Old 10-04-2012, 02:44 AM   #226
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,363
Originally Posted by DRjoe View Post
looking at fitting the model 60 on a 690 rally to replace the standerd halogen high beam.
Your light should be a nice simple swap but I was a bit woried it would over heat behind the fairing and light protector.
The lights need airflow to remain cool. You should consider addtional venting for the fairing.
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 10-04-2012, 03:35 AM   #227
DRjoe
DRjoe's Avatar
Oddometer: 5,309
Ah yea no way im cutting holes in a 690rr fairing.
Ill have to use something else.
Cheers
Joe
Old 10-04-2012, 05:55 AM   #228
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,363
Cheers
Joe
Can you post some pics of the front of the fairing where the lights are? Perhaps I can offer some options that don't require trimming.
Old 10-04-2012, 06:11 AM   #229
DRjoe
DRjoe's Avatar
Oddometer: 5,309
here is a good photo of the same kind of bike showing the light and fairing set up.
whats not clear in the phot is the head light protector thats in the fairing.
Its the bottom light that i want to replace.
Old 10-04-2012, 08:52 AM   #230
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,363
Do these bolts hold the light in?
Perhaps I can make an insert that the light will mount in, similar to this.
Old 10-04-2012, 03:22 PM   #231
StepOnIt
Assitoner
StepOnIt's Avatar
Oddometer: 1,037
Just my 2 cents into this, (following for some time) but what is the size of the HID light? and is the LED going to be smaller so that would have air flow around it?
Like the product and would love to have one ($$$$)
The road less traveled is the road I travel more.
"I feel sorry for people who don't drink. When they wake up in the morning, that's as good as they're going to feel all day." Dean Martin
StepOnIt is offline   Reply With Quote
Old 10-04-2012, 04:14 PM   #232
DRjoe
DRjoe's Avatar
Oddometer: 5,309
The model 60 is smaller diameter than the stock light but it would still get no air flow from the front because there is a clear screen attached to the fairing in front of the lights.
I don't want to remove the clear screen.
The lights bolt to the nav tower not the fairing sanjoh and the bolt holes you pointed out are for the clear screen and fairing mount.
Even if we did remove the clear screen that still wouldn't help the air flow if the bike is stationery.
What about adding some extra cooling fins?
I could tig weld some fins on to the case or turn up an extra big heat sink for the back of the light.
Old 10-05-2012, 05:51 AM   #233
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,363
What about adding some extra cooling fins? .
That will work. With our bulkhead mount in place, the lights do not overheat even at a standstill on full power, the bulkhead mount is a 1.6mm thick by 12mm clamp made of stainless, acts as a heatsink.
Old 10-05-2012, 12:38 PM   #234
DRjoe
DRjoe's Avatar
Oddometer: 5,309
Ok that's good then. I'll place an order on your sight soon.
Cheers
Joe
Old 10-06-2012, 07:24 AM   #235
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,363
Cheers
Joe
Great!
Old 10-10-2012, 09:09 PM   #236
marcwestbmw
Walkin' Mans Friend
marcwestbmw's Avatar
Oddometer: 491
Ok. 2002 KTM 520exc, Trail Tech 100W DC stator. What's the best way to run with my dimmer switch? Can I just run a 1500 as the low and a 3600 for high? What's the advantage of running your dimmer module?
"Where the Hell's Major Kong?"
marcwestbmw is offline   Reply With Quote
Old 10-11-2012, 03:23 AM   #237
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,363
Yes, that setup will work. The Model 30 (1500 lumens) will likely be too bright at night for other traffic on the road. The dimmer allows you to reduce light output which requires substantially less power to run then a light at full power. For example a model 60 makes adequate light for a low beam at only 3 watts.
Old 10-24-2012, 11:10 AM   #238
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,363
Old 10-26-2012, 06:26 PM   #239
Dr.Z
6Sigma Knuckle Shflr
Dr.Z's Avatar
Oddometer: 10,444
Recent adventure...
Lights made the nighttime into daytime...
Stay half-assed, my friends. -- Mike West
He's got some of the basics down, but, in the end, that just has to create a bigger clusterfuck in that chinese fire drill of a cognitive thought he brought to the dog and pony show of his new found awareness. - Jack Goff
Dr.Z is offline   Reply With Quote
Old 10-28-2012, 06:41 PM   #240
marcwestbmw
Walkin' Mans Friend
Oddometer: 491
OK,one last question. I have a Touratech DE/Xenon on my KTM 950 Adv S. Have you guys mounted any lights in one of these setups? The combo is great on the road. But, I need more light offroad.
Times are GMT -7.   It's 02:44 PM.
