Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 10-10-2012, 12:58 PM   #91
Padmei
enamoured
Oddometer: 3,719
Prob nothing to do with benellis & you prob have seen this kind of setup but check out the cam disc thing of this bike & the video of this lil bike engine running. Very cool I think
http://advrider.com/forums/showthread.php?t=832569
Padmei is offline   Reply With Quote
Old 10-11-2012, 01:31 AM   #92
innathyzit OP
AKA Woodman
innathyzit's Avatar
Oddometer: 1,159
Thats pretty cool, got the same carby as the Benelli. The old man has an old Ducati motor in his shed that has pull rods rather than push rods which is a bit odd. Remember trying to make a renault v6 into a race motor for a boat but the limiting factor would have been the exhaust and inlet valves used the same cam lobe for both and getting a decent enough valve lift and duration etc was nigh on impossible so it was scrapped.
Theres some odd things out there
innathyzit is offline   Reply With Quote
Old 10-12-2012, 05:44 PM   #93
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,656
does it look like this
Your old mans shed sounds interesting.....any pics
Voltaire is offline   Reply With Quote
Old 10-12-2012, 08:53 PM   #94
innathyzit OP
AKA Woodman
innathyzit's Avatar
Oddometer: 1,159
Can't remember what it looks like, but it is an engine that you bolt onto a bicycle. Dunno what year it is.
Old 10-12-2012, 10:49 PM   #95
Eddieb
Eddieb's Avatar
Oddometer: 999
It would likely be one of those motors then, as that's what they were manufactured for.
Eddieb is offline   Reply With Quote
Old 10-13-2012, 02:26 AM   #96
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,656
wanna swap it it for a Garelli one?( obviously not as good as this and all in bits...)
Voltaire screwed with this post 10-13-2012 at 02:27 AM Reason: glenfiddich induced spelling errors
Old 10-20-2012, 10:22 PM   #97
Eddieb
Eddieb's Avatar
Oddometer: 999
Here's my project I've slowly been getting bits for. I'm very tempted to clear coat the tank and use that as is.
Sent from my GT-I9100 using Tapatalk 2
Old 10-21-2012, 02:13 PM   #98
innathyzit OP
AKA Woodman
innathyzit's Avatar
Oddometer: 1,159
Looks good Eddie. Tis amazing when searching online the amount of common parts that Ducatis/Benellis etc share. Your front brake looks same as mine. Is that a SS1 carb?
Have you tried Guzzino for parts? Very good and have a lot of NOS stuff. Do you have an ETA for completion or is it a rolling target?
Have to take my engine out today and do some cutting and welding of the frame to make a bracket to mount the rearsets on. Fortunately engine removal is a less than 5 minute one man job. Advantage of having no lower frame.Oh yeah also got an adjustable main jet and one folding rear set footpeg. Was meant to order two Doh.
Old 10-22-2012, 02:38 AM   #99
Eddieb
Eddieb's Avatar
Oddometer: 999
Is that a SS1 carb?
It's been a rolling target but I collected most of what I needed this year and am hoping to spend some quality time on it next year.
Old 05-03-2013, 02:31 PM   #100
innathyzit OP
AKA Woodman
innathyzit's Avatar
Oddometer: 1,159
Oh yeah, forgot about this.
Now where did I put it?
Old 05-03-2013, 03:46 PM   #101
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
How waterproof was it?
NordieBoy is offline   Reply With Quote
Old 05-03-2013, 05:34 PM   #102
Padmei
enamoured
Oddometer: 3,719
I saw it floating out the estuary last weekend. should be good till the tyres start losing air
Old 06-07-2013, 03:35 PM   #103
innathyzit OP
AKA Woodman
innathyzit's Avatar
Oddometer: 1,159
More rainy days now so starting again. made a stand to get it up to a decent height, ordered some parts from Germany and done way too much internetting to get ideas.
How do you cure scope creep?
Cool pic of a benelli granp prix 250cc singles timing gears. Did they not have chains back then? Upside down for some reason.
innathyzit screwed with this post 06-07-2013 at 03:42 PM
Old 06-07-2013, 03:37 PM   #104
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,656
is that like underhead cam?
Old 06-07-2013, 03:45 PM   #105
innathyzit OP
AKA Woodman
innathyzit's Avatar
Oddometer: 1,159
Fcuked if I can spin the pic around. Just hold your screen upside down.
Times are GMT -7.   It's 08:13 PM.
