10-25-2012, 08:16 PM
#1 |
Oddometer: 2,430
100 THREADS all GS/GSA owners should read.
The "100 Threads" is a compilation of the TOP 100 THREADS submitted by your fellow inmates.
It contains the most common information in an easily SEARCHABLE format that you want/need to know if you own a GS/GSA. HOW TO SEARCH THE LIST You can SEARCH the "100 Threads" by using Ctrl+F keys This opens a FIND window which allows you to SEARCH this thread. For example, enter "Brakes" into the FIND dialogue window and you'll get each instance of "Brakes". 1. HOW DO I CONVERT MY HEADLIGHTS TO HID? http://advrider.com/forums/showthread.php?t=288538 http://www.advrider.com/forums/showthread.php?t=388828 (1150GSA) 2. WHY IS MY ENGINE NOW RUNNING ROUGH? THE ENGINE IS IDLING HIGHER THAN NORMAL. http://advrider.com/forums/showthread.php?t=835521 Post #5 3. HOW COME MY HEATED CLOTHING, AIR COMPRESSOR, POWER OUTLET, ETC DOESN'T WORK? http://www.powerlet.com/learningCenter/iCan 4...IS THERE ANY PLACE WHERE THE MOST FREQUENT QUESTIONS ARE ASKED? http://advrider.com/forums/showthread.php?t=326162 5. WHERE CAN I GO TO FIND DETAILED WRITTEN INSTRUCTIONS ON HOW TO DO MAINTENANCE ITEMS? http://advwisdom.hogranch.com/Wisdom/ http://www.amazon.com/R1200-Haynes-S.../dp/1844259250 2010+ Haynes Manual http://www.amazon.com/R1200-Service-...ds=bmw+r1200gs 2004-2009 Haynes Manual 6. HAS ANYBODY PRODUCED A DVD SHOWING HOW NORMAL MAINTENANCE ITEMS ARE DONE? http://www.jimvonbaden.com/ 7. Is oil consumption normal? http://www.advrider.com/forums/showthread.php?t=504643 8. WHAT ARE THE PART NUMBERS THAT WILL FIT MY BIKE? http://www.maxbmwmotorcycles.com/fiche/PartsFiche.aspx http://www.ascycles.com/BMW-Motorcycle-Parts-Fiche.aspx http://realoem.com/bmw/select.do 9. WHERE CAN I FIND THE BMW MAINTENANCE SCHEDULE FOR MY BIKE? http://www.ascycles.com/bmw_motorcyc...schedules.aspx 10. WHERE CAN I FIND TORQUE VALUES? AND...OTHER GS STUFF. http://www.r1200gs.info/misc/torque.html 11. MY GS/GSA WON'T START IN GEAR...NOW WHAT DO I DO? http://advrider.com/forums/showthread.php?t=376181 12. WHY ARE MY BRAKES SO GRABBY? SANDPAPER IS THE FIX...YOU SAY? http://advrider.com/forums/showthread.php?t=838082 13. WHERE CAN I FIND A COPY OF MY BIKE'S OWNERS (RIDER'S) MANUAL THAT CAME WITH THE BIKE? YOU KNOW..RTFM. http://www.bmw-motorrad.com/com/en/index.html Click on "Service" Click on "Rider's Manuals" on left side 14. HOW DO I ADJUST THE VALVES ON MY 10+ DOHC. http://sanjosebmw.smugmug.com/Other/...9614&k=BmBc5cN Note from contributor EvilTwin: I know there is a thread around for this somewhere, but can't find it. I do, however, have the photos bookmarked. This is a pictoral for a '10 and up valve lash check. There is a little more to it than this if you have to change shims. For example, if your shim (semi-sphere) measures as it should and your clearance is off then something else is worn and you will need a new shim of a different size to change the gap appropriately. If the shim does not measure as it should and the gap is not correct, then there is the possibility that you need a new shim of the same size to take up the gap. Provided, of course, the valve lash change needed = difference between actual shim size and spec'd size 15 HOW DO I TIE DOWN MY BIKE FOR TRANSPORTING? http://www.grassrootsbmw.com/uploads/Tiedown2.pdf