Old 10-15-2012, 07:02 PM   #1
CosentinoEngineering OP
Oddometer: 184
Billet FCR Velocity Stacks
Cosentino Engineering is proud to announce the release of its Billet FCR Velocity Stacks kit for Keihin 39 and 41mm FCR carburetors. The billet aluminum velocity stacks replace the standard aluminum Sudco filter mounts or the plastic or spun bellmouth of various lengths they also sell. The kit includes 2 anodized velocity stacks, matching K&N air filters and the recommended jetting sizes.
These velocity stacks are a bolt on accessory dyno tested to provide significant mid-range torque and increased top end power when compared to the standard filter mounts. The following dyno charts are for a KTM 950 tested on a Dynojet 250 dyno.
Rarely do bolt-on engine modifications result in such a clear-cut improvement over the entire operating range! These velocity stacks were designed to provide the proper intake port length to maximize cylinder filling and to incorporate the largest K&N filter possible, thus minimize pumping losses by providing more than double the filter area for the engine to breathe through. The result is 3.5Hp more peak power, nearly 4ft-lbf more torque across the entire rpm range, and 7% better economy! Increased throttle response and decreased front tire wear are important side benefits. The first test ride by Flanny was stopped before completion due to a serious case of acute torque intoxication. He may never recover.
This modification makes any carbureted 950 comparable with the latest 990 injected bikes. This dyno chart shows Flanny's carbureted bike compared to Gino's new fuel injected 990R with an aftermarket exhaust and modded ECU map. The 950 loses a small amount of top end power to the new FI model but still has significant mid-range gains: the place where most riding is done. Another benefit is the super smooth torque curve when compared to the lumpy FI version. If you want the top end power, a set of 41mm FCRs instead of 39s would bump up the maximum power with only a small reduction in midrange torque.
For those who already have a 990R with fuel injection there are large midrange gains to be made by stripping off the FI setup and retrofitting FCRs fitted with this kit. We tested sakurama's bike, which is a 990 FI engine that has 39mm FCR carbs. It compared very nicely to Gino's FI bike, only losing a bit of power on the top end. A set of 41mm FCRs would add a bit of top end making it a tough choice to keep the FI or go with a simpler and more reliable carburetor.
There are some pictures and videos of the testing process on the last few pages of sakurama's '950 Refresh' thread. Velocity stack length and jetting were varied until we got the best combination of wide power spread, good peak power, and stable air/fuel ratio.
The complete kit, including 2 velocity stacks, matching K&N filters, jetting, and an instruction manual, costs $469 + shipping. The kit fits under the stock KTM seat and requires no mods to the bike. The velocity stacks are available in an anodized black or KTM orange finish. Because the ADV list is one of the best online destination for motorcyclists we're giving a 10% discount to any ADV member. Just PM me and we'll send you a paypal payment request for the discounted amount.
We are currently developing kits for other motorcycles that use the FCR carb as an upgrade. Likely candidates are air cooled Ducati twins and the SV series from Suzuki. If you have a bike with FCRs that you think is not performing optimally, give a call and maybe we can develop a suitable kit to release its potential.
We will also be expanding our product offering to include complete carburetor kits prejetted to the specific application and fitted with our custom velocity stacks, low tension throttle return springs and TPS sensor brackets.
Check in for updates.
Chris
moto2-usa.blogspot.com
Check out my products 10% off for ADV rider members
CosentinoEngineering is offline   Reply With Quote
Old 10-15-2012, 08:42 PM   #2
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,974
Looks Great Chris.
I rode Flanny's bike. Very nice, but the Throttle pull was crazy. Interested to see what you come up with for a fix for that.
That along with the TPS sensor mount are some of the things holding me back from putting the set on the 950 SE.
Keep us posted,
Craig
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 10-16-2012, 04:54 AM   #3
kamanya
Andrew to most
kamanya's Avatar
Oddometer: 1,319
You have a PM
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost
kamanya is offline   Reply With Quote
Old 10-16-2012, 05:28 AM   #4
Flanny
Flanny-it-up!
Flanny's Avatar
Location: Ottawa, Ontario, Canada, the World, the Universe
Oddometer: 2,738
Good stuff Chris...
It will be a better world with everyone riding around all high on torque!
