Old 10-05-2012, 06:24 PM   #1
maximuski OP
Don't Follow Me I'm Lost2
Oddometer: 73
BMW skip plate fits ADVSpec bars?
Sorry, I tried to find the answer at some threads without luck.
Does anyone know if the BMW skid plate would fit with my ADvSpec bars?
99' Suzuki Freewind /// 98' Honda XRV750 Africa Twin /// 07' Suzuki DL650 WeeStrom /// 09' BMW F800GS /// 02' Honda XRV750 Africa Twin
2010 Canadian West Coast Trip
http://motorcyclemisadventures.wordpress.com/
maximuski is online now   Reply With Quote
Old 10-05-2012, 07:15 PM   #2
maximuski OP
Oddometer: 73
Got it!
Kept digging around and found that ... YES, they work together.
http://www.advrider.com/forums/showt...dvSpec&page=28
Old 10-05-2012, 08:12 PM   #3
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 592
You know what else fits with the Adventure spec bars?
The Adventure spec skid plate.
And I can personally assure you that plate is one tough bastard.
BMW plate on the other hand had some iffy reviews if I recall correctly.
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 10-05-2012, 08:21 PM   #4
maximuski OP
Oddometer: 73
Thumb
Thanks for the advice. ADVSpec plate has been my first option, love the bars, just checking other options, but I'll definitely consider your advice.
Old 10-05-2012, 10:04 PM   #5
Nacho911
Nacho911's Avatar
Oddometer: 368
I have the Advspec plate and bars. They rock. Don't waste your money on the BMW branded money pit. Order your stuff from ADV spec. I did on a Monday and it arrived in Alberta from the UK on Thursday the same week. Cheap shipping and hardly any duty.
Nacho911
Nacho911 is offline   Reply With Quote
Old 10-06-2012, 03:35 AM   #6
LukasM
Oddometer: 4,942
+1. Much better options from the aftermarket than BMW accessories, and the ADV Spec one is excellent.
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 10-06-2012, 09:11 AM   #7
MCMXCIVRS
Begining the Adventure
MCMXCIVRS's Avatar
Oddometer: 1,016
I'll back that up with first hand experience. Hit a rock, bent the BMW aluminum skid plate and cracked the sump. I replaced it with a MOD skid plate that is a lot sturdier.
If you feel you need crashbars as sturdy as the Adventure Spec ones, then you'll probably need a better skid plate than the BMW offering.
Ed
2009 BMW F800GS, 2008 BMW K1200GT
MCMXCIVRS is online now   Reply With Quote
Old 10-06-2012, 09:02 PM   #8
PatrickM
Oddometer: 210
+1 on the Mod skid plate. Protects the cat too.
PatrickM is offline   Reply With Quote
Old 10-06-2012, 09:40 PM   #9
Jooka
I grow everywhere
Jooka's Avatar
Oddometer: 28
Originally Posted by patrickm View Post
+1 on the mod skid plate. Protects the cat too.
+2
Jooka is offline   Reply With Quote
Old 10-09-2012, 08:24 AM   #10
Johnnydarock
Johnnydarock's Avatar
Oddometer: 162
BMW Skid Plate Sucks
I have the Adventure Spec crash bars and they are clearly the best out there...and I looked at everyones before buying. I didn't do the same search with the BMW skid plate and the welds show signs of cracking in two places. Not happy! Go with the Adventure Spec plate if you haven't bought it already.
Johnnydarock
Johnnydarock is offline   Reply With Quote
Old 10-09-2012, 09:49 AM   #11
PatrickM
Oddometer: 210
Johnnydarock
I disagree. Are they good? Well, they're certainly better than nothing! But are they the best? Now this is qualitative statement which requires a bit of proof & justification.
Let's compare the mount options between the two. The Adventure Spec mount to the frame at six points. They are metal tabs which rely upon a bolt to pull in the mounting tabs to the outside of the frame.
Now compare to the AltRider ones. They mount to the frame at the same 6 points but it's obvious from the pictures they actually sit INSIDE of the frame mounts and the bolt pull the tabs internal to the frame mounting point. Plus provide resistance/reinforcement.
Realistically, you could have the AltRider ones work with barely any (0?) bolts because of the way it is designed.
Times are GMT -7.   It's 02:13 PM.