http://advrider.com/forums/showthread.php?t=853572 16. HOW CAN I DONATE TO KEEP ADV UP AND RUNNING? http://www.advrider.com/Donate/Donate.html 17. WHAT TOOLS DO I NEED TO WORK ON MY BIKE? http://www.r1200gs.info/misc/toolkit.html http://jimvonbaden.com/Tool_Kit.html (JVBaden's suggested list!) http://advrider.com/forums/showthread.php?t=348022 18. HOW CAN I CHANGE THE LOCKS (RE-KEY) ON MY VARIOS? http://www.advrider.com/forums/showt...ighlight=rekey 19. HOW DO I INSTALL THE BURNS MOTO (OR OTHER) FUEL BYPASS CABLE? https://skydrive.live.com/redir.aspx...4609DB3988!130 20. WHAT SPARES SHOULD I CARRY? http://advrider.com/forums/showthread.php?t=839751 http://advrider.com/forums/showthread.php?t=316464 21. HOW TO INSTALL ALTERNATOR BELT: http://www.youtube.com/watch?v=YzPTPN98x40 22. HOW TO INSTALL AN ODYSSEY PC535 BATTERY: http://www.advrider.com/forums/showthread.php?t=320214 23. WHAT'S WITH THE REAR DISK BRAKE FLANGE?: http://www.advrider.com/forums/showt...3#post17330243 24. HOW TO DO BRAKES: PADS: http://www.bmwmoa.org/forum/showthre...=34541&page=2; 25.HOW DO I BLEED MY BRAKES: http://advrider.com/forums/showthread.php?t=341305 26. HOW TO BREAK THE BIKE IN HALF: (INTENTIONALLY, OF COURSE) http://www.advrider.com/forums/showthread.php?t=655998 27. DRIVE SHAFT, U-JOINT REPAIRS: http://www.advrider.com/forums/showthread.php?t=555869 http://www.advrider.com/forums/showthread.php?t=853018 28. HOW TO REMOVE, REINSTALL DRIVESHAFT & BOOT: http://www.advrider.com/forums/showthread.php?t=712469 29. HOW TO CHANGE FINAL DRIVE OIL: http://jimvonbaden.com/R1200_Final_Drive.html 30.HOW TO REPLACE FINAL DRIVE OUTER SEAL: http://www.advrider.com/forums/showthread.php?t=335870 http://advrider.com/forums/showthread.php?t=880390 31. HOW TO BYPASS THE SIDE STAND INTERLOCK SWITCH: Method 1. http://advwisdom.hogranch.com/Wisdom/SSIBD.pdf Method 1. R1200GSMethod 2.http://www.youtube.com/watch?v=kWVEA...FD804CDF3E026C GlobeRider's video 32. HOW DO I CLEAN UP THAT REAR CALIPER?: http://advwisdom.hogranch.com/Wisdom/BFDRear2.1.1.pdf 33. MY HEADLIGHT SEEMS TO BE OUT OF WHACK...HOW DO I FIX THE AIMING? http://advrider.com/forums/showthread.php?t=590440 34. WHO'S THE GUY THAT TRUES AND STRAIGHTENS SPOKED BMW WHEELS? I THINK HIS NAME IS WOODY. http://advrider.com/forums/showthread.php?t=839732 Post #3 35. HOW CAN I FIND PAINT THAT MATCHES MY BIKE/YEAR? http://www.colorrite.com/index.cfm?killnav=1 http://www.bmbikes.co.uk/paintcodes/reds.htm (select your color family) http://www.oreillyauto.com/site/c/de...1159&ppt=C0253 (Valve covers!) 36. ARE THERE AFTER MARKET OPTIONS FOR TIRE PRESSURE MONITORING? http://advrider.com/forums/showthread.php?t=626512 37.HOW DO I REMOVE MY ALTERNATOR? http://advrider.com/forums/showthread.php?t=703446 38. HOW CAN I KEEP MY VARIO SIDE CASES FROM FALLING OFF? http://advrider.com/forums/showthread.php?t=605203 ![]() ![]() 39. HOW DO I INSTALL OEM GSA DRIVING LIGHTS ON MY GS? http://advrider.com/forums/showthread.php?t=578964 40. WHERE CAN I GO TO IMPROVE MY RIDING SKILLS? http://www.rawhyde-offroad.com/ (Rawhyde) http://www.bmwoffroadacademy.com/ (BMW) http://advrider.com/forums/showthread.php?t=848451 (Jimmy Lewis) http://adventureridersinternational.com/ (Adventure Riders International) 41. I JUST REPLACE MY 'HALL' SENSOR AND MY BIKE DOESN'T RUN OR STOPS RUNNING WHEN IT GETS WARM. NOW WHAT DO