Old 10-09-2012, 09:05 AM   #46
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
Engine cleaned
and installed:
Pablo83 is offline   Reply With Quote
Old 10-09-2012, 03:58 PM   #47
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
Getting close:
Old 10-10-2012, 07:42 AM   #48
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
Done...
Old 10-10-2012, 10:07 AM   #49
solorider40
solorider40's Avatar
Oddometer: 697
Nice!!!!
WoW! That turned out really nice!!! Good Job
CMA#112674
AMA#1080306
2008 KLR650E
2001 KE100 (daughters bike)
1983 IT250
solorider40 is offline   Reply With Quote
Old 10-10-2012, 11:35 AM   #50
Iron_HawK
Farkle Enthusiast
Iron_HawK's Avatar
Oddometer: 52
Very Nice work Pablo! Looks great The black stripe really sets off the gray. Keep the pictures coming!
F=m*a
1981 Suzuki GS450L Cafe Racer - Build Thread
Iron_HawK is offline   Reply With Quote
Old 10-12-2012, 09:15 PM   #51
STROMVADER
STROMVADER's Avatar
Oddometer: 2,100
What a beautiful build! That bike turned out great! You have some serious skills my friend.
You only LIVE once. Make it COUNT.
F*CK CANCER
Godspeed Dad! RIP 1944-2010
STROMVADER is offline   Reply With Quote
Old 10-12-2012, 09:40 PM   #52
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
Thanks guys.
I got some exhaust wrap for the pipes.
And some race numbers
Old 10-13-2012, 04:57 AM   #53
radianrider
Adventurer wanna'be
radianrider's Avatar
Oddometer: 475
So what is your impression of the bike as a rider?
radianrider is offline   Reply With Quote
Old 10-13-2012, 08:09 AM   #54
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
The bike is a blast to ride. I ride it every chance I get.
Problems:
Initially the pipes were putting too much heat into the engine. The pipe wrap has helped and I've also built a small heat shield for the carb which I will post soon.
I still don't have the jetting completely worked out, but I'm getting close. My final jetting should be 45 idle, 137.5 main (at 9000 ft elevation).
The gas tank slips out of position. I need to redesign the rear bracket on it.
The rear wheel is a 16" which is real hard to find good rubber for. I'm currently running a D606 which isn't all that good for dirt, but I recently siped it and that helps.
It's sluggish when starting from a stop. I believe this is due to the carb slides not opening quickly enough and the heavy flywheel not disengaging quickly enough. When I get the proper tools, I plan on removing the dual mass portion of the flywheel and seeing how the bike performs. Right now the bike is most fun to ride at higher RPMs so I end up blasting through town on the thing which leads to the final issue I have with it:
It's stupid loud. I'll post a video soon. You'll notice in the video you can hear the bike before you can see it. The ID on the mufflers is much bigger than the ID on the headers so I hope to modify the pipe internals this winter and put a small ID perforated pipe in the muffler so I have more room for baffling.
Old 10-13-2012, 08:12 AM   #55
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
Old 10-13-2012, 11:30 AM   #56
radianrider
Adventurer wanna'be
Oddometer: 475
Originally Posted by Pablo83 View Post
Stupid loud is about right! If you zoom in on the video you'll see a guy way out in the valley with his fingers in his ears! Cool video!
Mine is never sluggish from the start--quite the opposite. Very easy to get rolling and up to speed.
Old 10-13-2012, 09:12 PM   #57
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
Here's the heat shield I built for the carb.
First I made it out of cardboard
And fit it up
Then cut it out o 18ga steel, bent it to shape, and fusion welded some extra metal to the mounting tabs.
punched some holes
and trimmed it to fit
It installs nicely
Old 10-21-2012, 12:51 PM   #58
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,809
Old 10-21-2012, 04:55 PM   #59
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,394
Were you part of this?
http://www.advrider.com/forums/showthread.php?t=830968
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 10-21-2012, 06:24 PM   #60
brucifer
brucifer's Avatar
Oddometer: 2,440
Pablo, i love those pics! lol. What's the story here?
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is online now   Reply With Quote
Times are GMT -7.   It's 09:52 AM.
