Old 09-21-2012, 12:20 AM   #1
assquatch20 OP
Hoss Cat
assquatch20's Avatar
Oddometer: 1,102
1972 r75/5
Answers/advice appreciated for the statements in bold text. The rest is details to help us both.
So a few months back a buddy sat on my little Honda and liked it. His folks were giving him a /5 one of them had bought, but the little dude didn't like the weight and style of the thing, so I'm selling him mine and bringing his home, while making a little profit to dump back into the thing. 52,000 miles.
So I guess I should get started with a proper thread on it so I know how to approach the thing and feel like it's roadworthy. I took a look at it the other day, and it now has a battery. Sidecover tabs are there, but no covers. Passenger pegs, as someone (east_high) pointed out to me before, have been moved but it looks like a clean job. From what I can tell, it has Wixom luggage and the Avonaire (thanks pfestus1) fairing. My fairing knowledge isn't enough to be sure if it's from the /2 or the multipiece kit for the /5. (It's the 2-piece specifically for /5's)
I couldn't get it to start, but I don't know the intricacies of the process. It would chug a time or two, but no idle. Had gas, left fuel tap on (or at reserve) and seemed to do worse if I put the choke on. I still won't have it home for a few weeks and probably won't hit the roads much until next year, but I'd like a head start. The carbs are not the flat tops, but I'm not sure which they are (can ya tell I'm new to white people bikes?). As well, the tank is definitely gonna need a POR15 run, but I can't see any external rust or pinholes, etc. Carb and petcock rebuilds look easy enough. I did notice the right side petcock would rub and was unable to turn all the way up. I'm thinking there's an internal spacer in there? And where should I go for a complete jet set?
In fact, it looks clean from maybe 5 feet off. Up close you notice how chrome isn't one of those things that stays pretty, so there's a lot of cleaning work to do. Not sure if it has the factory tool kit, but I'm hoping so. Where could a guy buy a /5 tool kit as an all-in-one bundle? Doesn't have to be OEM or NOS or other acronyms.
The needles on the clocks look pretty rough, and the lights inside as well, but seem to be operable. I've seen where folks rebuild them, but too rich for my blood right now. What I'm worried about is undoing the lighting reroute for the fairing. The signals were taken off the stems and mounted outboard, same deal with the headlight of course, so I'm hoping it's not hard to undo. If the front lighting is a total mess, which harness(es) would I be needing to fix that?
The Wixoms will probably get a resto at some point, but they're in pretty good shape. Latches and hinges look totally usable. My understanding is I can still find a key that fits those, correct?
I got lucky and saw an ad for a local guy that's a certified airhead mech. which is pretty rare here, but more opinions could help. My base question is, as a newbie to BMW (and a novice in general), what are the first and most important things to do when you get the bike home? What procedures would you go through? What would you have to buy with most certainty?
And also, would anybody be interested in the Batmobile fairing?
Some things shouldn't be left like you found them.
assquatch20 screwed with this post 10-10-2012 at 11:09 PM
assquatch20 is offline   Reply With Quote
Old 09-21-2012, 12:34 AM   #2
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 764
Out of curiosity, which honda did you trade? That's how I got into my r90, too.
Kt-88 is offline   Reply With Quote
Old 09-21-2012, 12:51 AM   #3
assquatch20 OP
Hoss Cat
Oddometer: 1,102
It's a CB-1. I made a deal that I'll get visitation rights.
Old 09-21-2012, 05:02 AM   #4
Kt-88
I like everything.
Kt-88's Avatar
Oddometer: 764
A cb1000?
Old 09-21-2012, 08:48 AM   #5
assquatch20 OP
Hoss Cat
Oddometer: 1,102
A cb1000?
Oh no, a CB-1. Kind of a rare naked 400 brought over here in '89 and '90.
Old 09-21-2012, 09:13 AM   #6
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,359
Good. You more than doubled your CCs.
Welcome to the asylum.
The earliest petcocks are not too easy to rebuild, they are the ones called Everbest. They can be worth a few $s because working ones are getting scarce. But it looks like a Karcoma petcock in the pic, can't be sure, too far away. The Karcomas are rebuildable if they only need rubber parts. Some of the other tiny pieces inside the petcock are NLA. We sometimes can come up with used parts.
A complete tool kit is going to cost some serious money and if you want the correct original tool kit the price will keep going up. There are tool kits, used, listed as "original" be careful. There are specific items that belong in the "original" tool kit.
How many miles on bike? Is there any ignition modification or addition? What else non-stock is on the bike?
Start with just changing all the fluids and tune up items. Set the valves. Replace worn or cracked rubber pieces. You will find plenty to do.
---Albert Einstein
Old 09-21-2012, 09:39 AM   #7
assquatch20 OP
Hoss Cat
Oddometer: 1,102
I just want the tools I need to use. Doesn't have to period correct or anything, but I'd like to know where I could get some of the specialty stuff on a decent price and throw it under the seat.
