Old 10-19-2012, 02:46 PM   #61
zaner32
In over my head
zaner32's Avatar
Oddometer: 621
Thanks to Oso Blanco for this. I'll have to do mine in the spring. I did miss something though... Can the races be bought with the bearings? Anyone have part numbers for the races?
97 DR350SE
09 F800GS
"When nothing goes right, go left!
zaner32 is offline   Reply With Quote
Old 10-19-2012, 03:29 PM   #62
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 6,046
Races are included with the bearings. The only other thing you'll need to buy is the lower bearing dust cover, a BMW part which should only be about $5. The one in the bike usually gets buggered up (technical term) when you remove the bearing.
"Don't play a lute to a cow" (Old Chinese Idiom)
Old 10-20-2012, 11:51 AM   #63
betitolara
ADV rider wannabe
betitolara's Avatar
Oddometer: 734
I managed to not bugger-up the bottom dust cover following the instructions from post #21. It took me 20 minutes of careful doing but didn't have to go to my local dealer for a $5 cover (for me, it's a 3 hr roundtrip to the dealer and a $30 ferry)
My bike feels 'normal' again
betitolara is offline   Reply With Quote
Old 10-20-2012, 07:10 PM   #64
zaner32
In over my head
zaner32's Avatar
Oddometer: 621
97 DR350SE
09 F800GS
Old 02-26-2013, 04:38 AM   #65
leadingedge
Trailing along...
leadingedge's Avatar
Oddometer: 32
Thanks a million for the illustrated step-by-step.
Replaced mine today at 11000km, totally notched....too many wheelies I guess.
I used NTN bearings, MUCH cheaper than buying from BMW. My bearings only cost me US$15...for BOTH of them.
I also managed to save the dustcap by using a 4mm drift punch. It made 2 little holes in the dustcap, but I just rotated it a little bit and re-installed.
Thanks again for the post!
leadingedge is offline   Reply With Quote
Old 03-17-2013, 07:03 AM   #66
chinchinete
Learning to fly
Oddometer: 34
Big Hurray!!
Thanks Oso Blanco and the rest for posting this DIY. Getting the lower bearing was a bitch: the two holes did not work and end up using Oso Blanco's chisel technique . Used NSK HR 320/28 XJ at $30 each. It is crazy expensive here in Central America.
Cheers
chinchinete is offline   Reply With Quote
Old 03-17-2013, 08:21 AM   #67
Reaver
Amusing Myself Again
Reaver's Avatar
Oddometer: 605
Tips and Tricks
A belated "thanks" to all here. I did mine over the winter along with a fork oil change. My bearings were well greased and without rust but were bad enough to cause low speed steering problems while wrestling it out of the notch to maintain balance.
On that note, I have saved myself much time and $ by using a little trick. My GS Dakar was sold certified and had a steering notch I knew wouldn't pass. An inspection showed lots of grease and no rust so I turned the upper bearing one way a few degrees and the lower the opposite. This reduced the notch by half and placed it well to the sides of steering range. I now had two minor notches, one each way well away from centre. Passed no problem. I then did the same to my new to me F8 for cert. They lasted another 30K kms. The goal is to remove the notch to prevent steering issues so along with regreasing, a little turn will spread the wear out extending the life of the bearings. This'll get you more time to plan for the eventual change.
YMMV
Life is a rollercoaster........and I'm not strapped in!
Reaver is offline   Reply With Quote
Old 04-05-2013, 08:07 PM   #68
Chop Chop
Mr Wiggles
Chop Chop's Avatar
Oddometer: 1,418
Just about to do my head bearings. As an aside, would you consider that the torque figures BMW are using are too tight and hence putting too much crush on the bearings causing early failure? Just something a mech mentioned to me as he has changed a few out.
Really just like doing nothing with no one.
Chop Chop is offline   Reply With Quote
Old 04-05-2013, 09:15 PM   #69
MikeMike
MikeMike's Avatar
Oddometer: 2,575
I dont think so, seems more like undersized, poor quality and/or lack of grease at Spandau and the dealers.
Those same things can crate a perfect storm for the career of a porn actress, too.
Old 04-06-2013, 09:17 AM   #70
Reaver
Reaver's Avatar
Oddometer: 605
[QUOTE=Chop Chop;21120325. As an aside, would you consider that the torque figures BMW are using are too tight and hence putting too much crush on the bearings causing early failure? [/QUOTE]
I highly doubt it. Bearings that are too tight cause stiff steering and you'd complain endlessly before wearing out the bearings.
If you lived to tell about it.
Build it as cheap as possible and get it just a hair past warranty. Make minor adjustments in quality as required.
Old 04-13-2013, 06:04 AM   #71
JRWooden
Oddometer: 3,480
F800GS uses diff. P/N than F658GS?
In another thread someone pointed out that the F800GS uses diff. P/N than F658GS ... I just looked at the Max BMW website and it is indeed a different P/N called out for the 650-twin...
Why the hell would that be the case?
Parts catalog in transition?
JRWooden is online now   Reply With Quote
Old 04-13-2013, 06:50 AM   #72
MikeMike
MikeMike's Avatar
Oddometer: 2,575
They probably changed bearing suppliers and prices.
Perhaps they are beginning to consolidate the parts catalog like the newer long snout oil filters as opposed to the previous stubby ones. The new ones are used on a number of different models. More parts shelf space for dealers to stock the Mini car fashion accessories like handbags, watches, lighters, and sunglasses.
You can get a BMW water bottle but you might wait 3 days for an air filter.
Old 04-13-2013, 09:41 AM   #73
JRWooden
Oddometer: 3,480
Originally Posted by MikeMike View Post
... You can get a BMW water bottle but you might wait 3 days for an air filter.
Old 04-15-2013, 12:26 PM   #74
Mongo357
Mongo357's Avatar
Oddometer: 65
All Balls
All Balls now has kits for the F800gs.
Steering Head Bearing kit (including two dust caps, one extra)
http://www.allballsracing.com/22-1024.html
Front Wheel Bearing / Seal Kit
http://www.allballsracing.com/25-1647.html
Fork Oil Seal & Dust Seal Kit
http://www.allballsracing.com/56-149.html
I went for all of them - gonna need them sooner or later.
Mongo357 is offline   Reply With Quote
Old 04-15-2013, 02:57 PM   #75
jengel451
1 Cool MotherF#$cker
Oddometer: 155
Good luck with All Ballz, I tried them a few times for my dirtbikes since they were a good price etc. Ended up spending the money Anyway as they didn't last. Especially their wheel bearings. They burn up real good.
jengel451 is online now   Reply With Quote
Times are GMT -7.   It's 10:19 PM.
