09-30-2012, 04:27 PM
#1 |
Screwed the Pooch
Oddometer: 512
Far from finished, but on the road!
Today was a good day. After seven months of daily work (and a few years of wanting), I rode my Airhead project bike. Here are some pics so you don't get bored reading my drivel:
![]() ![]() ![]() ![]() ![]() Started out as an R90/6, that I rode pretty stock for a few years then decided I wanted to make a single-shock go anywhere bike. There is still a lot to do . . .. It doesn't have a stand yet, notice it's leaning against a fence post? I extended my centerstand, but it's a little too long and when I started to cut and re-weld it, my welder started acting up, so it's on hold. Still need to finish the windshield, handguards, the exhaust is too "streety", etc., and there's a fair amount of tidying up to do, but it works for now and I can fix and add from here. Man, it felt so good to ride it, even it was only for an hour or so. I really needed to ride, too, because I was getting a serious case of shop burnout. Anyway, I hope you like it, and if you don't, well, what are ya gonna do? Joe
If your gonna be dumb, you gotta be tough When you get knocked down you gotta get back up, I ain't the sharpest knife in the drawer but I know enough, to know, If your gonna be dumb, you gotta be tough chollo9 screwed with this post 09-30-2012 at 04:36 PM |
09-30-2012, 04:41 PM
#2 |
ShadeTreeExpert
Oddometer: 5,229
Chollo,
It's you. What is it? Oh, you said "go any where". You're going to have to post pics of the unusual instruments.
Never memorize something you can look up. ---Albert Einstein |
09-30-2012, 05:10 PM
#3 |
Screwed the Pooch
Oddometer: 512
It's me. What am I?
You barely know me, yet you know me so well!Here's a pic of the "dash". ![]() From the front of the bike, with the windshield covering everything, it doesn't look so foreign. The box holds all of the wiring connections, since there is no large headlight bucket to stuff them all in. On the business side, I wanted the instruments, et al just below my line of sight so I wouldn't have to look down all of the time, that has always bugged me with conventional gauge placement. A GPS will go on the flat panel. Those are just simple LED idiot lights to the right of the speedo/tach unit (charging, turn, beam, OP). Not to everyone's taste, I'm sure, but it was function driven, along with my capabilities, what was available, and budget. Honestly, I'm not very impressed with the Vapor tach/speedo. It's small, and they tried to cram too much information into the space available. I only got it because of the tach function and now I'm thinking a digital only tach, versus this digital/bar graph combo might have suited me better. Oh well, nothing that can't be sold off and redone.
If your gonna be dumb, you gotta be tough When you get knocked down you gotta get back up, I ain't the sharpest knife in the drawer but I know enough, to know, If your gonna be dumb, you gotta be tough |
09-30-2012, 05:23 PM
#4 |
Don't buy from Brad
Oddometer: 7,403
cool. Does that thing on the handlebars enrich uranium, contain a flux capacitor, call in airstrikes, or at least allow you to play backgammon whilst bored on a long road trip?
On tap:Nada Aging: 3 experiments in mead - blackberry, apple, and straight honey |
09-30-2012, 05:36 PM
#5 |
Screwed the Pooch
Oddometer: 512
Mmmmmmmmmmmmmmmmead!
09-30-2012, 07:29 PM
#6 |
Shit for brains
Oddometer: 5,014
SSsaaaaawwweeeeeetttttt!!!!!!! Let's race it!!!!!
09-30-2012, 07:31 PM
#7 |
Druid
Oddometer: 2,075
Those DRZ forks with a BMW wheel? Details please.
Klaatu barada nikto |
09-30-2012, 07:48 PM
#8 | |
Wacky Bongo Boy
![]() It started as an R90/6? I don't see any /6 stuff on there.
1974 BMW R75/6, 1974 BMW R90/6, 1969 BMW R60/2 hack, 1929 Ford Model A, Metal casting, Part 2/Part 1 among others.. |
09-30-2012, 08:24 PM
#9 | |
Still on 3 wheels
Oddometer: 3,470
![]() TV....Internet? Seriously..... it looks like you might have a little sight interference going on there? Nice bike. |
09-30-2012, 09:44 PM
#10 | ||
Screwed the Pooch
Oddometer: 512
Thanks! We're hopin' to.
Oy, we're talking some work here. I'm kinda stubborn, and really wanted a 19" front wheel, ideally the stock one. There was enough room for the hub and spacer, but not for the stock disc with all of its offset. So, the disc is from a Suzuki GSXR750 (first generation), sourced from Metalgear in Australia. The center hole is 61mm, which fits the hub, and the offset is 21.5mm, thin enough to fit between the fork legs. The bolt hole circumference is different, but since they were both 5-hole, I drilled the new, 80mm pattern midway between the existing holes with a 8.5mm bit. I then had to make a four millimeter thick spacer to go between the disc carrier and the hub (this was necessary due to the caliper I used and would change with other applications). I had a cracked Airhead disc carrier that I cut the mounting flange out of and then turned it down to right thickness. I used one of the steel five-hole disc mounting "washers" on the outside of the disc when I bolted everything up and it covered the extra holes in the disc carrier. Now, fitting the BMW axle in the Suzuki forks. The threads on the axle were smaller diameter than the fork threads, but the axle diameter just inboard of that was larger than the fork ID. So the Suzuki axle that would thread into the fork would be too small a diameter to work with the BMW wheel bearings. I just wasn't up to making a new axle, so I decided to bore the fork leg so the axle would go all the way through, and put a nut on the outside, instead of threading into the fork leg. It's a nice slip fit, but was a tedious job as I hand fitted it with a reamer. The clamped side needed a split tubular shim (.5mm if I recall) between the clamp and axle. A simple spacer for the disc side to get everything centered and it was done. Jeez, it sounds so easy reading it!
If your gonna be dumb, you gotta be tough When you get knocked down you gotta get back up, I ain't the sharpest knife in the drawer but I know enough, to know, If your gonna be dumb, you gotta be tough chollo9 screwed with this post 10-01-2012 at 04:34 PM |
10-01-2012, 04:24 AM
#11 |
Don't buy from Brad
Oddometer: 7,403
it looks like it would be really really fun on a nice twisty road.
10-01-2012, 04:08 PM
#12 |
Handy Schtroumpf
Oddometer: 237
Nice job dude!
10-01-2012, 04:29 PM
#13 | |
Screwed the Pooch
Oddometer: 512
10-02-2012, 09:58 AM
#14 |
BigBrowedNeandereer
Oddometer: 1,009
Very nice custom. Would really like to see and hear about the swingarm. I can only see enough so far to see much custom work was done there as well. Some kind of brake stay on the left?? Articulations hidden by muffler? Rear axle not centered on hub?? Something special going on there, too.
10-02-2012, 10:37 AM
#15 | |
Screwed the Pooch
Oddometer: 512
