Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 08-24-2012, 01:34 PM   #106
Padmei OP
enamoured
Oddometer: 3,705
No gear yet from motobins however I have discovered this site. Each & every bike looks amazing.
It's a bummer when you read about track bikes, then enduro airheads then see cafe racers, bobbers, street trackers
http://kevilsspeedshop.com/motorcycles.html
Padmei is online now   Reply With Quote
Old 09-01-2012, 12:45 AM   #107
Oaters
Oaters's Avatar
Oddometer: 676
certainly some nice creations coming out of that shop in Devon Padmei - lurking with interest Aslan :)
Oaters is offline   Reply With Quote
Old 10-23-2012, 02:04 AM   #108
Padmei OP
enamoured
Oddometer: 3,705
Got back into the workshop mode tonite & decided to clean up Berlinas gearbox. I want to try it on Schmidt to hear if there are any differences in the sounds & if the notch from 1st to 2nd is the same.
A bit of kero & degreaser action
Ended up ok but not very clean or sparkly looking.
I am already on the way to having the fastest R65 on the planet as I spied the gearbox drain plug has been drilled
I had a looksie under the engine & found the same
Hmmmmmm so someone else has been flogging the poor girl on a racetrack before I got to it, Intelesting velly intelesting...
Also found the flange nuts had lil bits of green paint on the nuts. I'm thinking it was done by someone to make sure they'd done them all up tight.
I've heard that the only one that used this particular shade of green was the eccentric German engine tuner Gertrad Schumbleweiser. Very strange individual however maintained he could get 98HP out of a standard R65. I feel quite special really.
Edit: Does anyone know how the brake discs are riveted on? I'm wondering if a round cut piece of stainless would be cheap to get & fit. Course i could always start with a square piece & gradually knock the corners off.
Old 05-21-2013, 01:18 AM   #109
Padmei OP
enamoured
Oddometer: 3,705
Since some parts will be arriving back soon I should start getting some more inspiration. This one is one of the coolest customs I've seen.
i'm looking at a launch date of 2015 which will be months ahead of any other european bike works in Nelson
Old 05-21-2013, 02:24 AM   #110
innathyzit
AKA Woodman
innathyzit's Avatar
Oddometer: 1,132
Challenge huh ?
You're on..............
innathyzit is offline   Reply With Quote
Old 05-21-2013, 07:38 PM   #111
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,142
Trials tyres and BMW twin.
Not often even in the same photo, let alone the same bike...
NordieBoy is offline   Reply With Quote
Old 05-21-2013, 10:24 PM   #112
Padmei OP
enamoured
Oddometer: 3,705
Shit I like that can.
I can see it gracefully piro pireo spinning on a rock face with those tyres.
Old 05-21-2013, 11:27 PM   #113
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,142
It'd go straight up most rock faces with thems tyres...
Old 05-23-2013, 10:01 PM   #114
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,687
Awesome bike, but the tank needs some patina. But if it was my bike that would not take long.
R1150GS
R80GS Basic
Kokopelli is offline   Reply With Quote
Old 05-24-2013, 12:58 AM   #115
Padmei OP
enamoured
Oddometer: 3,705
Yes exactly right - a distressed or matt look would fit.
Do you think the swingarm is original or manufactured?
The rear peg on the muffler baffles me (get it? baffles- muffler hahahaha) & it also needs to lose the oil cooler & peanut covers
Old 05-24-2013, 01:38 AM   #116
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,687
Could be a standard twin shock set up. He probably has a "hot" girlfriend, so he needs the pegs.
R1150GS
R80GS Basic
Old 05-25-2013, 12:48 AM   #117
Padmei OP
enamoured
Oddometer: 3,705
Bet she wears a white singlet & tight jeans while she rides on it
Got the frame down & gave it a spray with some rustkiller paint. I thought it was gloss but is Matt. Looks quite good tho.
I noticed it doesn't have a Vin plate. Not sure if it did from the factory but I didn't take it off.
I did bit of a google & it states if it was first registered before 1994 & has a frame number stamped on it. Any with older bikes than mine have one? Mine is 88
Old 05-26-2013, 03:14 AM   #118
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,309
It should have the manufacturers plate there, with model details etc
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is online now   Reply With Quote
Old 06-04-2013, 11:00 PM   #119
Kokopelli
Yeah, right!
Kokopelli's Avatar
Oddometer: 4,687
Would that be a barrier to getting it registered? I know the wof guy always has a look there.
R1150GS
R80GS Basic
Old 06-04-2013, 11:45 PM   #120
innathyzit
AKA Woodman
innathyzit's Avatar
Oddometer: 1,132
He will have 2 modified airheads. Couple of wingnuts and he won't have to worry about regoing it.
Times are GMT -7.   It's 07:07 PM.
