Old 09-17-2012, 01:22 PM   #16
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,823
Pablo83 is offline   Reply With Quote
Old 09-18-2012, 04:11 AM   #17
radianrider
Adventurer wanna'be
radianrider's Avatar
Oddometer: 505
Some serious metal working skills, Pablo. Nice work.
radianrider is offline   Reply With Quote
Old 09-18-2012, 06:00 AM   #18
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,823
thanks
Old 09-18-2012, 06:01 AM   #19
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,823
I got a bunch of pipe bends from Summit Racing (I think that's where they came from).
And I already happened to have the perfect mufflers laying around.
Now I just need to do a bunch of fitting and welding
Old 09-18-2012, 01:22 PM   #20
ivantheterrible
Oddometer: 605
i love the tank. What did you use to cut it, and did you have to take precautions against an explosion from old gas fumes and sparks? I have an old tank i want to cut up (and put back together).
ivantheterrible is offline   Reply With Quote
Old 09-18-2012, 02:22 PM   #21
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,823
I used a thin disk on a 4-1/2" angle grinder to cut it.
I had to make sure ALL the fuel and vapors were out before welding it; it was a bit of a process. First I emptied all the fuel and sprayed compressed air through it. Then I let the tank sit in the sunlight for an hour or in the shop overnight to evaporate most of the leftovers. There was usually still about half a teaspoon of fuel left in it at this point so I would shake it up good and hold a long nose lighter to the cap and wait for it to go WHOOOOSH. I would repeat the shaking and lighting until it would no longer light. It was usually ready for welding at this point, but I still needed to make sure the tank cap opening was not pointed at me when I started welding. Fun stuff.
Pablo83 screwed with this post 09-18-2012 at 08:42 PM
Old 09-18-2012, 07:23 PM   #22
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,595
Nice exhaust work.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 09-19-2012, 01:59 PM   #23
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,844
With your skills and a 750 chain drive Shadow , I'd bet you could make a reasonable facsimile of the RS750. The intakes would be tough.
bk brkr baker is online now   Reply With Quote
Old 09-19-2012, 08:02 PM   #24
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,823
Old 09-20-2012, 06:47 AM   #25
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,688
Someone once told me to connect a long hose from a car exhaust to the gas tank you want to cut/weld, and run it for a while. Apparently, all the exhaust fumes burn any remaining fuel and vapors without explosion because of the high CO2 content in the exhaust fumes. I'll be giving it a try on my next project.
henrymartin is offline   Reply With Quote
Old 09-20-2012, 07:32 AM   #26
ivantheterrible
Oddometer: 605
Thanks for replying to my question, Pablo83.
i'd heard the same thing about the exhaust gas trick. It's so hard to know which way to go, with so much at stake.
Old 09-20-2012, 11:09 AM   #27
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,823
Seat Pan
Old 09-21-2012, 05:33 PM   #28
Quickv4
Pro Turd Polisher
Quickv4's Avatar
Location: Dickinson, Nort' Dakohtah- Orig. from Wiscowsin
Oddometer: 550
MADD fab work man! Keep it coming. Looks like the ol girl is developing some nice curves! 2nd on the exhaust!!!! Nice!
Jerry
____________________________
Great forum and Resource for 1st and 2nd gen Honda V4s SabMagIntercept
www.v4hondabbs.com
Quickv4 is offline   Reply With Quote
Old 09-22-2012, 10:25 PM   #29
riderjohn
Tag Sniper
riderjohn's Avatar
Oddometer: 1,632
Saw your bike at Cruise Above the Clouds.I really liked it.
2008 Yamaha FJR1300
2005 Suzuki GSX 750F Katana
riderjohn is offline   Reply With Quote
Old 09-23-2012, 07:14 AM   #30
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,823
Thanks. My bike was pretty different than anything else out there. I met Dave Doubleday of D&S Motorcycles there. He had the Kawi 750cc 2 stroke triple (the only other bike in the show). We're going to try and get more motorcycle entries for next year and he'll sponsor a prize for the class.
Times are GMT -7.   It's 08:16 PM.
