Old 10-05-2012, 02:40 AM   #31
Hicks OP
der Überluber
Hicks's Avatar
Oddometer: 457
Originally Posted by maigashi View Post
Without knowing too much specifically of the gs motor, I am very familiar with BMW engines and it is not uncommon for the pistons to be the first to go and the cylinders and rest of the engine to look fine. Unlike most other engine the cylinder walls in BMW's are nikasil coated or treated. The makes them the metal equivalent to diamond. Pistons wear and the cylinder remains. Nice in a lot of ways since you don't have to overbite when you rebuild. New piston, new rings and a go. It is a little odd for the pistons to wear but something has to give no its not the wall, then.......
Good luck. Pictures would be great :)
thx for the valuable info ;) it quite a correspond what they told me in the service :)
R1200GS 2013 LC, F800GS '08 (130 000+km)
.de + .at + .it + .sk + .pl + .hu + .li + .ch + .fr + .es + .p + .and + .lu + .be + .nl + .uk + .sco + .ork + .slo + .hr + .bih + .srb
Hicks is offline   Reply With Quote
Old 10-05-2012, 03:27 AM   #32
LukasM
Oddometer: 5,425
Nikasil plated cylinders can wear as well, so you should still get the cylinders checked with a bore gauge for taper and out-of-round.
Old 10-06-2012, 11:52 AM   #33
Hicks OP
der Überluber
Hicks's Avatar
Oddometer: 457
I had.
after 135 they are in tolerance (=VERY round :).
Old 10-06-2012, 12:01 PM   #34
Hicks OP
der Überluber
Hicks's Avatar
Oddometer: 457
my piston on the left.
The darker body means that it's teflon-coated, they say.
carbon + my sexy hand
Old 10-06-2012, 01:30 PM   #35
itsatdm
itsatdm's Avatar
Oddometer: 4,904
There are a few pistons like that are out there, you get any insight about about yours. You aren't one of those, it runs fine on regular guys are you? Any modifications you don't want to tell us?
Old 10-06-2012, 01:41 PM   #36
Hicks OP
der Überluber
Hicks's Avatar
Oddometer: 457
you mean that it looks too good for such kms?
Old 10-06-2012, 04:35 PM   #37
ebrabaek
Oddometer: 4,758
The gunk ( Carbon ) on the top is normal, due to all the different additives in modern gas. You do however have quite a lot of blow by. ( rings not holding back the pressure) Which is then caking the oil channel in the lube ring...which then further decimates the lube process. This much blow by would have been visible in the exhaust, I would think. Did you notice any " abnormal engine behavior"....or did you just decide to tear into the motor for the fun of it....????
Erling
Times are GMT -7.   It's 08:48 PM.