52k miles AFAIK. Not sure on the ignition, but there's two gigantic horns mounted by the downtubes and what looks like a big solenoid valve for each. Probably not good on the charging system, but I'm no expert. Being no expert, I can't say with certainty if there are other mods, but that's all I noticed. Oh, the tank badges look to be the adhesive type or something, as I didn't see screw holes. Is that right for a '72?
Old 09-21-2012, 10:38 AM   #8
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,359
You would do well to contact Hucky's and see what he can get you a complete kit for. Find Hucky's on the Web but call him to place orders. He will explain to you. Get as much stuff as he has in stock that you can afford right now. Get the Clymer's or the Haynes manual now. If you can't afford the complete new tool kit then tell us do you own metric tools?
If Hucky's only sells the BMW shop manual don't get that one. It is too much money for something not very useful for a beginner.
http://www.bmwhucky.com/
Look for "tool" on Ebay. You may find what you need. Hopefully, but I just did that and did not see a reasonable /5 tool kit in the lot.
The problem is that it is an on going evolving thing. The "tool kit" under the seat is only a start. You are going to need a lot of other tools as time goes by.
The German tools made for the bike are good tools. It would cost just as much to make the tool kit up at the Sears store.
There are several ordinary wrenches needed but there are also a couple of special wrenches you should have. These are hard to find if Hucky's doesn't have them. Recently we have sent riders there to get the specialty wrenches.
I think there is a picture of the tools in the manual. Please get a manual right away so we know what we are talking about.
---Albert Einstein
Old 09-21-2012, 01:19 PM   #9
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,359
Supposing that you have some of this stuff already we will try to make a list of everything that belongs in the basic /5 tool kit. Remember there are other tools you will need but this is the on board tool kit. To begin;
5 Hex Key wrenches also called Inner Hex wrenches. You need 3 mm, 4 mm, 5 mm, 6 mm and 8 mm. Ordinary good quality hex wrenches will work fine. But not cheapo ones, they will round off.
Several special tools are needed in the on board tool kit. 71 11 1 237 857 is the ring spanner that fits the swing arm nuts on one end, 27 mm, and the other end fits the center nut and other parts of the front forks, it is 36 mm.
Another special wrench you will need is the hook spanner with pins for the top covers of the fork tubes. It is # 71 11 1 237 858
There is a third special spanner for /5s but I don't have one so I don't know the #.
You need a socket for the spark plugs. The tubular one in the stock kit is a good one. It has a Tommy bar that can also be use to remove stubborn axles. The spark plug socket is #71 11 1 237 856 the Tommy bar is #71 11 2 301 357
There is a special feeler gauge that is still available and belongs in the on board tool kit. It is shorter and makes it much easier to do some of the operations needed. It covers all the sizes needed for the setting of valve lash, ignition point gap, spark plug gap and a setting needed on the brake master cylinder (used only rarely when replacing, rebuilding the MC) It is part # 71 11 9 090 154
You need a test light, a continuity light. They are a common tool for tracing wiring problems. There is a German one made by Stahwillie and is a nice one but a common test light will work fine.
It is recommended to carry a couple of short tire irons. I one several and a long one too. And if using tube tires, which you will be using, a tube patching kit. There is an on board tire pump that has a special place to store on the bike.
There will be more, to be continued.
---Albert Einstein
Old 09-21-2012, 05:07 PM   #10
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,359
These are the two special tools I mentioned above. Might not need these right away but they are part of the original tool kit and you are better off having them already when you need them than having to wait to get them.
Look at Duane Ausherman's Web site he has a good article on the tool kits;
http://cmtk3.webring.org/l/rd?ring=b...duane%2Fbmw%2F
---Albert Einstein
Old 09-21-2012, 10:36 PM   #11
assquatch20 OP
Hoss Cat
Oddometer: 1,102
Much appreciated, disston. That's the stuff I'm looking for, the bike-specific tools that make the job easier. There's still a chance the kit is on there, I didn't check. I might go have another look at it next week or wait until I bring it home.
I was considering getting the OEM, Clymer, and the Haynes as it seems they're always missing something, but it looks like those prices are ridiculous and I'm not that helpless. By good luck I've never had to tear into a gearbox but I'm not opposed to it. I've done plenty of engine maintenance and top end work though, so I don't think anything will blow my mind. Would you still say the BMW manual is too complicated or should I have it? Is the owner's manual necessary as well?
Mostly I'm worried about getting into something I desperately need to fix and then not having the tools or parts to complete the job. Obviously I don't know what "jobs" I'll end up having to do, but the feeler gauges and special spanners look like a good start. I suppose a syncing gauge would be handy to have around as well, considering the fuel system work I'm looking at?
My weak point is definitely electrical stuff, so still a little nervous about undoing the fairing wiring and/or throwing new wiring in there. Any advice in that arena is greatly appreciated.
Hopefully somebody can read this thread in a few months and see a nice little transformation.
Old 09-21-2012, 11:14 PM   #12
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,359
If you want more than one manual get the Haynes and the Clymer. The OEM is not too complicated, it's just not really needed with the other two and the internet. The OEM does have more torque values an explanations about what pistons and which cylinders are made, 30 years ago. I'm not against people getting this, I have one myself. but you can get the OEM manual next year or the year after. And they do show up on Ebay and at Flea markets. October Fest is almost here.