I DO? http://advrider.com/forums/showthread.php?t=827860 42. HOW DO I INSTALL THOSE ROX RISERS ON MY BIKE? http://advrider.com/forums/showthread.php?t=341906 http://advrider.com/forums/showthread.php?t=844550 http://advrider.com/forums/showthread.php?t=347359 (Re-routing the throttle cable...afterwards) 43. THE ADV SEARCH ENGINE DOESN'T FIND WHAT I'M LOOKING FOR. WHAT DO I DO NOW? https://www.google.com/search?num=10...le&btnG=Search Substitute whatever you're looking for for the word "Motorcycle" and you'll find it! 44. I'M LOOKING FOR A TOOLBOX FOR MY GSA...WHAT ARE SOME CHOICES? http://www.advmotorrad.com/index.php...&product_id=61 http://twalcomusa.com/ttr-raidbox-r1200gs-adv.html http://www.bmwgsemotion.com/accessoring.html http://advgear.net/ http://dsbikeprotection.com/BMW-R120...l#.UOZHGm99LNk http://www.bmwgsemotion.com/accessoring.html (GS Emotion brand) 45. HOW DO I REMOVE MY SIDESTAND? THE BUSHING SEEMS STUCK? http://www.aksengineering.com/assets..._use_guide.pdf 46. ARE OHLINS SHOCKS REALLY THAT GREAT? CAN I INSTALL THEM MYSELF? http://advrider.com/forums/showthread.php?t=262392 http://www.jimvonbaden.com/Ohlins_Shock_Install.html (Thanks, as always, to JVB!) 47. DO THOSE "WINGLET" THINGS REALLY WORK? WHERE CAN I GET THEM? http://advrider.com/forums/showthread.php?t=151722 http://www.ceebaileys.com/bmw/1200gs_wind_wing.html http://www.wunderlichamerica.com/mot...00378-379.html 48. WHERE CAN I BUY A 'THROTTLE CONTROL' http://www.kaoko.com/default.aspx (Kaoko) http://throttlemeister.com/ (Throttle Meister) http://www.crampbuster.com/ (Crampbuster - CB2) 49. I WANT TO MAKE MY BIKE MORE VISIBLE...WHAT ARE MY OPTIONS? http://www.skenedesign.com/lights/ (Photonblasters) http://hyperlites.com/ (Hyperlites) http://advrider.com/forums/showthread.php?t=605428 (LED's in Hanguards) http://advrider.com/forums/showthread.php?t=831710 (Reflective Decals) http://www.adventuretech.ca/ (LED Flashing Brake Light -05 thru 07) http://beemershop.com/Merchant5/merc...uct_Code=RCL08 (LED Flashing Brake Light -05 thru 07) http://www.touratech-usa.com/Store/1...m-2008-onwards (LED Brake Light -08 onwards) https://www.kisantech.com/index.php?cat_id=3 (Kisan) http://www.adventuremotorcycleparts..../TR481001.html (Signal Dynamics Back Off XP Brake Light Signal Module) http://admorelighting.com/ (Various LED light bars) http://www.identi-tape.com/solas.html (SOLAS reflective tape) 50. HOW DO I REPLACE THE FINAL DRIVE BEARING IN A R1100GS and R1150GS? http://advrider.com/forums/showthread.php?t=234400 51. I WANT/NEED TO BUY SOME PANNIERS FOR MY BIKE. WHAT ARE SOME CHOICES? Contact Inmate Kirkster70 (Kirk's hand made panniers)...or...start reading here: http://advrider.com/forums/showthrea...625664&page=94 --------------------------------------------------------------------------------- http://www.touratech-usa.com/ (ZEGA's) http://www.jesseluggage.com/ (Jesse's) http://cariboucases.com/store/?name=Home (Caribou Cases) http://micatech.net/ (Micatech) http://www.happy-trail.com/ (Happy Trails) http://www.twistedthrottle.com/shop-.../luggage-racks (Twisted Throttle - TRAX) http://www.xplorermoto.com/bumotR12GS.html (Bumot made in Bulgaria...available in the US) http://www.projectvnd.com/index.htm (Vern's World Beater's) http://advdepot.com/globescout (Global Scout's - US