10-06-2012, 08:56 AM
#1 |
Oddometer: 281
I'm putting together an R100 Frankenbeemer. I just got the heads on and everything torqued up a couple of weeks ago and noticed when I was installing the exhaust today that one of the new push rod seals was torn.
![]() Now everything on the right side has to come off to replace that stinkin' seal. My question is, even though the bike hasn't been running, am I going to have to replace the head gasket again? Also this is one of those cylinders that requires a large o-ring around the cylinder and the 2 o-rings around the studs. Am I going to have to replace those as well? I just want to make sure I order everything at once and save on shipping.
--------<>-------- 2004 R1150GS Adventure (The Valdez) 1973 R75/5 Red Toaster (Amy) |
10-06-2012, 09:02 AM
#2 |
Oddometer: 30
torn pushrod seal
hi,you will only have to replace the two small o rings and the larger base o ring ,i would of thought the head gasket is fine.i have had the heads off mine and reused the gasket with no ill effects.
10-06-2012, 09:16 AM
#3 |
odd
Oddometer: 1,092
Leave the head attached to the barrel with the 12 and 6 o'clock bolts. No need to replace the o-rings, they are still fresh.
Just slide the barrel out with engine at TDC keeping the rings in place. If you used sealant at the base, you have some cleaning to do and careful but awkward re-application. But no big deal.
Never underestimate the laxative properties of motorcycling. |
10-06-2012, 09:44 AM
#4 |
ShadeTreeExpert
Oddometer: 4,980
A lot of riders would take the wrist pins out of the pistons so the pistons will stay in the cylinders and the heads stay on top of the cylinders. It's OK to do that way but be very careful when reinstalling the wrist pin circlips. The circlips have to be prooved or proofed. There's not a lot you can see when performing this operation and everything is still attached to the engine. There is just not a lot of room to stick your head in there.
Even a circlip installed in a place where you can see what is happening is proofed. Once installed, you think it's in place, the circlip is spun in it's bore. Spin it enough so that you can see it is seated. That's it. Prove all circlips. My friend lost a piston, cylinder, cam shaft, oil pump and lifters. Because a circlip was not fully seated.
Never memorize something you can look up. ---Albert Einstein |
10-06-2012, 10:06 AM
#5 |
Von Hochstaden's son
Oddometer: 44,956
Take the valve ro kers off and move the whoe thin up a bit. Tdc or u will spend some time with the ri.g compressor. Master te h at bmw did all pushrod seals that way. 30 minutes. Readjust the valves before reinstaling valve covers.
mikuni vm32-33 both sides :\ 5000 feet altitude/ 140 main \ 159 02 needle jet\ 6F4 needle in the middle setting\ 0.5 air jet\ pilot 25/3.0 slide 35 mpg around town riding like a asno |
10-06-2012, 12:53 PM
#6 |
because I can
Oddometer: 6,041
Where did you get the seals Blaine?
10-06-2012, 01:38 PM
#7 |
enamoured
Oddometer: 2,477
Have you checked for leaks? I put one in a few weeks ago that got a bit squished & a bit is hanging out. I didn't notice it till after I'd ridden it for a few hundred Kms.
Replace if you want- it may bug you that it is there smirking at you I got mine from motobins. |
10-06-2012, 01:48 PM
#8 |
In need of repair
Oddometer: 1,426
10-06-2012, 01:49 PM
#9 |
enamoured
Oddometer: 2,477
barstard
10-06-2012, 02:29 PM
#10 |
Oddometer: 281
From Hans at Hucky's BMW Parts.
10-06-2012, 03:26 PM
#11 |
Beemerholics Anonymous
Oddometer: 7,354
I wouldn't replace the ORings. As said, they're still fresh.
I've re-used used head gaskets in my bikes many times, only freshening the sealant around the top studs and pushrod tubes. Hasn't been a problem yet. And in your case, it's still new with no heat cycles - but best to leave the head and cylinder together.
Wanted: Dead, smashed, crashed or trashed gauges BMW GAUGE REPAIRS - TACH*SPEEDO*CLOCK*VOLT METER *PODs & LIGHT BOARD* |
10-06-2012, 05:42 PM
#12 |
because I can
Oddometer: 6,041
I wonder if they are BMW. There are some bad ones floating around from Motobins or Capital Cycle or some place like that.
Or maybe it was from BMW (the bad ones). They are selling crap as if they were Capital cycle lately. I just got a new cadnium plated front axle. WTF? It's going to turn to rust in no time. |
10-06-2012, 06:05 PM
#13 |
Oddometer: 505
Did you put any sealant on the push rod tubes before the seals where put on them ?
Have seen a lot of those seals slide over the ring on the tube and than burst because some sealant was used there. Just thinking why they would burst. Of course there could be some bad ones out there.
BMW R100'91/R80'93/R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920 R100GS'91 (sold) |
10-07-2012, 04:05 AM
#14 | |
Oddometer: 281
10-07-2012, 04:08 AM
#15 | |
Oddometer: 281
