2012, 04:56 AM   #3117
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Thanks for the reports fellas!
Poolside is offline
Old 10-03-2012, 05:28 PM   #3118
skybo1
Oddometer: 91
Question
I have a 2002 1150GS with:
valves/rockers adjusted and TB synched
Autolite APP 3923
y-pipe and O2 sensor
stock exhaust
steptoe mod
and soon to receive IICE Air!
It seems to be running very well.
What can I expect from my IICE Air?
Have I accomplished the basics for as smooth running as I can get?
Thanks to All
skybo1 is offline
Old 10-09-2012, 01:52 PM   #3119
jadoca
Oddometer: 91
Any chance the Icee will plug into th new LC GS and what is the ETA of the other 2 products? Thanks.
Your post was FULL of errant VB code which I deleted.
JJ
johnjen screwed with this post 10-09-2012 at 03:26 PM
jadoca is offline
Old 10-09-2012, 02:09 PM   #3120
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,954
whoa... what's going on, man?
Splitting lanes, and splitting hairs.
Andrew is offline
Closed Thread
Times are GMT -7.   It's 04:52 PM.
