Old 10-09-2012, 06:13 AM   #1051
rey_s
Oddometer: 10
fuel leak?
Hi everyone.
New to the world of adventure bike ownership. Recently took the plunge and bought the sertao. Really happy with it. Had a bit of an unpleasant suprise this morning when I saw droplets of fuel on the left side of the bike. I reached under the black plastic gs tank and felt fuel underneath it. Is this normal? Does it do that because its over filled or should I immediately send it to the dealer? I heard its an old problem with Dakars, but have blnot heard of.fuel leak issues with the sertao. Thanks for the advise.
rey_s is offline   Reply With Quote
Old 10-09-2012, 11:20 AM   #1052
VitSports6
VitSports6's Avatar
Oddometer: 195
Originally Posted by rey_s View Post
Hi everyone.
How much is it leaking? I was told to fill the tank up to the orange filler neck, Not to the top, why I don't know.
I would at the very least contact the dealer.
Best of luck
Have Fun!
Brian
VitSports6 is offline   Reply With Quote
Old 10-09-2012, 01:42 PM   #1053
rey_s
Oddometer: 10
Best of luck
It's more like its weeping fuel. Just droplets. I filled it up until the auto stop on the nozzle kicked in. Think the fuel was up to the orange neck. Did I overfill it?
Old 10-09-2012, 02:07 PM   #1054
Lost.In.Hokkaido
Lost.In.Hokkaido's Avatar
Oddometer: 9
Hi everyone.
I'm probably at a similar point as you. New to the world of Adv. bikes but so far loving every minute of it. Bought a Sertao in Sept and so far have 800km on it. I will keep my eyes out for any fuel issues and will let you know if something comes up (or should I say comes out).
Lost.In.Hokkaido
Paul
2012 G650GS Sertao
2008 WR250R
Lost.In.Hokkaido is offline   Reply With Quote
Old 10-11-2012, 10:08 AM   #1055
kdennan
kdennan's Avatar
Oddometer: 630
When are we gonna see progressive fork springs from touratech?
kdennan is offline   Reply With Quote
Old 10-11-2012, 10:28 AM   #1056
kdennan
kdennan's Avatar
Oddometer: 630
Bummer...
I'm at almost 1500 miles on mine with zero starting issues, which is great for me
Good to hear you were able to get your parts off.
I had hot start issues and the dealer (after I inquired) read the bulletin and replaced the decompression lever and all is happy now.
Old 10-11-2012, 12:31 PM   #1057
pasomonte
Oddometer: 95
thats not normal.Id take it to the dealer.
Sent from my SCH-I535 using Tapatalk 2
pasomonte is offline   Reply With Quote
Old 10-11-2012, 03:13 PM   #1058
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,897
just for the record. I hate changing the oil in this thing. what is the point of putting the oil filter up behind all that plastic ? jeez.
Enduro Earth
YOUTUBE
off the grid and deep in the woods
swamp is online now   Reply With Quote
Old 10-11-2012, 05:30 PM   #1059
swamp
swamp's Avatar
Oddometer: 1,897
Thumb 2012 bmw sertao oil change
oil and filter change... i guess im used to dirt bikes or something.
changing oil shouldnt require removing this much crap.. or am i wrong?
i didnt know that this was the drain plug for the oil can.... i know now; because i had to clean up an exxon valdez oil spill from my garage floor.
way too many
ive never had a bike that required me to remove suspension component in order to change the oil filter, and ive had a few bikes
this is when i realize two things:
1. the bmw dealer sold me the wrong fucking oil filter and
2. im selling this piece of shit and buying a DR650
its a nice bike but im not fond of how she is put together.
Enduro Earth
YOUTUBE
Old 10-12-2012, 03:04 AM   #1060
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,494
You can use a vacuum pump to suck the oil out of the reservoir tank, eliminating the need to remove the bodywork.
Eliminate the need to remove the bash plate by drilling a hole in it to access the drain bolt.
And while you're at it, replace the battery with a maintenance free one so you don't have bother pulling off bodywork to check the electrolyte levels.
2014 350 EXC-F
2011 XT1200Z
2009 FLHR
2006 Djebel 250XC
twinrider is online now   Reply With Quote
Old 10-12-2012, 08:27 AM   #1061
petepuma
petepuma's Avatar
Oddometer: 403
Just curious.....does the regular G650 have the same hot start issues?
petepuma is offline   Reply With Quote
Old 10-12-2012, 08:32 AM   #1062
matloik
kludge
matloik's Avatar
Oddometer: 1,253
Yes.
http://www.f650.co.uk/forums/showthr...-issues/page63
2011 KTM 250 XC-F / DRZ-ADV / 2013 WR250R (wife's)
matloik is offline   Reply With Quote
Old 10-18-2012, 09:16 PM   #1063
VitSports6
VitSports6's Avatar
Oddometer: 195
Finally got around to buying some panniers, I went with the Caribou cases and some Touratech mounts on my Touratech rack, I am pleased with the outcome, However, I think I may put together some sort of plate on the inside of the case for strength.
I went to take some pic's and my camera seems to have taken a dump...
I will get some pic's up tomorrow
Have Fun!
Brian
Old 10-19-2012, 02:00 AM   #1064
Kim_uk
Oddometer: 41
I am planing on getting the Caribou cases but thought they were only available for the Hepco Becker, GIVI or SW-Motech racks. How did you get them for your Touratech rack and which size case did you go for?
Kim_uk is offline   Reply With Quote
Old 10-19-2012, 05:32 AM   #1065
VitSports6
VitSports6's Avatar
Oddometer: 195
I bought the Touratech 18mm Pannier Mounting Kit They have other rack kits, So you will need to see what millimeter tubing was used on your specific rack, I have the Stainless Steel Zega rack on mine, when I had all the pieces together, I ratchet strapped the cases on my Sertao and moved them to where I liked the fit, Then I used a wax pencil to trace the inner rack dimensions(not as easy as it sounds) as well as where I thought the pucks would work, Drilled and put everything together.
I will get some pic's up in a few hours, I'm about to head off to work where I have another camera.
I hope that helps.
Have Fun!
Brian
Times are GMT -7.   It's 07:17 PM.
