10-25-2012, 11:47 AM
#1366 | |
British
Oddometer: 736
Bike should be quicker ... loosing 50lbs of useless garbage from the bike
10-25-2012, 12:06 PM
#1367 |
Oddometer: 2,394
More like 5 lbs at best. I removed the entire air injection system from my W but didn't notice any difference in performance.
Vince @ SWFL or WNC 2001 Kawasaki W650 2012 Ural Yamal |
10-25-2012, 12:28 PM
#1368 |
Oddometer: 80
Damnit, just let me enjoy my perceived performance enhancement! Haha!
New question for you folks. Would you think it unwise to run the bike without a rear fender? I'm trying to go for that super stripped down vibe and I think it would look really cool. The airboxes and carbs don't look like they would be in any danger from water and debris, but I could be wrong. If I remove the front fender as well, I would get a Super Brace. Just curious if I would damage anything. |
10-25-2012, 04:31 PM
#1369 |
Oddometer: 4,585
Well. you'll definitely risk a skunk stripe up your back the first time you hit wet weather.
'01 Kawasaki W650 '05 Yamaha XT225 |
10-26-2012, 05:31 AM
#1370 |
Oregon Expatriate
Oddometer: 2,329
. . . and when you remove the front fender, all that water gets sprayed on the engine and up in the air . . . . and then lands on your face . . .
![]() Since I ride in the rain as a matter of routine, I've no intention of cutting down or removing my fenders. For the fair-weather-only folks, I don't believe fender removal would cause any real problems. You might put a cut-down piece of plastic fender under the saddle/behind the airbox, just to keep rocks and gravel from causing damage. |
10-26-2012, 05:42 AM
#1371 | |
Oddometer: 80
10-26-2012, 06:33 AM
#1372 |
Oddometer: 2,394
zwish,
You could ask someone who has replaced their W650 rear fender because of the splitting if they would sell you their old fender and you could just chop it off and still have the protection. I believe the Jerk replaced his rear fender with the new improved version.
10-28-2012, 07:23 PM
#1373 |
Oddometer: 142
my W675
I'm just about done with my w675.
List of things done: Super Brace RaceTech fork springs (lowered an inch) and gold emulator Hagon rear shocks (210mm, which should come out to about an inch lower at rear axle) shorten center stand an inch and bent out kick stand Honda CB600F handle bar (3" rise and 28" width at bar end weights) with problem solver bar shims Shorten throttle cable (cut them down and solder new ends) Shorter clutch cable (from oem low bar) stainless steel braided brake line HH brake pads Signal Dynamics headlight and brake light modulator Powder coated fenders and grab bars spot welded on gussets on rear fender smaller turn signals 2001 knee pads trimmed seat and upholstered (plan on trimming down the middle hump flat) Rapid Transit tail bag Gerbing electric heater ready oil dip stick thermometer de-baffled stock mufflers air/fuel screw at 2.5 turns out and shim needles All emissions stuff removed/replaced properly not just plugged up BT45's tires with over 5k miles (looks like they will last 6k miles) Trying some Pilot Activ next Big improvements were the suspension upgrades and the lower handle bars. Lower the bike an inch did reduce ground clearance a little but I like the lower center of gravity. Carb tune is just right and am getting over 60mpg taking it easy, upper 50's mpg thru the mountains and about mid 50's mpg if I ride it like a sports bike. Overall the bike feels much better then stock...almost sold it when it was stock cause I wasn't happy with how it rode but now am very happy. Thinking about taking off the emblems, just don't like how thick they are, makes the bike look wider. If I do do it then they will be replaced with W's. Bike is a little dirty in this pic, hadn't washed it in about 3 months.
10-28-2012, 10:01 PM
#1374 |
Oddometer: 4,585
Got good news yesterday from my local dealer, my little mishap caused no fork or frame damage.
So I'll rebuild, already had new throttle cables installed, now looking for a new headlight. Need to order turn signals and another low bar. Looking for opinions as to whether (and how) the foot peg bracket can be unbent.
10-29-2012, 05:13 AM
#1375 |
Oddometer: 2,394
Speedo66,
That is good news. She will be good as new soon. How about a close up of the bent bracket? Maybe someone can come up with a suggestion. Hunker down for Sandy and be safe.
10-29-2012, 05:07 PM
#1376 |
Oddometer: 4,585
Visiting my daughter in OH, won't be back to the east coast 'till next weekend. Hope my houses are still up with no trees through them.
Good luck to all in Sandy's path, and stay safe.
10-30-2012, 04:57 AM
#1377 | |
I have no soul
Oddometer: 5,585
If you strip it down just make sure you do your bike justice. W's are gorgeous bikes with a ton of potential as a custom. ![]()
"I have great faith in fools; self-confidence my friends call it." ~Edgar Allen Poe~ My HD Scram-ster build Help Save a Pit-Bull |
10-30-2012, 07:14 AM
#1378 | |
Oddometer: 2,394
Is that your W? Very nice job but way too extreme for me. IMHO, unless I had a wrecked W I would leave it original but to each his own. I'll be back in SWFL for the winter soon so maybe we can have another W meet up say half way across the Alley.
10-30-2012, 07:38 AM
#1379 |
Oregon Expatriate
Oddometer: 2,329
I tend to agree with Barnone. W650's are relatively rare in the US, though much more common in Europe and Asia. I hate to see such a nice bike made less ridable in the name of an individual's view of aesthetics.
I enjoy looking at custom work that enhances the joy of riding--cafe racers, scramblers, touring versions--and that don't destroy the bike's basic handling and ergonomics. That's my biggest complaint about "choppers." Most aren't built to be ridden, just gawked at. There's a lot of superb craftsmanship and creativity that go into many unrideable bikes--I respect that immensely. But many of the things done to those bikes detract from the ability to actually ride them. Contorted riding positions, ill-conceived tire sizes, etc.--meh. I'd rather go for a ride!
10-30-2012, 01:07 PM
#1380 |
Oddometer: 142
