Old 10-08-2012, 02:09 PM   #17
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,886
Originally Posted by NW Cascade Rider View Post
It was firing on both cylinders, it just seemed to favor the Left jug a bit more. But the spark on both cylinders was very weak. And both TB's showed evidence of back fire / miss fire. Again, missing more in the Right jug than the left. I was not aware that the Ignition fired both cylinders at the same time. that being the case, Is there a good alternative coil or a coil with the same part number that would be a good replacement? If I could find a coil that had the same ohm and voltage output that would be sweet.
I think there are several companies selling more cost-effective replacements to the expensive BMW ignition coil from a dealer. I just had a look and Euromotoelectrics has it listed here, Beemerboneyard has used replacements listed here (out of stock at the time of posting) and Motorrad Elektrik has them listed here. No special reason why you should go to them as I'm sure you could find other sources also - these were just the first places I looked. These guys also all state that early oilhead coils were failure prone.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Times are GMT -7.   It's 01:16 PM.
