Old 10-02-2012, 03:13 AM   #1
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,069
Carbs overflowing, but not overflowing
Hello!
My new T500 is acting a bit weird. When it is on the sidestand, and I take it off the stand, petrol will run out. If I then put it back on the sidestand, petrol will come out again.
So every time, it is being tilted or raised up, petrol is coming out.
So I guess it is carbs off float bowl clean and the needle area.
What else?
Sendt fra min GT-S5690 med Tapatalk2
Old 10-02-2012, 04:35 AM   #2
lrutt
SILENCE.....i kill you
lrutt's Avatar
Oddometer: 1,419
where exactly is it coming out??? There is a drain hole through the crank case possibly, if like tye T250, where gas can accumulate on top of the motor and when moved could drop down to the bottom. Same with Gas accumulating in the air box.
So you could just have a leaking float boal drain plug, leaking fuel line, as well as possible float / needle problems.
2006 HD 1200C, 2006 Tri Scrambler, 2001 Duc M900, 2001 Hon XR650L, 1994 HD Heritage, 1989 Hon Hawk GT, 1978 Hon CB750K / sidecar, 1977 Guzzi 850 LeMans, 1976 Hon CB750K, 1965 Hon 305 Dream, 1973 Nort 850 Commando, 1971 Tri Trophy 650, 1970 Hon Trail 90, 1970 Tri Tiger 650, 1973 Hon Z50, 1984 Yam Virago 1000, 1981 Hon Passport 70, 1970 Suz T250, 1971 Yam RT1 360, 1965 Hon CT200
lrutt is offline   Reply With Quote
Old 10-02-2012, 09:04 AM   #3
LasseNC OP
XSessive!
LasseNC's Avatar
Oddometer: 1,069
It it coming out of the plastic tube, which is connected to the floatbowl.
Old 10-02-2012, 09:05 AM   #4
2stroke_junkie
Oddometer: 4
From my experiences I say change the needle and seat. I had that problem on my 89 KTM 350
2stroke_junkie is offline   Reply With Quote
Old 10-04-2012, 12:21 AM   #5
Twin-shocker
Oddometer: 1,673
Check that the floats arent porous
Old 10-06-2012, 09:58 AM   #6
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,644
and float height is correct.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is online now   Reply With Quote
Old 10-06-2012, 10:43 AM   #7
victor441
victor441's Avatar
Oddometer: 960
also carry a fire extinguisher until you get it fixed, I had a new to me bike catch fire that way and I was very lucky to be able to put it out with my gloves before I lost it some of the overflow gas was ignited by the alternator wires. FWIW in my case the PO had installed new floats and they were a bit too wide at the pivot, no more overflows after I filed them a bit
victor441 is offline   Reply With Quote
Old 10-09-2012, 08:06 AM   #8
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,160
Shoot carb cleaner through the carb fuel intake tube. It usually cleans out the float nerdle and seat area. Try that before cleaning the whole thing.
Uncle Pollo is offline   Reply With Quote
Old 10-09-2012, 05:07 PM   #9
killfile
49/50
killfile's Avatar
Oddometer: 353
Is this while the bike is running, or not running?
If it happens while it is running, check needles/seats and float heights as previously mentioned.
if it happens while it is not running i would suspect the needles and seats, but your vacuum petcock might also be bad.
what year t500 did you end up getting? is there a picture thread yet?
actually after re-reading your thread, how much gas is coming out? is it constant or just a small amount after the tilt? starting to sound like the float level is just a little off.
Gallery MotoSF & Neoedo
killfile is offline   Reply With Quote
Times are GMT -7.   It's 09:21 PM.
