Old 10-27-2012, 05:33 AM   #1
sstewart OP
sstewart's Avatar
Oddometer: 1,056
Oil tank screen
Serviced bike yesterday,my oil tank screen had small bits of rubber on it. Is this the water pump seal coming apart? None on the lower screen. No water in the oil.
sstewart is offline   Reply With Quote
Old 10-27-2012, 11:41 AM   #2
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Gray or Black?
What color is the rubber you found? The OEM water pump seal is battleship-gray, and it's the shaft that wears grooves into it which allows the coolant/oil exchange past the seal lips- the lips take a beating & wear so it needs replaced at the same time to maintain a tight seal
If the bits are black more likely cam chain guides...
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 10-28-2012, 08:13 AM   #3
sstewart OP
sstewart's Avatar
Oddometer: 1,056
Bits
They are definitely black.
Old 10-28-2012, 04:05 PM   #4
spafxer
spafxer's Avatar
Oddometer: 2,632
Inside layer of one of the rubber hoses between the scavenge pump and the oil tank?
I've had them delaminate in other applications, but don't know for sure the LC8 has rubber hose in this location.
spafxer is offline   Reply With Quote
Times are GMT -7.   It's 02:22 AM.
