Old 08-29-2012, 04:48 PM   #31
Navin OP
Navin's Avatar
Oddometer: 7,657
Originally Posted by Navin View Post
I wish I had measured them as delivered now!
I'm pretty sure they were close to 9mm before and they were stalling like crazy diving into corners off road. They were definetly higher than they are now. I now know 16mm is too low. If it doesn't stall at 12, it'll stay there. I'll move 1mm at a time now if I have to go to less fuel again.
I just had her in the woods and did a few dozen brake slides into corners off of fast WOT straights, NO STALLS!!!
Next to cure the off idle lag it has for a few hundred RPMs in the basement and smooth out the hit after it. H2W says a JD kit cures it and I'll do that mod next. For now I figured out how to ride around it, man this thing rips now! I need to get it in the deep SNJ sand!
Navin is online now   Reply With Quote
Old 10-15-2012, 03:12 PM   #32
Navin OP
Navin's Avatar
Oddometer: 7,657
So, ran her hard in the deep NJ sand today. Not impressed again. I got these to cure the CV stalling in whoops, but, while better, they still get sloppy in deep, nasty whoops while skimming. Everytime it took a hard hit it would drop power causing the bike to drag, start skidding and swapping. Ridden at 60-70% it is fine. Start bottoming the suspension and all bets are off.
Another SE rider with FCRs was having the same symptoms. I have a vac FP, he a facet so that didn't seem to matter.
Street use they rock. At a DS pace they are great, race pace in turns the bike explodes out like a missle but wick it up in whoops and they flubber.
So, anyone using a FPR with FCRs?
Old 10-15-2012, 11:50 PM   #33
kamanya
Andrew to most
kamanya's Avatar
Oddometer: 1,302
I too was surprised when it did it to me the first time. They are better than the CV's but like you say, still do act up.
I'm wondering what the actual cause is? Is it the high G's that cause the floats to sit lower and so stay open thus causing the overly rich running?
It seems to me that whoops cause it to run very rich. I had a guy behind me once who thought my bike had caught fire, when the bike finally stalled flames were coming out the exhausts.
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost
kamanya is offline   Reply With Quote
Old 10-15-2012, 11:59 PM   #34
bikerbilly
throwing a leg over
bikerbilly's Avatar
Oddometer: 119
have any of you guys tried lowering the float level??????
cheers, Bill..
2012 Husaberg FE 570................2004 KTM Adventure 950
bikerbilly is offline   Reply With Quote
Old 10-16-2012, 01:05 AM   #35
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,832
don't know much about them but Would the R&D power II bowls help or the Power Pump II ?
have you had a chat with Eddie Sisneros on thumperTalk
http://www.thumpertalk.com/user/5904-eddie-sisneros/
he is a guru for the FCR's & in the past found him very helpful. it never hurts to ask.
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 10-16-2012, 09:38 AM   #36
Navin OP
Navin's Avatar
Oddometer: 7,657
My floats are as low as I dare to run them at this point. I'm thinking the slant and depth of the bowls is the cause too. My MX FCRs never miss a beat.
Old 10-16-2012, 10:15 AM   #37
max2
max2's Avatar
Oddometer: 217
I wonder if there is a way to build a spring loaded needle and seat...kinda like the Holley Carbs when used for off-road
http://www.holley.com/6-513.asp
2007 Super Enduro...Finally got another one & 2008 Kawi KLX 450 - Plated
2010 KTM 690R - Sold
2006 BMW R1200GSA - SOLD...Thank Goodness...I hated that thing.
2007 KTM Super Enduro - Sold - HUGE Mistake letting it go
2006 KTM Adventure S - Sold / 2007 KTM 950 Supermoto - Sold
max2 is offline   Reply With Quote
Old 10-16-2012, 10:19 AM   #38
Navin OP
Navin's Avatar
Oddometer: 7,657
I think it needs a fully baffled bowl.
Mine is either gonna sell or be retired into DS/street use only. I may have to weld on the passenger pegs to keep myself from trying to race it in the future but I'm really committed to ending my last few semi fast years of racing on a proper small bike.
Old 10-16-2012, 11:34 AM   #39
Mr. Canoehead
Taste Gunnels!
Mr. Canoehead's Avatar
Location: Calgary, Too far to the mountains and too cold
Oddometer: 1,520
Maybe you could do a 990 injection swap!
2006 FJR1300A, 2005 GS1150 Adventure, 2002 DR650 SE, a fortune in Farkles.
"No matter how many [internet] opinions you line up, you can't vote nonsense into truth"- Kevin Cameron
Mr. Canoehead is offline   Reply With Quote
Old 10-16-2012, 11:36 AM   #40
Navin OP
Navin's Avatar
Oddometer: 7,657
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOO!!!!!!!
I could never after blasting Crankshaft about his FI exploits!
Old 10-16-2012, 11:48 AM   #41
Yardstick
Hydrophobic
Yardstick's Avatar
Oddometer: 3,012
I haven't read the whole thread here, but the few posts I have read made me think that same thing! I have been thinking about it for mine. Shortly after I got my SE (new) I took it on a ride with some steep hills and rough terrain. It was scary when it would just flood out on long, steep downhills or stumble in the rough. I'm super happy with the EFI on my 990 R.
Yardstick is offline   Reply With Quote
Old 10-17-2012, 01:12 PM   #42
azdrhill
AZ offroad rider
azdrhill's Avatar
Oddometer: 116
Try this for cold weather starting help
I put a Euro headlight switch on my '05 Adventure so I could have the headlight shut off while starting. Added a little more latitude for cold weather cranking...
Adventurers Workshop sells them.
azdrhill is offline   Reply With Quote
Old 10-17-2012, 01:20 PM   #43
Mr. Canoehead
Taste Gunnels!
Oddometer: 1,520
Are they still in business? I heard they took a bunch of orders and shut down. If you got an order filled, you did well.
Old 10-17-2012, 01:54 PM   #44
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,964
We have those on our bikes, and it helps. We stock those.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 10-17-2012, 02:35 PM   #45
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Eek Yikes
At $500 retail for the two carbs that is an expensive fix!
I do think the totally horizontal position of the carbs has a lot to do with bogging problems, and yes I think float bowl baffles would help
The Power Bowl 2's work well on the KTM singles
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Times are GMT -7.   It's 07:44 AM.
