Old 05-12-2012, 08:40 AM   #16
Qwik OP
Adrenaline Addict
Oddometer: 6,947
Guess I should've specified block off plate gasket.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 05-12-2012, 09:50 AM   #17
patrkbukly
52 Weeks of warm
patrkbukly's Avatar
Oddometer: 1,261
Fuel pump...
,....ahhhh that right...the fuel pump.
Damnit Jim.
You only live once, but if you do it right, once is enough.
Mae West
patrkbukly is offline   Reply With Quote
Old 10-26-2012, 10:52 PM   #18
666
Agnostic and Orange
666's Avatar
Oddometer: 1,319
I am getting a set of used safari tanks for my 950. How thick viton sheet should I buy? 2-3 mm enough?
2006 KTM 950 ADV; 2006 KTM 525EXC; 2013 Tiger 800 street
Moab Ride Report http://www.advrider.com/forums/showthread.php?t=629423
Dusy Ershim Ride Report http://www.southbayriders.com/forums...ad.php?t=99109
666 is offline   Reply With Quote
Old 10-27-2012, 12:09 AM   #19
Qwik OP
Adrenaline Addict
Oddometer: 6,947
That sounds about right.
Old 10-27-2012, 09:11 AM   #20
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,045
Personally I'd find a fuel proof sealer and bond that sucker on.
Unlike with the FI pump which you need to remove for filters,
on the 950's you need to install it and not have to dick with it again.
Maybe some Permatex Hylomar Blue and an adhesive backed heavy duty
gasket material. This would be removable .
Also be sure the threaded inserts in the tank are not standing proud
of the tank plastic.
I had to grind them back flush with the tank to get a good seal for my fuel pump.
Devil boy, boxed and ready to ship !
Max
Da oggi la strada
é senza limiti
MAXVERT is offline   Reply With Quote
Old 10-27-2012, 05:03 PM   #21
walstibsf
ADVENTURE-HOLIC
walstibsf's Avatar
Oddometer: 212
Aircraft grade two part internal fuel tank sealant:
http://www.aircraftspruce.com/catalo...?clickkey=4275
The NO-WORRY stuff......spendy but good......
W A L S T I B........ S F......................
what a long strange trip it's been......SO FAR......
walstibsf is offline   Reply With Quote
Old 10-27-2012, 08:43 PM   #22
Fresno
Adventurero
Fresno's Avatar
Oddometer: 616
Originally Posted by Just Paul View Post
If you know where they sell one for $800 let us know.. they are over $1600
http://www.ktmtwins.com/safari-ktm-9...40-liter-tanks
+1 anyone know where to get them less?
Fresno is offline   Reply With Quote
Old 12-03-2013, 07:02 PM   #23
daveg
no longer homeless
daveg's Avatar
Oddometer: 788
Goog led me to this thread but is failing me to find a replacement gasket. I have a gasket that looked even worse than the OP's and was steadily dumping gas all over my garage. I tried making my own out of gasket material but failed and my garage continued to smell like eau de fuel and only worked under extremely low pressures.
I just bought this bike used from a guy in Austin so I dont know much about it. She's a 950 adventure with a safari tank. Is that a unique gasket to safari or is it used on the OEM tank as well? Either way, anyone know of a place to buy a replacement? My gasket making skills suck.
Travels around the world.. or something -- RTW on a DRZ
All the way south -- Texas to Tierra del Fuego
daveg is offline   Reply With Quote
Old 12-03-2013, 07:51 PM   #24
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,681
Hmm. When mine leaked just after I changed the fuel filters, the trailside fix was a thin bicycle tube a rider had in his tool kit, which of course has been added to my tool kit, now. That was 8 months and 12k miles ago. I'm afraid to replace it!!
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 12-04-2013, 04:56 PM   #25
DirtyADV
DirtyADV's Avatar
Oddometer: 2,405
Not using a safari tank but have used a block of plate from them that I got years ago when placing 990 tanks on my 950, have not been leaking but the gasket was quite rotten when removed:
Tanks will go on the brand new 990R and the brand new tanks put aside as spares.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is online now   Reply With Quote
Times are GMT -7.   It's 07:39 PM.
