Old 10-25-2012, 09:01 AM   #1
DeeGee OP
I'm a Yorkshireman thanoz
DeeGee's Avatar
Oddometer: 1,884
Oil Traces In Airbox??
I'm just servicing the bike after our latest adventure and I've just checked to see how the air filter is as I have Pyndon's per-filter fitted. There's a fair bit of oil on the front intake. Should I be worried at all and any suggestions as to why it's done it??
A few pics below.
DeeGee is offline   Reply With Quote
Old 10-25-2012, 09:11 AM   #2
AdvGa
AdvGa's Avatar
Oddometer: 1,320
You could try this:
Bypass the Crankcase Oll Breather Hose to AirBox with a Filter and Cap the AirBox Inlet.
http://www.advrider.com/forums/showp...23&postcount=6
Also, you may have a Bad Crankcase Seal:
http://ktmtalk.com/index.php?showtopic=408017
Excess Blowby from crankcase breather, onto air filter
In my case I fixed the excess oil blowby from the crankcase by replacing "shaft seal ring 12x20x5B " part # 0760122050
avilable from munns racing online
it is located in the alternator cover and seals the Crankshaft Balancer .
if you do it you may want to order a new alternator cover gasket also
evidently the crankcase pressure is metered and vents through the crank balancer shaft .
If the seal is shot it blows major oil for some reason
mine was rock hard and shrunken . It was blowing oil everywhere , especially when doing over 90 mph sustained
fish picture courtesy of Munns " shop online" feature ;
AdvGa screwed with this post 10-25-2012 at 11:12 AM
AdvGa is offline   Reply With Quote
Old 10-25-2012, 09:56 AM   #3
DeeGee OP
DeeGee's Avatar
Oddometer: 1,884
I've got a pre filter fitted and looking at the air filter it's done a crackin' job as it looks new apart from the oil trace. Can't log onto the link for some reason
Old 10-25-2012, 10:06 AM   #4
VTwins4me
VTwins4me's Avatar
Oddometer: 153
My money is on prolonged high speed running - ie 200 miles @ 90mph?
Clean it up & look again in a couple of weeks.
VTwins4me is offline   Reply With Quote
Old 10-26-2012, 07:39 AM   #5
KEELAYMONSTER
BRRAAAAPPP!!!
KEELAYMONSTER's Avatar
Oddometer: 181
My 950 did the same. Found mine was due to a balancer shaft seal failure. The case breather port is right above this seal. Its very easy to check and replace. Just make sure you have a spare ignition cover gasket.
Kyle Montagne #141K
KEELAYMONSTER is offline   Reply With Quote
Old 10-26-2012, 07:49 AM   #6
TheMuffinMan
Forest Ranger Magnet
TheMuffinMan's Avatar
Oddometer: 6,253
This, it's easy to change. Gasket is $25, and the seal is $10 or something.
"To strive, to seek, to find, and not to yield."
"You don't cross the mountains, they let you through."
KTM 525 XC-W // KTM 950 Adventure
TheMuffinMan is offline   Reply With Quote
Old 10-26-2012, 09:56 AM   #7
scorpion
Two arm bandit
scorpion's Avatar
Oddometer: 5,419
I just ordered the parts for my fix. I'll try and take some photos when I get in there.
May install the K&N breather filter if I can get hold of one.
There was an K&N part number floating around somewhere. . .
07 KTM 990 11 Husaberg 390
scorpion is offline   Reply With Quote
Old 10-27-2012, 05:01 AM   #8
Spark01
V-Twin
Spark01's Avatar
Oddometer: 306
k&n 62-1110 this one i used
'10 990SMT
Spark01 is offline   Reply With Quote
Times are GMT -7.   It's 01:36 AM.
