Old 10-08-2012, 01:42 PM   #31
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,907
Correct, not top left, top right side access to the vent tube.
Air cleaner, air box, same thing effectively.
bottom right.
Jim
Old 10-08-2012, 06:12 PM   #32
Bender OP
I can pass this guy.
Bender's Avatar
Oddometer: 36,367
Didn't have a lot of time to mess with it today. But I did pull the plug out of the airbox and got a couple drops of oil. Unusual?
Bender™
Bender is offline   Reply With Quote
Old 10-08-2012, 06:31 PM   #33
JimVonBaden
"Cool" Aid!
Oddometer: 52,907
Nope, a couple drops is normal.
Jim
Old 10-09-2012, 12:53 PM   #34
Pekkavee
Oddometer: 327
Originally Posted by JimVonBaden View Post
One other trick is to use electrical tape and tape the old one to the new one to help keep them lined up. Once it is going in, the tape will come off on its own.
Jim
Nice tip-. Thanks.
Pekka
Pekkavee is offline   Reply With Quote
Old 10-13-2012, 08:23 AM   #35
Bender OP
Bender's Avatar
Oddometer: 36,367
Ok, I believe that PVC hose comes out of the crankcase just aboput the tele-lever pivot point? If so, I found it. The PVC hose was supple and still rubber-like. Not hard and cracking.
Took the seat off and nosed around a bit. Checked the air cleaner and found no traces of oil on it, but there is a thin film of oil underneath it on the bottom of the airbox. This leads me to believe that I am not fighting a worn-out engine. I kinda think that if it was compression getting past the rings that there would be oil all over the airbox. Correct?
I am seriously not wanting to start tearing into this thing to get the airbox off to check that PVC hose, so I am thinking that maybe I can rig up an adaptor to run about 15psi of compressed air into the oil filler hole to see if it holds pressure, or if it flows as it should.
How bad is that last idea? Will I screw something else up if I try this? And if it vents this pressure, what else do I need to check?
Bender™
Old 10-13-2012, 05:20 PM   #36
Bender OP
Bender's Avatar
Oddometer: 36,367
Really?
Bender™
Old 10-13-2012, 05:38 PM   #37
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,878
I wouldn't use 15psi. Better might be to blow gently into the breather hose from the airbox end. I'd do a leakdown test on the cylinders too.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 10-13-2012, 05:48 PM   #38
AndyCap
Mineral Oil Anyone?
AndyCap's Avatar
Oddometer: 1,469
There is an article in the Hall of Wisdom.
The link to that article is here -> http://advwisdom.hogranch.com/Wisdom...eplacement.pdf
That article references this thread -> http://advwisdom.hogranch.com/Wisdom...eplacement.pdf
Hope that helps.
2004 R1150GSA, 2000 BMW R1150GS, 2008 KTM 950R SE, 2001 Honda XR400R, 2003 Honda XR100R
Another Proud Small Scale Faker......
New England Pie-O-Rama
ADV Pie Map
AndyCap is offline   Reply With Quote
Old 10-14-2012, 05:03 AM   #39
Bender OP
Bender's Avatar
Oddometer: 36,367
I have got the replacement thing down pat.
I am trying to figure out why I have popped two oil sight glasses out in a matter of about 5 miles.
Bender™
Old 10-14-2012, 06:24 PM   #40
JimVonBaden
"Cool" Aid!
Oddometer: 52,907
I highly doubt you have excessive crankcase pressure. If you did you would have leaking seals all over the place. I suspect wither you have gotten a bad sight glass, or your sight glass hole is somehow out of spec.
What I would suggest is that you install a new one, drille some safety wire holes around it, and safety wire it in. This has been done successfully before.
Jim
Old 10-14-2012, 06:48 PM   #41
Bender OP
Bender's Avatar
Oddometer: 36,367
As in just strap it down so it doesn't blow out?
Bender™
Old 10-14-2012, 07:55 PM   #42
JimVonBaden
"Cool" Aid!
Oddometer: 52,907
Basically cross the glass with safety wire.
Jim
Old 10-15-2012, 02:55 AM   #43
Bender OP
Bender's Avatar
Oddometer: 36,367
Ok, that's what I thought you meant. Thanks.
Bender™
Old 10-15-2012, 08:23 AM   #44
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,187
Is the BMW boxer oil site glass actually made of glass?
The clear window on mine appears to be plastic.
def is offline   Reply With Quote
Old 10-15-2012, 10:43 AM   #45
Mike Ryder
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 985
My 2002 oil sight glass was plastic. The new one is glass.
Yes I am quite serious.
Mike Ryder is offline   Reply With Quote
Times are GMT -7.   It's 02:55 PM.
