Old 10-01-2012, 06:44 PM   #1
pcwirepro OP
Aspiring Adventurer
Oddometer: 281
Stick coil question
So I "know" a guy that bought an '04 1150GS (dual-spark) a few months ago. He's been pulling his hair out since he bought it thinking that something just wasn't right. Or so I've been told.... New plugs, TB rebuild, injector cleaner, injector soak, throttle cables, 3x valve adjustment, 4-5x TB sync all with little to no improvement. Today while driving home from work he remembers reading a thread about testing stick coils by pulling one or the other. Well as it turns out one is dead. Moved it to the other side (he did that is) to confirm and the trouble moved with the coil.
So... how much improvement can he expect to see from a new coil or set of coils? Is performance affected more at higher RPM's and more noticeable under load as opposed to no load? Is BB the best (read cheapest) option for these?
Thanks for your input. I'll pass on any and all of your comments.
pcwirepro screwed with this post 10-03-2012 at 11:28 AM
pcwirepro is offline   Reply With Quote
Old 10-01-2012, 07:41 PM   #2
SR1
I'm a Seoul Man...
SR1's Avatar
Oddometer: 3,849
Send a message via Skype™ to SR1
A. Shit. Load. DAMHIK
What is this? "BB"
'07 BMW 1200GS and Yamaha WR250X/R (split personality)
Save $5 on a Smugmug account, use this code:
hVs9vtN9NsQRQ
SR1 is offline   Reply With Quote
Old 10-01-2012, 07:42 PM   #3
Adventure Trio
GS'r
Oddometer: 522
Originally Posted by SR1 View Post
A. Shit. Load. DAMHIK.
+1
Experienced this myself.
-Terry
Adventure Trio is offline   Reply With Quote
Old 10-01-2012, 07:44 PM   #4
pcwirepro OP
Aspiring Adventurer
Oddometer: 281
No Beemer Boneyard?
Too late to call and can't find them on their site. Hmmm.
Old 10-01-2012, 07:45 PM   #5
lp6
lp6's Avatar
Oddometer: 48
night and day. during heavier acceleration above 4000 rpm, 3rd gear and up the bike will actually run rather than crap out
2006 R1200 GS
2009 KTM 300 XC-W
lp6 is offline   Reply With Quote
Old 10-01-2012, 07:45 PM   #6
def
I have little to say
def's Avatar
Oddometer: 6,480
Send a message via Skype™ to def
Think about this....a two cylinder boxer running on only one cylinder?
You make the call.
def is offline   Reply With Quote
Old 10-01-2012, 07:48 PM   #7
SR1
I'm a Seoul Man...
SR1's Avatar
Oddometer: 3,849
ahh, beemer boneyard. if the have them. might need to order through max like i did
hVs9vtN9NsQRQ
Old 10-01-2012, 07:49 PM   #8
pcwirepro OP
Aspiring Adventurer
Oddometer: 281
Secondary plug contributes?
Surely it isn't running on one cylinder if the secondary plug is firing. Could this have done damage over 2k miles?
Old 10-01-2012, 07:50 PM   #9
pcwirepro OP
Aspiring Adventurer
Oddometer: 281
Cry Ouch
$130/ea. at Max.
Old 10-01-2012, 08:21 PM   #10
def
def's Avatar
Oddometer: 6,480
One cylinder's contribution to performance and power is severely compromised. You might as well be riding a 500cc thumper.
As for damage, I can't say.
Old 10-01-2012, 08:53 PM   #11
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,188
Try this, click here $80 two coils.
Originally Posted by HackyMoto View Post
Am fortunate to have two GS’s a’ 04 1150 36k and a ’06 1150 adv 47k both twin spark. Both started running ruff dropping a couple hundred rpm’s at idle and missing under load. The coil sticks (one each) on both bike’s went bad within a couple weeks so that’s 2 time’s 140.00 or 4 time’s if one’s to replace them all. I didn’t want to go back to the coil sticks because of the fail rate and the price so I started thinking what kind of alternative action I could take. I wanted a coil that was small available everyware and (cheep) (inexpensive) reasonably priced, I found it 1999- to present 5.4 Ford F-150‘s C.O.P. coils checked the specs (Ohms) close enough and at 30 bucks each it’s worth a try.
Pick-up two coils from the parts house and a wire harness from a ford 5.4 at the auto recyclers for the connectors on the coils. Plug wires I’ve had laying around.
I didn’t want to cut the bikes wiring in case I wanted to ever go back to the stick coils, so I got four sub-d connectors that fit right into the bikes coil connectors.
Hook it up and I’ve got spark
The coil are zippy tied to the frame for now if this works out I’ll mount them-up this winter.
Got about 200 miles so far all’s well.
2 coils 60.00
Wire harness 10.00
Sub-d connectors 2.00
Plug wires ????
scooteraug02 is offline   Reply With Quote
Old 10-01-2012, 08:54 PM   #12
Beezer
Oddometer: 4,478
here ya go....
http://www.advrider.com/forums/showt...ght=stick+coil
by the way, Hacky is a top rider & we need to send him to South America to compete in the BMW challenge
http://www.advrider.com/forums/showthread.php?t=830908
EDIT.... ha.... Scooter ya beat me to it
Beezer is offline   Reply With Quote
Old 10-01-2012, 09:03 PM   #13
scooteraug02
Dog Rancher
Oddometer: 4,188
Google stick coil for motorcycle under shopping. Japanese bike coils inexpensive. Find one similar to BMW.
Old 10-01-2012, 09:14 PM   #14
SR1
I'm a Seoul Man...
SR1's Avatar
Oddometer: 3,849
$130/ea. at Max.
Yup, well aware of that, too.
The Ford coils (or whatever) are certainly an idea, though it requires some garage space and some time to do, neither of which I had when I was fighting my coils (others here can attest to that). I was fighting it all from Korea (where I am now) and getting the right or wrong harness/assembly through the mail is a bigger issue than just ordering the damned part from Max or whomever and sucking it up. Sure enough, once the bad coil was replaced it was like riding a brand new bike. 2 probems I see with BB on the coils. 1, you hope they have the one you need (primaries are the same but secondaries are left/right specific) and also 2 what if the one they have is also shit? Coils are difficult to test according to what I've read, so even though it passes current and shows good impedance throught the body it may still be crap. Now you have an $80 used coil and STIL need a new one. I don't like to gamble, even when I'm in Vegas. I just pulled out my wallet and ate it. At least the bike runs now.
Eventually I'll probably switch to the car coils once I get to the US again.
hVs9vtN9NsQRQ
Old 10-01-2012, 09:59 PM   #15
vagueout
vagueout's Avatar
Oddometer: 1,131
Would not bother jerking around with used coils, these things have a finite life. New coils and you will love your bike again.
i just seek clarity
vagueout is offline   Reply With Quote
Times are GMT -7.   It's 07:19 AM.