Distributor) http://www.globescout.de/home.php?cat=2 (Global Scout - Mfg website) http://nomadacases.com/en/catalog/41...mada_PRO_cases (Holan Nomada) http://www.maxbmwmotorcycles.com/fiche/PartsFiche.aspx (BMW branded, Varios and OEM aluminum) search by bike 52. I LOST THE KEY(S) TO MY BIKE. WHAT DO I DO NOW? http://www.advrider.com/forums/showthread.php?t=396942 http://www.advrider.com/forums/showthread.php?t=791283 53. MY HEATED GRIPS STOPPED WORKING...NOW WHAT? http://www.advrider.com/forums/showthread.php?t=770667 http://advrider.com/forums/showthread.php?t=856853 54. HOW DO I REPLACE MY HEATED GRIPS? http://advrider.com/forums/showthread.php?t=498496 http://advrider.com/forums/showthread.php?t=856853 55. AM I TOO OLD TO OWN A GS? WHAT'S THE AVERAGE AGE OF A GS RIDER? http://advrider.com/forums/showthread.php?t=844883 56. WHAT ARE SOME OF THE MODS RIDERS HAVE DONE TO THEIR VARIOS? http://www.advrider.com/forums/showthread.php?t=643013 57. I JUST GOT MY CENTECH AP-1 OR AP-2 FUSE BOX.. HOW DO I MOUNT IT? WHERE CAN I MOUNT IT? http://advrider.com/forums/showthread.php?t=537579 58. HAS ANYBODY EVER INSTALLED 'CRUISE CONTROL' ON A GS? http://advrider.com/forums/showthread.php?t=845862 http://www.advrider.com/forums/showthread.php?t=244690 http://advrider.com/forums/showthread.php?t=803459 (O-ring version) http://www.mccruise.com/collections/bmw (McCruise) 59. HOW DO I CHANGE A GEARBOX INPUT SEAL? HOW DO I REPLACE A CLUTCH PRESSURE DISC? http://www.advrider.com/forums/showthread.php?t=724130 60. HOW DO I REMOVE A GS ADVENTURE PETROL TANK? HOW DO I REPLACE GS ADVENTURE SHOCKS? http://www.advrider.com/forums/showthread.php?t=808727 61. WHAT IS CONSIDERED A LOW OR HIGH MILEAGE GS? http://advrider.com/forums/showthread.php?t=744842 62, MY VARIOS ARE STUCK...THEY DON'T OPEN/CLOSE EASILY. NOW WHAT? http://advrider.com/forums/showthread.php?t=356840 63. HOW DO I DO A THROTTLE BODY SYNC? http://www.advrider.com/forums/showthread.php?t=231335 64. I THINK MY FUEL PUMP FLANGE IS CRACKED. WHAT DO I DO NOW? http://www.advrider.com/forums/showthread.php?t=711467 65. I BROKE THE 'TAB' and/or 'LOCKING MECHANISM' ON MY VARIOS. HOW DO I FIX THEM? http://advrider.com/forums/showthread.php?t=848307 66. I'M HAVING TROUBLE REMOVING MY SHOCKS FROM MY GSA. HELP! http://advrider.com/forums/showthread.php?t=848957 (See Post #11) http://advrider.com/forums/showthread.php?t=856133 (Removing ESA shocks on a GS. pictorial) 67. I WANT TO LINE MY ALUMINUM PANNIERS...EVERYTHING KEEPS GETTING BLACK ALL OVER IT. SUGGESTIONS? http://advrider.com/forums/showthread.php?p=19339154 Post #204 68. HOW CAN I TELL WHEN MY BIKE WAS ACTUALLY BUILT? AND...A LOT OF OTHER DATA ABOUT YOUR SPECIFIC BIKE! http://www.bmw-z1.com/VIN/VINdecode-e.cgi ...OR... http://www.bmwarchiv.de/vin/bmw-vin-decoder.html 69. HOW CAN I ADJUST THE THROTTLE CABLE...IT SEEMS TOO LOOSE? http://advrider.com/forums/showthread.php?t=850951 70. HAVEN'T FIGURED OUT HOW TO POST PICTURES...CAN YOU HELP? http://advrider.com/forums/showthread.php?t=919 ...or...Click on FULL SCREEN at lower right of window below. 