10-22-2012, 09:46 AM
#1 |
Oddometer: 2,825
How to make your own F800GS Carbon Fiber Fork Sliders......
So..... along with the other projects......
http://www.advrider.com/forums/showthread.php?t=678072 And this set...... Which was made up at a local hose maker for US$ 120.... I was at a go. ![]() So I wanted to make a set of fork sliders......MX style, rather than hack the low fender. First I tried to form a piece of lexan..... and while it would have worked fine functionally, It did not look as good as I wanted. ![]() So onward with a sheet of 24 gauge steel...... Marked 12x5 inches. When I make things from scratch, I always try to.....uhhhhmmmm... make it from scratch, as not to "reform" others products. That keeps me in the clear, if I ever sell any parts. Copyright laws allows you to make sets for your self, but once you sell further copies, you open yourself up for exposure. ![]() Cut to shape..... ![]() ![]() Bend it on a SS tube, and installed, and drilled the holes, while fit the abs sensor........ Acceptable.....????? ![]() ![]() ![]() ![]() These will then serve as templates, for a Carbon Fiber mould...... Should be short work...... ![]() ![]()
Erling |
10-22-2012, 10:17 AM
#2 | |
Oddometer: 760
http://www.motocross-atv.com/Lightsp...p/667-1587.htm I currently run an MX style brake lines and had to screw in the pinch clamp on the right fork. But I would much prefer to have the tab molded in like all the left fork gaurds. |
10-22-2012, 11:32 AM
#3 |
b00b
Oddometer: 172
Awesome.
10-22-2012, 11:44 AM
#4 |
Oddometer: 2,825
Thanks..... Could be..... But I will have to see how it sits, as the line would add stress to the equation. We shall see.....
Erling |
10-22-2012, 11:45 AM
#5 |
Oddometer: 2,825
Erling |
10-22-2012, 11:47 AM
#6 |
Oddometer: 2,825
All set up, and ready for hardware casting...... Note the outer and inner rings, and Brake line guides...... A quick and dirty dual sided moulding for hardware.....
Erling |
10-22-2012, 01:00 PM
#7 |
Oddometer: 232
I have a better idea. Make 'em for the DRZ (S version). You'll get rich selling 'em, and I'll be your first customer.
MSF RiderCoach 2012 BMW F800GS Trophy 2011 Suzuki DRZ-400S |
10-22-2012, 01:05 PM
#8 | |
Oddometer: 2,825
![]() ....... I thought of that many times...... But it would look soooooooo funky half way up there......![]()
Erling |
10-22-2012, 01:13 PM
#9 |
Oddometer: 232
No way, look at all the threads on Thumpertalk about adapting KTM guards to fit a DRZ fork. I'm telling you, there's a market. Nobody likes those stupid black accordion-lookin' things.
10-22-2012, 02:37 PM
#10 | |
Oddometer: 2,825
Erling |
10-22-2012, 02:39 PM
#11 |
Oddometer: 232
I'll start saving my pennies. They'll match my heat shield nicely.
10-22-2012, 03:15 PM
#12 |
Oddometer: 480
Erling, This may be the route that I go as well. I pulled out the KLX forkguards and it will be a lot of work to try and mate anything (heat gun and forming). I might also make a cast using the two portions though as I like the upper plastic styling but need the lower bolt pattern. Either way it is on hold for the moment because it is a nice week and I finished with the fender mount today.
10-22-2012, 04:21 PM
#13 | |
Oddometer: 2,825
Erling |
10-22-2012, 07:33 PM
#14 |
Oddometer: 2,825
The hardware will now cure over night..... Until tomorrow....
Erling |
10-23-2012, 02:21 AM
#15 |
Oddometer: 480
Are the rings going to hold your brake cables? I am not quite sure how you routed yours but with mine they have a decent range of motion just on the street so make sure you provide as smooth of a guide as possible because they will be traversing it a lot.