The owners manual is nice for a lot of basic info. I have one somewhere. There may be one on the bike. These are often with the bike.
Good, you may have a tool kit. I did learn tonight a bit about posting pictures tho.
There is a simple method to sync the carbs that doesn't use an expensive tool. You may want to get one of the expensive tools but you don't need it now. I'll describe how to make the shorting tool and explain a little about it's use, but later I'm about to turn in, big day tomorrow.
We do a lot of transmission stuff on these bikes. And then after all the bother and sweat and money, more tools, we end up with something that shifts like a John Deere. There will be transmission work in your future or you will send it out, the option that really is best for most riders. But if you are one of those that are driven, or think you can handle it or want the experience then we can help a little. The one thing you don't want to tell yourself is that you want to rebuild a transmission to save yourself money. Not very likely that anybody ever saves any money doing the first two or three transmissions. And the guys that have done a few hundred of them, there are a few, they know stuff we can't learn, they will do a better job than any part timer. Just the way it is. But some of us just want to do our own, that's me, and we are allowed.
When's the bike get to you? Does it run? Any known problems? Mileage?
BTW, I've been meaning to tell you. I think you might have something of a rarity in that fairing. Would like to see more pictures of that set up.
---Albert Einstein
Old 09-21-2012, 11:29 PM   #13
assquatch20 OP
Hoss Cat
Oddometer: 1,102
I'll be bringing the bike home in a little over 2 weeks. My buddy will get back from AIT and want to get on with the trade I suppose. I couldn't get it to run myself, but I'm told it does. The owner wasn't there when I looked to help me out. Seems like just a clogged jet or old gas. No known problems aside from the fuel stuff. I'll definitely need POR15 for the tank. Mileage is 52,000 miles.
It does certainly seem like the fairing is hard to come by, but I don't know if that means anyone will want the thing. I kinda like it and I've read it was the best of the best for its purpose, but I'm not so sure it'll stay with me.
Also now that I think about it, my buddy slapped together one of the yardstick synchronisers, so I suppose that might work for me. I'm used to 4 cylinders so much that it never occurred to me.
Old 09-22-2012, 08:57 AM   #14
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,359
There are a number of little things about Airhead ownership and repair that are sometimes hard to explain even if I know the answer. You have a number of good qualities that make helping you out so much easier. It's amazing the number of times riders with no prior mechanical experience come to these forums for advice and help but they need to have their hands held because they won't buy a manual. The inexperienced beginner mechanic thinks that real mechanics don't use manuals. Little do they know that we read them from cover to cover in our spare time and revel at the quality of a really good manual. They are the back bone of what a lot of us do. So I just wanted to say again you're on the right track
After the Clymers and Haynes manuals there is another that will prove very useful. It is the Bing Carburettors Manual. Mine was published in 2001 and I understand there is a latter edition with some up dates. I think this is the next after the ones already mentioned. Find the Bing Web page and get the phone #. I think you have to call them to order anything. But here's the caveat, do not make a big order of a lot of parts from Bing. You will get their price list with the new manual (BTW it's pretty cheap at only 10 or 11 dollars I think.) And from there it is easy to compare with the prices from other sources. Not to start the discussion all over again but the fact is Bing parts are cheaper at the dealers than from Bing. But get the book.
Here is a link to one of the places that have after market tools for BMW. You may use them. There are others. They will sell you the adapters for the shorting the plugs method of balancing the carbs. You can also make your own, I'll give directions if needed later.
http://www.northwoodsairheads.com/Tools.html
(not sure why the pic didn't work)
---Albert Einstein
disston screwed with this post 09-22-2012 at 09:16 AM
Old 09-28-2012, 04:18 PM   #15
assquatch20 OP
Hoss Cat
Oddometer: 1,102
Went and had another look today. Guy said it was a '73, showed me the title, but I can't remember. If it is, it must be an early one. The tank badges aren't screwed on, which I think indicates a difference between 1972-73 and I don't think it's a LWB. Also noticed the dual airhorns run off some Sears brand compressor and are scary loud. I might have to hang onto those.
Anyhow he got it running and it idles nicely once it's warm. Still needs a serious cleaning for the entire fuel system, but it ran. Looked like a tiny pinhole in that link pipe/connector thing between the headers, and an exposed hole on the motor beside the dipstick. What is that? Absolutely can't be good to have that open, oil change asap.
I couldn't get the seat to lift, all the way, seemed like the luggage was in the way and the whole seat felt kinda loose. The trim around it needs replaced but the cover looks dandy. From what I could see, though, no tools/pan. In that case, what maintenance tools do I need? I know gauges and the exhaust nut spanners, but what else is necessary to lube the splines and change fluids, etc? Doesn't look like I'll be needing into the tranny/crankcase so that stuff can wait, I hope.
assquatch20 screwed with this post 11-14-2012 at 05:43 AM
Times are GMT -7.   It's 10:41 AM.