71. MY BIKES STARTS...BUT IDLE'S VERY HIGH AT STARTUP. WHAT'S GOING ON? http://www.advrider.com/forums/showthread.php?t=721682 Read Post #6 72. WHERE CAN I FIND A WIRING DIAGRAM/SCHEMATIC FOR MY BIKE? R1200GS: R11XXGS: http://advrider.com/forums/showthrea...7#post20364897 Post #23 73. MY ABS UNIT IS SHOT. CAN IT BE REPAIRED? OR DO I HAVE TO BUY A NEW ONE? http://advrider.com/forums/showthread.php?t=852577 http://advrider.com/forums/showthread.php?t=792722 74. THE FUEL PUMP FLANGE APPEARS TO HAVE A CRACK IN IT...WHAT DO I DO NOW? http://advrider.com/forums/showthrea...ight=fuel+pump (Read about it) http://advrider.com/forums/showthread.php?t=852502 (Fix it) 75. I WANT TO SHIP MY BIKE TO EUROPE. WHAT ARE SOME OPTIONS? http://advrider.com/forums/showthread.php?t=852629 (SEE Post #4 and #20) http://advrider.com/forums/showthread.php?t=852629 76. HOW CAN I TELL HOW OLD THE TIRES ARE ON MY 'NEW TO ME' BIKE? http://www.tirerack.com/tires/tirete....jsp?techid=11 http://www.tirerack.com/tires/tirete...jsp?techid=172 77. WHAT'S MY BIKE WORTH? WHAT'S THE VALUE OF AN RXXXXGS? http://www.kbb.com/motorcycles/ (Kelley Blue Book) http://www.nadaguides.com/Motorcycles (NADA) http://www.searchtempest.com/ (SearchTempest.com) - searches all Craigslist's in the US 78. HOW DO YOU REPLACE THE EWS RING? http://www.advrider.com/forums/showthread.php?t=443172 http://advrider.com/forums/showthread.php?t=855501 (Post #2...Good info to know!) 79. I CAN'T GET MY OIL FILTER OFF? HUH? WHAT THE BLANKETY BLANK DO I DO NOW? http://advrider.com/forums/showthread.php?t=852340 Lots of great alternative suggestions! 80. CAN YOU CONVERT A GS TO THE LARGER GSA FUEL TANK? HOW? http://advwisdom.hogranch.com/Wisdom...Conversion.pdf http://advrider.com/forums/showthread.php?t=378053 http://advrider.com/forums/showthread.php?t=760269 (Fuel transfer problems) http://www.advrider.com/forums/showthread.php?t=521394 81. WHAT'S THE PROPER WAY TO USE THE DIAGNOSTIC PLUG FOR 'POWERING' THINGS? http://advrider.com/forums/showthread.php?p=20473988 82. HOW DO I KEEP MY VARIO TOP CASE FROM FALLING OFF? IS THERE A FIX? http://advrider.com/forums/showthread.php?t=686640 83. HOW DO I REMOVE THE CHARCOAL CANISTER FROM MY GSA? http://advrider.com/forums/showthread.php?t=211357 84. HOW ABOUT A 21" FRONT WHEEL? ANYBODY DONE IT? CLEARANCE ISSUES? http://advrider.com/forums/showthread.php?t=495376 http://advrider.com/forums/showthread.php?t=663107 http://advrider.com/forums/showthread.php?t=853064 (R1200GS Billet triple clamp project - Vendors) http://advrider.com/forums/showthread.php?t=862561 (R1200GS Billet triple clamp project - Oilhead Boxers - discussion/feedback) 85. I BROKE MY HEADLIGHT RETAINER CLIP...WHAT DO I DO NOW? IS THERE A FIX? http://www.advrider.com/forums/showt...php?p=20573586 86. I NEED ONE OF THOSE ABS FUNNELS TO SERVICE THE ABS...WHAT ARE MY OPTIONS? http://advrider.com/forums/showthrea...4#post20586234 (See Post #17 for DIY parts) http://www.beemerboneyard.com/abs3funnel.html 87. HAS ANYBODY BUILT A SNORKEL FOR THEIR GS/GSA...YOU KNOW... FOR DEEP STREAM CROSSINGS? http://advrider.com/forums/showthread.php?t=628545 http://advrider.com/forums/showthread.php?t=811462 http://www.advrider.com/forums/showthread.php?t=520523 88. I WANT A LOUDER HORN. STEBEL IS THE NAME I'VE HEARD. HOW DO YOU INSTALL IT? WHERE TO INSTALL? WHAT DOES IT SOUND LIKE? http://www.stebel.it/stebel2012/suon...nautilusCS.swf http://excelcyclewerkes.com/index_files/Page732.htm http://www.itrider.net/downloads/R12...cle_Werkes.pdf (2011 GSA w/ESA) http://www.motorcycleparts-hornig.co...ebel-Horn.html 89. MY BRAKES LIGHTS STAY