09-25-2012, 07:39 PM
#61 |
What if its a Samsquamch?
Oddometer: 7,717
Question-
Isn't the oil tank venerable in this pic? Or is the tank high enough to avoid taking a rock hit? I noticed that this skidplate goes about the same height as the Big Dog plate -
LC8World.com - KLRWorld.com Forums - Nighthawk Forums "Life's an adventure, and I refuse to live a boring one." |
09-25-2012, 07:55 PM
#62 | |
Nothing to see here.
The tank itself is pretty robust, the problem is that its mounted to the radiator so when you the bash plate hard enough it starts to collapse the rad.... Not that you couldn't damage the oil tank but it is pretty stout. |
09-26-2012, 04:23 AM
#63 |
AKA; Mongo-E
Oddometer: 1,756
In the $325 range Canadian.
No link yet, as he can't produce very many and he doesn't want to be overwhelmed with orders. Mike is going to produce about 12 plates next week, so we will see... He has tested this design on his own SE and it will work with a center stand and again, the plate does not depend on the oil tank to support anything. He told me you can run the plate without the 2 oil tank screws just fine. These plates are 3/16" tig weled alum. and powder coated in a silver vein finish. If you take a hit to the front hard enough to bend the plate at the oil tank, wheww.... it might leave a mark, but will buff right out!! ![]() I am new to the SE, I rode my 990 to over 30k though. And only broke one motor case! I do have some insight to one or 2 of our local SE "guru's" Take care everyone, Eric. This is what the Black dog did to my Adventure, ![]() And this what the plate looked like, ![]() Edit, I souldn't say the plate did this, I did this, and the plate suffered the wrath. The ribs where very high on the inside of the plate, and when I cased the G-out, the rubber grommets flexed enough to slam the plate into the bottom of my motor, cracking it. Luckly, we where able to weld it thru the clutch side and it never leaked again!!
"If my Technique Improves, so will my riding"! BIG-E screwed with this post 09-26-2012 at 05:52 AM |
09-26-2012, 08:27 AM
#64 |
Oddometer: 7
09-26-2012, 12:52 PM
#65 |
Rookie
Oddometer: 265
The last picture in this post http://advrider.com/forums/showpost....postcount=2143 shows how I fixed the issue on the SE. My rad started to bend, but I just mounted two thicker / strong steel bars on each side going from the BD bashplate to the free mounting threads (for crash bars?) higher up on the sides. Held up very well for two years and no more issues.
09-26-2012, 12:54 PM
#66 | |
Allergic to Asphalt!
Oddometer: 5,979
Here is the issue w/ the BD vs the G-IT:
09-26-2012, 05:54 PM
#67 |
Oddometer: 15
Hey Guys, boy oh boy, do i wish i bought my SE when it first came out? However i picked mine up as one of the last ones available. Iv'e had it for two Seasons now, and built, and tested a few Trinkets for it, including my Version of a Skid Plate.
I am surprised at the interest, and demand for product for the Bike still, so yes, i am building a run of Plates. I have been Machining, and Fabricating Motorcycle parts for years, that include everything from one-off Aluminum Subrames, to Stainless Steel Clipons, rearsets, fuel tanks, swapping front forks around, yada, yada. I am working on getting a Website done, so people can find me, and i will be producing a few different Off-Road, and Adventure parts (mostly KTM) for now. You can get in touch with me here, or my business email... info@mvmotoventure.ca I have had some difficulty posting Pics on ADV, so thanks to BIG-E for doing a little PR work for me! My Machining skills outweigh my Computer abilities by a Factor of 10... This is good, No? Cheers!!! |
09-26-2012, 08:52 PM
#68 |
Oddometer: 2,617
So then the force is transfered to a bolt through the engine? Sounds perfect remount the kickstand to prevent a cracked engine then mount the skidplate to it. Lol.
Thank you MX1WEST, Lindsay Machine, Smart Performance, SPS for the Support 257x Solo Baja 1000 If I had not some strength of will I would make a first class drunkard--Shackleton Moving??? Two Man Movers |
09-26-2012, 09:55 PM
#69 |
Oddometer: 902
A little misleading. Not the same troublesome mounting point.
The highway's a storyteller...No time to write it down. |
09-26-2012, 10:13 PM
#70 |
Oddometer: 7,717
That's interesting, as the BD plate that I installed on my ADV a few months ago had shims in case there was any room between the rubber bumper & the bottom of the engine case. Mine fit snugly and did not require the shims.
09-27-2012, 04:43 AM
#71 | |
AKA; Mongo-E
Oddometer: 1,756
Thanks TT!! I can't wait to get my plate!
"If my Technique Improves, so will my riding"! |
09-27-2012, 05:13 AM
#72 | |
Aaron S
Oddometer: 6,100
Once reading this thread I jumped at the chance to buy the very last G-iT plate for the SE, if it hand not landed yesterday I would be in line for one of these. Feel free to make one extra... you know... just in case! |
09-27-2012, 07:00 AM
#73 |
Aaron S
Oddometer: 6,100
More pics from BIG-E:
09-27-2012, 07:03 AM
#74 | |
Oddometer: 5,979
The ADV skid plate bolts to a cast aluminum subframe in the front.
09-27-2012, 07:37 AM
#75 |
Oddometer: 2,185
If Lakemonster is so anal he puts tie wire on his oil screen bolts the details on the plate are probably well sorted.
![]() I think I'll keep a few hundred bucks in my pocket and modify my Blackdog a bit, should be a few holes to drill and a simple bracket to bend up, maybe BDCW can build others and upgrade kit?
07 SE PG007 "Up there where you eat moose-cock you must all be rockets scientists." |
