Old 10-08-2012, 08:11 AM   #1
chasesa OP
Oddometer: 16
R100GS oil light flickering
My 1990 GS oil light flickers when driving. I realize this can signal low oil pressure but I'm interested to know anyone's experience with faulty indicator lights. I have just replaced the sender unit.nsame flickering.
On removing the filter, all O rings are ok and in place.
Your advice please.
Stephen C
chasesa is offline   Reply With Quote
Old 10-08-2012, 08:39 AM   #2
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,052
The light, if it illuminates, if fine . . . . . if you get flickering on the oil (pressure) light using two different sending units, and you have checked the wiring, I would bet you have low oil pressure.
this can be caused, of course, by having too little oil in the reservoir/engine . . . . I assume you've checked?
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance. T.R.
Old 10-08-2012, 09:38 AM   #3
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,716
Very easy to connect a proper gauge on them. That way you'll know for sure. Them oil pumps can push over 100 PSI cold. The idiot light, altough I don't have the specs here should come on at around 12-15 PSI. Lots of bad things can happen to them engines between 15 PSI and the normal operating oil pressure.
That would be a better question for the Airheads in Old's Cool then they can go on about the proper mounting/measurements of them oil filters.
Have tools, will travel!
Old 10-09-2012, 04:58 AM   #4
StephenB
G(/)S ... what else!
StephenB's Avatar
Oddometer: 2,044
There are people out there saying that when the oil lights comes on flickering it's already too late. My advice: do not ride the bike, find the cause. Start wit the obvious (enough oil, no leaks), then measure the oil pressure. My 1000cc engine pushed up to 160psi cold and settled to 20psi @ idle and 60psi @ 4000+ with the engine at operating temperature.
How to build a cheap and cheerful oil pressure meter in 5 minutes under $30:
  • a 1 1/2" oil pressure gauge from your local hydraulic supply, 1/8NPT fitting, 160psi range, 270deg sweep (my preference)
    => $5.50
  • a tubing kit with 3ft-4ft of 1/8" nylon tubing and at least a 1/8NPT Male and one 1/8NPT Female fitting (e.g. EQUUS #9801)
    => $9.10
  • one adapter fitting M12x1.5 Male to 1/8NPT Female (to fit the original location of the OEM oil pressure switch)
    => $9.40
  • one 7/8" hose clamp
    => $3.50
Oil pressure gauge on the bike:
Some of the above is fact, some is fiction, some is my personal imagination and some is just simple truth. [me]
... i'm not touring around the world, but neither are most of the guys i see running overloaded spam cans ... [bmwblake]
Stephen Bottcher
Ontario, Canada
'72 R75/5 The Blues
www.stephenbottcher.net
StephenB is offline   Reply With Quote
Old 10-09-2012, 10:11 AM   #5
ignatz72
call me iggy
ignatz72's Avatar
Oddometer: 626
Does the same light in the dash light up fully if you short the oil pressure sender lead to ground? If not, it's likely the oil and charge bulbs got swapped at some point.
If the right bulb fires above, it's time to measure your canister depth and adjust the filter gaskets/shims accordingly.
http://www.largiader.com/tech/filters/canister.html
Current: 93 R100GS, 03 XR650R
Prior: 73 CB350, 77 R100/7, 83 R100RT, 04 XR650L
I love every motorcycle I've owned and even some that I haven't.
ignatz72 is offline   Reply With Quote
Old 10-09-2012, 10:39 AM   #6
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,509
Add an extra shim behind the white o-ring and see if the problem goes away.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Boxer Metal is online now   Reply With Quote
Times are GMT -7.   It's 06:06 PM.