ON ALL THE TIME. WHAT'S UP WITH THAT? http://advrider.com/forums/showthread.php?t=692796 http://www.advrider.com/forums/showthread.php?t=688059 90. LOOKING FOR A SPARK PLUG COIL REMOVER TOOL. WHAT ARE MY OPTIONS? http://www.marcparnes.com/BMW_Plug_Tool.htm (Marc Parness) http://stores.promachdualtool.com/-s...val/Detail.bok (ProMach) http://www.advdesigns.com/bmwspplcapre.html (Adventure Designs) http://advrider.com/forums/showthrea...2#post20654002 (DIY methods and tools) 91. WHAT'S THE PREFERRED WAY OF MOST RIDERS OF ADJUSTING THE ALUMINUM GS/GSA SEAT RODS? http://advrider.com/forums/showthread.php?t=684161 92. HOW DO I PROPERLY BED-IN NEW BRAKE PADS? http://advrider.com/forums/showthread.php?p=20668739 93. I SEE THE OIL FOAMING IN THE SIGHT GLASS...SHOULD I BE CONCERNED? http://advrider.com/forums/showthread.php?t=858913 94. WHAT THIS THING CALLED A "GS911 FAULT CODE READER" ACTUALLY DO? DO I NEED ONE? http://advrider.com/forums/showthread.php?t=189421 (Many responses...discussion) http://advrider.com/forums/showthread.php?t=861221 (More responses) 95. WHAT'S THE BEST WAY TO CONNECT AUDIO TO YOUR HELMET HEADSET? WIRED OR BLUETOOTH? http://advrider.com/forums/showthread.php?t=874440 96. I WANT TO EXTEND MY MIRRORS FURTHER OUTWARD. WHAT ARE MY OPTIONS? http://www.wunderlichamerica.com/mot...60446-447.html (Wunderlich, Black/Silver) http://store.bobsbmw.com/product/zte...ers-r1200gsrst (ZTechnik) http://advrider.com/forums/showthread.php?t=643655 97. I'D PREFER A DIFFERENT SEAT THAN THE OEM (READ AS...."I HATE MY SEAT!") WHAT ARE SOME OTHER CHOICES? (The #1 complaint) http://www.day-long.com/gallery_BMW.html (Russell Day Long) http://www.sargentcycle.com/bmwwsr12gs.htm (Sargeant) http://www.corbin.com/bmw/r12gs.shtml (Corbin) http://www.rickmayercycle.com (Rick Mayer) http://mayergonomic.com/ (Bill Mayer) http://www.touratech-usa.com/Store/3...ure-Oil-Cooled (Touratech) http://www.advdesigns.com/safrseforbmw.html (Adventure Designs) http://www.wunderlichamerica.com/mot...61164-199.html (Wunderlich Ergo seat) [ 98. LOOKING FOR A TANK BAG FOR MY GS. WHAT ARE MY OPTIONS? http://advrider.com/forums/showthread.php?t=337145 (Tank Bag Discussion) http://www.marseeproducts.com/ (Marsee) http://www.twistedthrottle.com/shop-...acks/tank-bags (Bags Connection and others) http://shop.sw-motech.com/en/by+prod...bags/index.htm (SW-Motech) http://www.touratech-usa.com/Store/1...Bags-Tail-Bags (Touratech) http://wolfmanluggage.com/index.cfm?...&category_id=8 (Wolfman) 99. HOW DO I INSTALL THE DISPATCH 1 POWER DISTRIBUTION SYSTEM? http://advrider.com/forums/showthread.php?t=870449 pictorial on the R1200GS http://advrider.com/forums/showthread.php?t=870941 pictorial on the R1200RT http://arborealsystems.com/Arboreal_Systems/home.html 100. HOW MUCH OIL SHOULD I PUT IN WHEN I CHANGE IT? (#1 most common question) http://advrider.com/forums/showthread.php?t=869667 (See Post #4) 101, MY GEAR INDICATOR IS 'INDICATING' THE WRONG GEAR. HOW DO I FIX THIS? http://advrider.com/forums/showthread.php?t=824627 102. What alternate foot pegs and lowering options are available for the R1150GS and R1200? http://advrider.com/forums/showthread.php?t=878283 LaurelPerryOnLand screwed with this post 05-11-2013 at 06:25 AM Reason: link to FAQ |
10-26-2012, 04:08 AM
#2 |
Boxer Freak
Oddometer: 413
What? No oil thread??
