Old 10-02-2012, 09:21 AM   #91
Spark01
V-Twin
Spark01's Avatar
Oddometer: 306
Originally Posted by olec View Post
So you made an extra pocket on the old baseplate, but it didn't help (too much), and you reaplaced it with the updated baseplate now and then you found more cracks in the old one when removing it? (just to be sure before I order it that there are no more issues with the new one)
No
those pockets where made in the OLD type base plate to have clearance between the plate and the 2nd valve motor and idle speed motor:
http://www.advrider.com/forums/showp...4&postcount=64
Otherwise it would be installed under stress, but the cracks i found where in the tabs not around the pockets.
I installed the new type last week so.. no feedback of strenght issue's. but according Chris from CPR the new plates should be stronger than the old ones.
'10 990SMT
Spark01 is offline   Reply With Quote
Old 10-05-2012, 09:32 AM   #92
Lelos950
KTM 950 S
Oddometer: 12
Dear friends, has anyone tried the CPR air filter on 950 adventure? What is the improvement, concerning throttle responce, horsepower, gas consumption? Is it worth spending money? What other adjustments are required, concerning carburator jetting etc.
Life is an adventure..........KTM 950 S Adventure!
Lelos950 is offline   Reply With Quote
Old 10-05-2012, 09:52 AM   #93
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,806
http://advrider.com/forums/showthread.php?t=786119
Moto Trek'n to New York via the Trans Labrador Hwy, South America
Moto-Treks
moto-treks is offline   Reply With Quote
Old 10-13-2012, 12:23 PM   #94
olec
Rookie
Oddometer: 273
Ordered, received, installed and tested on an '11 990R. Already tuned for motohooligan airbox with K&N, and the CPR breathes quite similar to the old setup. I am happy.
Best part was that it is more quiet compared to the K&N which has this very sharp bark between 4 and 5K. The CPR flattens this out and just breathes with a good base tune.
No bolts and nylock nuts included (as pointed out earlier). The fit could be more precise becaue if you lock one of the quarter turn tabs first, it's very hard to lock the second and vice versa. I think the whole issue is that it's difficult to get the filter enough over to the right side when the lip of the filter goes under that base on the left side. Maybe it will get more play after some more usage, but lets see.
I ordered a baseplate w/o breather hole bc that hose is now just venting to air in front of filter, ending in a filter sock zip tied to the frame.
Cheers!
olec is offline   Reply With Quote
Old 10-14-2012, 10:50 AM   #95
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,029
Question FCR's ???
I have a set of FCR39's to put on my 950 but am not really keen on using the K&N air filter pods that come in the SUDCO kit
Would this filter system work with FCRs? I think that would be the ticket!
That way I won't have to build my own airbox...
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 10-14-2012, 05:53 PM   #96
Johnf3
Oddometer: 1,057
No. Not even close.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is online now   Reply With Quote
Old 10-14-2012, 10:30 PM   #97
blublapp
Oddometer: 19
It will if you build your own baseplate for FCR's....
blublapp is offline   Reply With Quote
Old 10-15-2012, 03:35 AM   #98
Spark01
V-Twin
Spark01's Avatar
Oddometer: 306
It could with a custom base plate
http://www.merlinmotorsport.co.uk/p1...duct_info.html
But i don't know if this base plate has the exact same size like the CPR.
So you also can buy a matching ITG jC30-100 filter.
With filter socks
As used by another inmate:
http://advrider.com/forums/showpost....&postcount=300
'10 990SMT
Spark01 screwed with this post 10-15-2012 at 03:47 AM
Old 10-15-2012, 08:55 AM   #99
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
With filter socks
I made my own for my 950. Its not so hard... In fact, I feel mine is a superior product with a more secure gasket to carb flange mount and its 6061 aluminum, not gonna crack.
If theres anyone with a 990 in NC, I'd gladly help someone make their own.
Sporting Wood is offline   Reply With Quote
Old 10-15-2012, 09:54 AM   #100
howl
990 Adventure
howl's Avatar
Oddometer: 98
I like the idea of making your own Mr Sporting Wood,as 200 for the CRP is a bit steep (bit poor at the moment) Has any one got a template drawing for the 990 they could post ? I'm sure I could fabricate one using a jigsaw and file. Money saved would help pay for DYNO time .Have got the Akra tune, can't need much more fuel surely .
howl is offline   Reply With Quote
Old 10-15-2012, 10:58 AM   #101
geometrician
let's keep going...
Oddometer: 1,029
Cool2 Thanks!
my thoughts exactly...
With filter socks
thanks for the links!
I'm thinking of my own box w/a flat filter on top sourced from catalogs of the filter manufacturers- with airbox volume limited by tank & glovebox (if I keep it) filter surface area is important. I'm sure there are several out there that will fit. Building a custom box will also allow me to direct the air coming in & keep engine/radiator heat from migrating up as much- going to the trouble of the FCRs (TPS, etc) I'd no doubt have a heat blanket/director on top of the engine/below the carb bodies. I could source sheet plastic & heat-weld it together, but then again I have a friend with a huge roll of neglected CF he bought for a small project. I know plastic welding, but getting into making molds, resins/curing agents/etc and ending up with something I'm proud of might be tough since I'm a bit of a perfectionist... all I need is another hobby/skill-set...
been lurking on that thread for a while- enjoy the side-stories & use of alcohol in the shops
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
Old 10-15-2012, 01:21 PM   #102
Sporting Wood
Oddometer: 896
I have a template for a 950
Have a couple buds with 990's but it'll be a while till I can get my paws on their bikes.
FWIW, I don't really think this particular filter is really all that and a bag 'o chips. Works and its a pretty decent compromise, but the fit is pretty tight/ weird and it routes air mostly right above the velocity stacks. Way...WAY better than living with the airbox but I'm thinking single UNI's might be just as good and a bunch easier... though the problem of attaching them well remains. Back in 2007 I ran some single K&Ns that worked great... but I ride a lot of dust and had them simply zip tyed to the carb intake w/o the velocity stack. Put the box back on eventually.
One observation, water from rain likes to roll down between the glove box and the seat, soaking the top of the filter just above the rear intake. It'd be wise to weatherstrip the gap or cover it when it rains.
Sporting Wood screwed with this post 10-15-2012 at 01:57 PM
Old 10-17-2012, 08:11 AM   #103
howl
990 Adventure
howl's Avatar
Oddometer: 98
Thank you for reply ,single UNI's sound a better idea if they could be attached ,like you comment about the rain ,we get quite a bit if that in England ,could fabricate somthing to cover that gap under the seat may be.
Old 10-19-2012, 11:50 AM   #104
Spark01
V-Twin
Spark01's Avatar
Oddometer: 306
But i don't like the new routing of the crank case breather, as i still have the 2nd valve motor inplace.
The hose is pushing against the front injector connector and the connectors of the 2nd valve motor.
So i removed the hose and sealled the hole with a bolt and 2 washer with some rubber seallant inbetween.
And ordered a small crankcase breather filter to put on the hose.
i think this also will help for lowering the intake temp some degrees. because the warm fumes from the crankcase will no longer enter in the airfilter.
Finally the crank case breather came in (K&N 62-1110) and i installed it with a self made bracket to the rear throttle body:
Hose routing:
'10 990SMT
Old 10-29-2012, 01:19 PM   #105
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,806
Filter cleaning
Cleaned the Rottweiler the other day after about 2K mile of use. It was a bit dirty
But totally clean inside
A simple wash and re-oiling with some no-toil filter oil and it as good as new.
Moto-Treks
Times are GMT -7.   It's 02:27 PM.