B.
Flanny is offline   Reply With Quote
Old 10-16-2012, 12:05 PM   #5
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,122
Watching the development and the results of your work was very enjoyable. Will they fit under my 950SM fuel tank?
Can't wait to place an order!
snowhawk jockey is offline   Reply With Quote
Old 10-16-2012, 12:19 PM   #6
Oddometer: 184
Thumb
Thanks, lots of fun, especially when it all works better.
Probabaly. Where is the stock airbox relative to the upper frame rails? If you post a pic of the bike without the tank on and the underside of the tank I can tell you for sure.
Chris
Old 10-16-2012, 12:28 PM   #7
Oddometer: 184
>I rode Flanny's bike. Very nice, but the Throttle pull was crazy. Interested to see what you come up with for a fix for that. That along with the TPS sensor mount are some of the things holding me back from putting the set on the 950 SE.
Hopefully you won't be held back for long. Will test springs and hopefully finalize the TPS mount this week.
Chris
Old 10-16-2012, 12:35 PM   #8
snowhawk jockey
Slack Jaw Gaper
Oddometer: 1,122
I'll see if I can come up with a pic of that. I have the FCR's installed and the box is off.
Old 10-16-2012, 01:25 PM   #9
Oddometer: 184
That may be easier. The filters protrude about 6 3/8" from the munting flange of the carb body and need clearance for about a 3 1/2" diameter filter top that tapers as it approaches the carb to 4 1/4"
Chris
Old 10-17-2012, 08:28 AM   #10
PS-RagE
PS-RagE's Avatar
Oddometer: 648
I'm in!
The kit does include the jets, yes?
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
2014 KTM 1190 Adventure R
PS-RagE is offline   Reply With Quote
Old 10-17-2012, 10:56 AM   #11
Oddometer: 184
Yup. Recommended jet sizes are 155 for the 950 and 168 for the 990 and are provided.
Just finishing up the TPS adaptor and will machine the first samples over the next couple of days.
Chris
Old 10-18-2012, 02:42 PM   #12
max2
max2's Avatar
Oddometer: 219
Sounds great..also waiting to hear about the throttle spring....any word on a choke system?? I hear they are a bear to start when cold/
2007 Super Enduro...Finally got another one & 2008 Kawi KLX 450 - Plated
2010 KTM 690R - Sold
2006 BMW R1200GSA - SOLD...Thank Goodness...I hated that thing.
2007 KTM Super Enduro - Sold - HUGE Mistake letting it go
2006 KTM Adventure S - Sold / 2007 KTM 950 Supermoto - Sold
max2 is offline   Reply With Quote
Old 10-18-2012, 03:14 PM   #13
PS-RagE
PS-RagE's Avatar
Oddometer: 648
Ooh! I'd like a choke too please!
A. Dale McLean
aka PS-RagE
2007 Beta REV3 270
2012 KTM 350 EXC-F
Old 10-18-2012, 04:34 PM   #14
Oddometer: 184
Throttle springs are in progress. I tried to wind some samples on my simple spring winder but couldn't get an acceptable result so I ordered a few samples in different wire sizes from the vendor that makes the springs for my vintage fork upgrade kit.
The choke is also in progrsss, the aim is to make something that uses the stock KTM clutch master cylinder choke lever and maybe the stock KTM choke cable too. It may need some carb machining so would require the carbs to be sent to me. I'll try to avoid that but it may be unavoidable.
Chris
Old 10-19-2012, 10:11 PM   #15
sakurama
on an endless build
sakurama's Avatar
Oddometer: 1,495
Hey Justin, I am 98.2% sure they will from my recollection of your bike at the Bend rally. Our prototypes just fouled Flanny's seat (back carb) and we cut a sliver out of the plastic but Chris redesigned them to set the filter lower down over the bell mouth so they should be within the stock airbox dimensions.
I really want to hear what you think when you get them installed. You may end up a bit fatter with your 41's so getting the chance to jet on a dyno would be helpful especially with your own exhaust. If you do be sure to get some before and after graphs. I know you rip on that bike so I'm looking forward to your impressions.
Gregor
sakurama is offline   Reply With Quote
Times are GMT -7.   It's 07:42 PM.