Cornerworker of the year 2012 www.marrc.org 1981 BMW R100rs "Helga" 2007 Kawasaki ZX6r "Grasshopper" 2012 BMW R1200 GS/A "Elche" |
10-26-2012, 04:14 AM
#3 |
Oddometer: 263
When will my FD explody?
10-26-2012, 04:50 AM
#4 |
'05 R1200 GS
Oddometer: 4,077
My legs are too short, waaaaaaa, waaaaaa !!
(search for seat height, lower, Napoleon, inseam, etc,)
"Dang man I'm impressed." - Willy-B "Are you OK? ... Are you sure you're OK?" - Honcho "Disturbing and funny, all at the same time." - MrTwisty |
10-26-2012, 04:54 AM
#5 |
Oddometer: 120
Gotta have a tire thread, the problem is which one?
2007 R1200GS |
10-26-2012, 07:29 AM
#6 |
Dog Rancher
Oddometer: 4,181
Too bad we can't organize the threads based on category by BMW part category.
01-Literature 11-Engine 12-Engine Electrics 13-Fuel Preparation 16-Fuel Supply 17-Cooling 18-Exhaust System 21-Clutch 23-Transmission 31-Front Suspension 32-Steering 33-Rear Axle & Suspension 34-Brakes 35-Pedals 36-Wheels 46-Frame, Fairing, Cases 51-Vehicle Trim 52-Seat 61-Electrical System 62-Instruments Dash 63-Lighting 65-GPS, Alarm & Radios 71-Equipment Parts 77-Accessories Aftermarket exhaust, What seat do I get, Panniers, Driveshaft, Spline lube, GPS wiring, Shift lever, foot pegs, How do I check my oil quantity. What car parts can I use. What color paint is my engine painted, Who is tagesk, What is a sticky, What is GSpot Frequently Asked Questions/LOOK HERE FOR FORUM CONTENTS GSpot FAQ
scooteraug02 screwed with this post 10-26-2012 at 10:50 AM |
10-26-2012, 08:25 AM
#7 |
Oddometer: 818
but ummm which tires should i use
10-26-2012, 03:03 PM
#8 |
Oddometer: 818
10-26-2012, 05:27 PM
#9 |
Oddometer: 2,936
![]() Needs more oil thread.. Oh..and exhaust makes my bike run like shit thread.. xcellent effort LPOL
Insert witty sig line here.. |
10-27-2012, 02:56 AM
#10 |
Crohn's Disease sux!
Oddometer: 1,188
how about an accessories / farkles thread?
"The early bird gets the worm, but the second mouse gets the cheese." Unknown '12 BMW R1200GSA '07 BMW G650X Ch ADV '02 BMW R1100S BCX
10-27-2012, 06:47 AM
#11 |
Boxer Freak
Oddometer: 413
Will you post more so I can watch your avatar?
10-27-2012, 01:08 PM
#12 |
Oddometer: 1,188
er, no...
11-04-2012, 06:56 AM
#13 |
Boxer Freak
Oddometer: 413
I know there is a thread around for this somewhere, but can't find it. I do, however, have the photos bookmarked. This is a pictoral for a '10 and up valve lash check. There is a little more to it than this if you have to change shims. For example, if your shim (semi-sphere) measures as it should and your clearance is off then something else is worn and you will need a new shim of a different size to change the gap appropriately. If the shim does not measure as it should and the gap is not correct, then there is the possibility that you need a new shim of the same size to take up the gap. Provided, of course, the valve lash change needed = difference between actual shim size and spec'd size.
11-04-2012, 01:51 PM
#14 |
Usually Just Lurking
Oddometer: 64
Here are two that I've bookmarked and found useful:
How to Rekey Vario Panniers - A Pictorial: http://www.advrider.com/forums/showt...ighlight=rekey What tools do I need to work on my bike? http://www.r1200gs.info/misc/toolkit.html BTW, great idea for a thread.
2006 R1200GS 2007 Moto Guzzi Griso Tomcat503 screwed with this post 11-04-2012 at 04:01 PM |
11-04-2012, 05:36 PM
#15 | |
Boxer Freak
Oddometer: 413
