Old 10-04-2012, 12:57 PM   #1
redblk63 OP
TacoDog
Oddometer: 4
Question on 1970 Bultaco Matador
I have just begun work on a Mk IV Matador I have had in the back yard since 1979. Picture of frame below. (Oops, "You may not post attachments") My question is about the lower triple clamp.
When I removed it from the frame, it came away with the steering stem. So far, so good. The problem is that it can rotate about the steering stem, and that joint is a bit loose (it wobbles).
How are those parts meant to be joined together? I would have guessed they could be welded together, but maybe they were a press fit, or threaded, or ?
I am currently mystified, and any help will be appreciated.
Thanks,
Larry - Pasadena
1970 Matador (resuscitating)
1969 Matador (just a rider, Snowy Trail veteran)
Hondas
redblk63 is offline   Reply With Quote
Old 10-05-2012, 01:47 AM   #2
Twin-shocker
Oddometer: 1,673
If the lower yoke is alloy then the stem will be a press fit, if its steel can also be press fit or may be welded.
Old 10-05-2012, 09:04 AM   #3
redblk63 OP
TacoDog
Oddometer: 4
Thanks twin shock. It is a magnetic metal, so I will investigate further. It's really loose, about 10 degrees of wobble. May need to use a fixture to insure right angle if it needs welding.
Larry - pasadena
Old 10-05-2012, 10:50 AM   #4
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,248
I'm guessing press fit.
You can post pictures by using a picture/file sharing host site like Photobucket. They are free and easy to use
"I couldn't wait for success, so I went ahead without it."
Strong Bad is offline   Reply With Quote
Old 10-05-2012, 11:14 AM   #5
Twin-shocker
Oddometer: 1,673
Larry - pasadena
If its 10 degrees I would suggest either properly repairing the worn or damaged part, or a used replacement. Welding it when there is that much movement, will mean distortion is almost certain.
Old 10-05-2012, 12:29 PM   #6
blaine.hale
blaine.hale's Avatar
Oddometer: 3,144
Pick one up off ebay. They pop up every now and again. It's definitely a press fit, in wich case, welding could interfere with the inner race/bearings. Sounds like someone may have been a bit rough on riding that matador :)
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Times are GMT -7.   It's 10:49 AM.
