Old 09-27-2012, 09:23 AM   #1
Roughseas OP
Roughseas's Avatar
Oddometer: 63
140 or 160 tyre on a R1150GS?
Cant find any 150/70 size in the market here and was wondering if anyone tried a 160/60 for the rear? The tourance I have on has the tread depth but has become brittle and breaking off in chunks
Roughseas is offline   Reply With Quote
Old 10-06-2012, 06:53 AM   #2
Roughseas OP
Roughseas's Avatar
Oddometer: 63
Anyone? 140/70 or 160/60
Old 10-06-2012, 06:58 AM   #3
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,810
Haven't done it myself, but there are numerous threads here where inmates have successfully installed and run 140 width tires on their GS/GSA.
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 10-06-2012, 08:25 AM   #4
mcstark
KaTooM convert
mcstark's Avatar
Oddometer: 1,128
I have not run anything other than a 150mm Tourance, but looking at the Metzeler spec chart I think a 140 would be a tight fit. The 150-section tire has a max diameter of 650mm, but the 140-section tire has a max diameter of 667mm. That's .67 in, which eats up half the clearance between the rear tire and the lower shock mount.
Too tight for my liking. What tire were you looking at in 160mm-section?
Regards,
Mark
2004 KTM 950 Adventure
Black is the new orange
mcstark screwed with this post 10-06-2012 at 08:31 AM
mcstark is online now   Reply With Quote
Old 10-06-2012, 09:00 AM   #5
mousitsas
mousitsas's Avatar
Oddometer: 2,750
The 140 dimension is a far better choice for the 4" rim size, than the 160.
Old 10-06-2012, 10:56 AM   #6
Ua the Destroyer
Ua the Destroyer's Avatar
Oddometer: 235
Lots of people ran the 140/80-17 mitas e09 and heidenaus on their gs's in the past before the correct size was available
some pictures and measurements in this thread
http://advrider.com/forums/showthread.php?t=614147
Ua the Destroyer is offline   Reply With Quote
Old 10-06-2012, 11:33 AM   #7
Beezer
Oddometer: 5,746
depends on the tire... I've seen 120 tire that were wider than 130 and 130 that were wider than 140.
P.S. I have run a 130 TKC on my 1150 & it worked fine
Beezer is offline   Reply With Quote
Old 10-06-2012, 01:02 PM   #8
Roughseas OP
Roughseas's Avatar
Oddometer: 63
Thats the reply I wanted
I am looking at a Conti-go 140/70 for the rear. The 150/70 is almost non existent in the Indian market and the only options I have are the 140/70 Pirelli SD or the Conti-go. Thanks all!
Old 10-06-2012, 02:02 PM   #9
Ua the Destroyer
Oddometer: 235
Well a 140/70 has a smaller diameter (14mm smaller) than a 150/70, but should work fine. your speedo will read a couple kph faster than your speed with that size tire, but not enough to be a big deal.
Old 10-06-2012, 03:02 PM   #10
mcstark
KaTooM convert
mcstark's Avatar
Oddometer: 1,128
The Tourance is a 140/80, which makes the difference. A 140/70 should be fine.
Regards,
Mark
Old 10-07-2012, 02:51 AM   #11
Zoef zoef
Oddometer: 372
Sir, the speedo on a R1150GS works on the front wheel, and if I'm not mistaken we are talking about the back wheel here?
Zoef zoef is offline   Reply With Quote
Old 10-07-2012, 05:57 AM   #12
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,402
I just put a 140 Heidenau on my GS. It's rubbing the Maier hugger a little offroad, but it doesn't look bad so far. I like the height and the feel. We'll see!
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is offline   Reply With Quote
Old 10-08-2012, 04:17 AM   #13
OzRob
OzRob's Avatar
Oddometer: 674
I used to run 140's Heindenau K60's with no problem and a mate of mine runs E07's as they are cheaper than the 150's
I recently read a post where a bloke on a trip around Oz fitted a 160/60 road bike tyre on his GSA 1150 so he could get home.
OzRob is offline   Reply With Quote
Old 10-08-2012, 11:53 PM   #14
Ua the Destroyer
Oddometer: 235
Laugh
Duh brain fart
Old 10-10-2012, 10:18 PM   #15
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,402
BTW, on this topic again...
I realize I'm speaking from the 1200 perspective, but my clearance does not appear to be similar at all to that in the photo of the K60 on an 1100. I'm guessing the shock mount or the length of the swingarm is different... I have plenty of clearance between the tire and the shock mount with the 140 K60.
Times are GMT -7.   It's 12:13 PM.
