Old 10-09-2012, 11:54 AM   #1
BOB RAMSAY OP
Not in the clique :)
BOB RAMSAY's Avatar
Oddometer: 274
Rear brake - way too weak (950)
My rear brake is about 5% effective - actually, more like 0%, as I cannot stop the bike, even under 10mph.
A little history:
2006 950 Adventure
OEM pads/rotor, 24k miles (all road).
Pads 6mm thick.
Had a light oil contamination on pads/rotor last week (don't ask. . . ).
Pulled, cleaned and sanded pads and sanded rotor today. Nada.
Fluid changed summer 2010. Free play is good.
There is some pressure at pedal, no pressure being applied to the rotor.
Can the wheel cylinder 'blow by' the seals when the brake is applied?
Any help would be appreciated. Thx -
I'll take Heaven for the climate - Hell for the company.
BOB RAMSAY screwed with this post 10-25-2012 at 06:12 AM
BOB RAMSAY is offline   Reply With Quote
Old 10-09-2012, 12:01 PM   #2
Cyclops Motorsports
Cyclops Motorsports's Avatar
Oddometer: 905
personally I like sintered Iron brake pads,They bite hard, but do wear your disk.
Im always draging my rear brake, (bad habits are hard to break) I replace my fluid about once a month, Its amazing how quick the fluid can go to crap.
When Quality matters,Its all about choices.
Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
http://youtu.be/1fmEJO3ftFI
Cyclops Motorsports is offline   Reply With Quote
Old 10-09-2012, 01:03 PM   #3
veesquared
Oddometer: 18
Freeplay
Assuming you do not have air in the lines from a tip over . Can you lock the rear wheel on asphalt? Try cleaning the rotor again with your favorite solvent . You might find that you have squeezed out more oil. If no go them I too would go with a different compound. 6mm must be pretty close to new.
Always keep people in your life that charge your battery. Not those that drain it.
veesquared is offline   Reply With Quote
Old 10-09-2012, 01:19 PM   #4
crofrog
Oddometer: 1,376
A little history:
2006 950 Adventure
Pads 6mm thick.
Had a light oil contamination last week (don't ask. . . ).
The pads seem to be a darker (gray) as opposed to the 'bronze' color of fresh pads.
My use of the rear brake is an afterthought, growing up on dirt bikes. But, at times, every little bit counts.
I've noticed the brake being weak before the oil contamination. I always assumed the brake was designed 'weak' for off-road use. But, what do I know. . . ?
2010, I do that like every 6 months...
crofrog is offline   Reply With Quote
Old 10-09-2012, 01:29 PM   #5
txbear55
Oddometer: 128
New pads....
txbear55 is offline   Reply With Quote
Old 10-09-2012, 03:10 PM   #6
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 556
Galfer Green pads! Stock ones absolutely blow!
Sporting Wood is offline   Reply With Quote
Old 10-09-2012, 03:50 PM   #7
Roughidle
Super Star Destroyer....
Roughidle's Avatar
Oddometer: 1,490
A little history:
2006 950 Adventure
Pads 6mm thick.
Must be some different riding styles out there, I grew up on dirt bikes in Michigan and I used the rear brake ALL the time. Too much front brake = lowside. But I digress, that isn't really what the post is about.
Did you ever get the reservoir diaphragm upgrade? KTM sent out a service bulletin about it back in 07 IIRC (took my 06 950a in for it). The bulletin called for a new diaphragm, and a rear brake bleed.
If I was in your shoes, I'd ensure I have the upgraded diaphragm, pick up a new set of galfer pads as others have suggested, and properly bleed the brakes.
You can check it for "blow by" or leaking cylinder seals by doing the following:
Pump the rear pedal 3-4 times and hold pressure on it, if it starts to slowly move as you apply pressure, then it needs a rebuild. If it stays in the same position after you pump it a few times and hold it, then the cylinder is fine.
Ideally, you should be able to lock the rear brake on dry pavement on these bikes, I was always able too with my 950.
Burninating the peasants.
Roughidle is offline   Reply With Quote
Old 10-09-2012, 05:43 PM   #8
Mttodd
Oddometer: 36
Bought my 06 last summer and would like to know how to identify the improved diaphragm. If I do have the old version is the new one expensive, or supplied like a recall? Noticed that my rear brake pedal has a lot of play before it engages. It does not have any adjustment like the newer models, and was looking for some pointers.
Mttodd is offline   Reply With Quote
Old 10-09-2012, 06:35 PM   #9
Roughidle
Roughidle's Avatar
Oddometer: 1,490
Brake TSB with pics: http://cpmodem.smugmug.com/gallery/2...944527&k=PppNc
From here: http://www.ktm950.info/
Just bookmark the HOW link. I actually copied all the articles into a big book when I had my 950, just in case. \ Big props to CPmodem as always.
Really? Aren't there adjustment nuts on the pushrod? It's been a while, and I could be wrong, but I thought there were adjustment nuts on the pushrod. I seem to remember adjusting the pedal height after installing new/ lower pegs.
Roughidle screwed with this post 10-09-2012 at 06:49 PM
Old 10-09-2012, 06:59 PM   #10
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 4,234
For what it's worth, my 04 (rebadged 03) brakes suck so bad, even standing on them barely slows the bike. At least I don't have to worry about stalling it off-road.
I took mine in for the brake upgrade because they kept fading/going away and getting limp. After the new parts were installed it was hard as a rock but sucked. One day it stuck on so I had to disassemble the master cylinder and free the stuck piston. Cleaned it all up and still no better. A few days ago I took the caliper apart and both pucks moved freely but were looking pretty bad. The edges were crumbling away like bad concrete. This winter I am rebuilding them, sanding down the rotor and trying to find a set of pads that will actually grab.
EBC, KTM and another brand all sucked. The off brand I bought on ebay was so bad I wore them out in 4k miles and had to replace them on my trip, twice in 8,000 miles! I just tried a set of organics from the front of a MX bike, suck too
When I ride by myself it is tolerable but loaded 2 up gets a bit scarly when you need that extra boost.
Thinking maybe some 80 grit sand paper glued to some old backing plates would be the best route
Michael
mgorman is online now   Reply With Quote
Old 10-09-2012, 07:08 PM   #11
crofrog
Oddometer: 1,376
Keeping digging man. I'd make sure the caliper is floating freely, get the rotor re-cross hatched and stick some oem pads back in there.
My stock 950 brakes will easily lock the rear tire, but with good modulation.
Old 10-09-2012, 07:39 PM   #12
Mttodd
Oddometer: 36
There is adjustment on the pushrod (some). I was looking at an 08 990 and it had an additional adjuster up near the fulcrum to tighten up the whole assembly. Mine doesn't even look similar. Still curious about the improved diaphragm.
Old 10-09-2012, 07:58 PM   #13
Bgunn
Sand seeker
Bgunn's Avatar
Oddometer: 1,101
A fluid change brought my rear brake back to life.
Everybody's on the run
Bgunn is offline   Reply With Quote
Old 10-09-2012, 08:05 PM   #14
Mttodd
Oddometer: 36
Thanks Roughidle for the cpmodem link. I will check to see what I have when I get back to town. Anybody think it would be worth asking KTM or my local dealer to supply one if I do in fact have the original defective version? Apologies to the O.P., did not mean to hijack thread, but this might save others the same headache.
Old 10-09-2012, 09:02 PM   #15
GrenDesb
Oddometer: 197
If you bring your bike in, they have to do the recalls if it hasn't been done. They know from their records if the recall has been done.
GrenDesb is online now   Reply With Quote
Times are GMT -7.   It's 07:46 AM.
