08-28-2012, 07:02 PM
#16 |
cheap bastard
Oddometer: 2,999
Did you ever check the points are set properly ?
10-09-2012, 04:40 PM
#17 |
Oddometer: 51
Aha! After taking off the side cover, I found the nut to hold the rotor missing. Ordered a new one, put it on, kick, no spark. Disconnected both wires for the kill switch, still nothing. So next is the points. Anybody know the correct gap?
Sure it's quiet, for a diesel. But that's like being well-behaved... for a murderer. -Jeremy Clarkson |
10-11-2012, 06:42 PM
#18 |
Street Adventurist
Oddometer: 189
Points gap .012-.016
Plug gap .025 From this source http://en.allexperts.com/q/Motorcycl...lsinore-MT.htm Hope this helps.
bmwdon75 K75s |
10-13-2012, 12:38 AM
#19 | |
Have guns will hunt
Oddometer: 5,404
![]() ![]() ![]() ![]() ![]() ![]() ![]() Is it me or did anyone else think this was a wind up.
I REALLY AM A NICE GUY. JUST ASK ANYONE WHO HASN`T MET ME. |
10-13-2012, 11:27 AM
#20 | |
n00balicious
Oddometer: 2,912
Ok wait. The stator is screwed onto the engine case, it holds the three primary coils and the points. The flywheel (or rotor) is held onto the crankshaft via a single nut. I'm guessing you mean the nut for the flywheel was loose. Was the flywheel loose? If so, you may have sheered the flywheel key. The flywheel needs to be "clocked" to a particular position by that key. You should need a flywheel puller to get the flywheel off to access the points. Did you change the condenser? You can use a condenser off of just about anything.
"I couldn't wait for success, so I went ahead without it." |
10-14-2012, 02:43 PM
#21 |
Oddometer: 51
News flash (literally). I got spark! But only once. I widened the gap, and kicked over, and it sparked the first time, but after that, nothing. What does this mean?
Wk
10-15-2012, 01:52 PM
#22 |
cheap bastard
Oddometer: 2,999
the key was still in after you noticed the flywheel nut was loose ?
10-15-2012, 03:25 PM
#23 |
What could go wrong?
Oddometer: 4,960
Are you using an old plug? If so try a new one, if that doesn't work try a new condenser.
Kawasaki H1 build thread 71- 450 Honda CL re & re Just another pathetic sheep following the herd |
10-15-2012, 03:31 PM
#24 |
Oddometer: 51
No. I didn't mention a few steps. The key was sheared, so I replaced that too. And while I'm at it, the threads where screwed up ( pun intended) so I cleaned them up with a chaser. I also replaced the spark plugs and the condenser is part of the ignition coil.
10-15-2012, 03:48 PM
#25 |
cheap bastard
Oddometer: 2,999
on your bike the condenser is up by the coil but it is still replaceable .
10-25-2012, 06:17 PM
#26 |
Oddometer: 51
I know, i meant that a new one came with the coil.
