Old 10-30-2012, 07:29 AM   #16756
Ryel
Ryel's Avatar
Oddometer: 214
Originally Posted by 8baller View Post
i know they have been out for a while and i cant see myself buying a new one..so i was wondering ..did they change them at all besides colors and graphics through the years?...or are there differences...if so what would be good years to look at?..and what would be good to look at when buying a used one?...thanks in advance..just dont want to buy something and be told later i would have been better off looking for this year or that year because of some performance issue or whatnot..
oh yeah..i want the S model...maybe an SM i could put some dirt wheels on
maybe this would be of some help:
http://www.thumpertalk.com/topic/642...e-drz-history/
there have been some changes from 2000-2004 so you would be best served to get a 2004-2012 model S; the SM suspension is not up to off road work. check the common fixs on the TT list and look for them on the bike you want to buy.
"Good judgment comes from experience and experience comes from bad judgment."
Ryel is offline   Reply With Quote
Old 10-30-2012, 07:35 AM   #16757
8baller
Oddometer: 26
thanks...i'll check that out as soon as i get off work
8baller is offline   Reply With Quote
Old 10-30-2012, 07:53 AM   #16758
150ron
150ron's Avatar
Oddometer: 818
It seems as tho there is NO rim lock on the rear rim of my 2007 DRZ400S? is that so?
do people add them for off road use? (rear only)
Just some dude...
150ron is offline   Reply With Quote
Old 10-30-2012, 07:54 AM   #16759
955616846
Oddometer: 1,692
Rim locks are not a standard fit on these bikes. If you want them you'll need to add them yourself, but they are not really required until pressures are dropped below 15psi or so.
I have used Tubliss with its integral rim lock on the DR-Z since new.
Cheers, Numbers
05 R1200GS, 11 TE630, 11 DR-Z462, 09 990AR, 12 R1200RT, 12 VFR800
Founding member Longtails SC
955616846 screwed with this post 10-30-2012 at 08:22 AM Reason: Edit in italics
955616846 is offline   Reply With Quote
Old 10-30-2012, 08:13 AM   #16760
ptgarcia
Huh?
ptgarcia's Avatar
Oddometer: 508
I added rim locks to my S model.
Pauly
'06 DR-Z400S
ptgarcia is offline   Reply With Quote
Old 10-30-2012, 08:50 AM   #16761
Homercules
Doh!
Oddometer: 12
kind of new to this and after much research have decided a DRZ is what i want...looked at a few different options from KTM Husky DRZ XR DR etc etc and have made up my mind this bike is about the one that suits me best...
I converted my SM to offroad and it's been great. Not sure about the fork comments...the fork is set up for road work but when set up for offroad is fantastic. I prefer it to the old school S fork personally. If there is a problem it's the larger front rotor. I put Warp 9 wheels on my SM and they are ok. Just ok. (I have to re-true the wheels occasionally and the rotor is a bit warped) Throw on a bash plate and a gps (or vapor) for a speedo and you're set. But only get an SM if you plan to use it as a road bike as well otherwise just get an S.
Here's mine from a trip a few weeks ago. I forgot to put on the bash plate before I left.
Homercules is offline   Reply With Quote
Old 10-30-2012, 09:02 AM   #16762
ifixfords
ifixfords's Avatar
Oddometer: 241
I drill an extra hole in the wheels opposite of the pre-drilled rim lock hole. Then I use two of the light weight motion pro rim locks opposite each other. With two you can drop the air down really low for extra traction.
DRZ400E Tagged
KTM200XC-W ""
Why does trespassing have to be so much fun?
2001 DRZ400E - tagged
2008 KTM200XC-W
ifixfords is online now   Reply With Quote
Old 10-30-2012, 09:44 AM   #16763
150ron
150ron's Avatar
Oddometer: 818
DRZ400E Tagged
KTM200XC-W ""
Thanks guys,
looking at the bike, there is a hole (with what seems like a rubber grommet in it) about 6 inches or so away from the inner tube stem hole, is this a hole to fit a rim lock if someone wanted too? just remove the rubber cap thing that is in there?
if it is, then i can use that one, or drill another one like suggested by fixfords, wonder why they did not include one on the bike.
Just some dude...
Old 10-30-2012, 10:12 AM   #16764
150ron
150ron's Avatar
Oddometer: 818
just to make sure, did you get the size 2.15 for the rear wheel?
Just some dude...
Old 10-30-2012, 10:18 AM   #16765
markjenn
Oddometer: 9,702
...wonder why they did not include one on the bike.
As previously said, for a dual-sport like the S which isn't likely to see ultra-low tire pressures, they're unnecessary, make tire changing more difficult, add weight, and contribute to wheel imbalance. I've only seen standard rim locks on off-road only bikes.
- Mark
Old 10-30-2012, 10:20 AM   #16766
ifixfords
ifixfords's Avatar
Oddometer: 241
Thanks guys,
That is a hole for a rim lock and I just add another one opposite of it. Suzuki does not add one to keep the cost down, and most people will not miss it. I like using two, as I set the pressure low on a regular basis for the type of riding I do.
Definitely not necessary for fire roads and light trail riding. In fact as mentioned if you don't go below 15-20 psi, you really don't need a rim lock.
DRZ400E Tagged
KTM200XC-W ""
2008 KTM200XC-W
Old 10-30-2012, 10:22 AM   #16767
150ron
150ron's Avatar
Oddometer: 818
- Mark
My previous XT250 (2009) had one on from the factory,
Maybe that is why my buddy who also has a DRZ400S always has to change his rear tubes, he runs around 10-12 psi when we go offroading, and has had like 3 flats in the back while i never had one, i will tell him to add one too.
Just some dude...
Old 10-30-2012, 10:23 AM   #16768
150ron
150ron's Avatar
Oddometer: 818
DRZ400E Tagged
KTM200XC-W ""
Great, that is what i wanted to know, thanks for clearing it up.
Just some dude...
Old 10-30-2012, 11:13 AM   #16769
blaster11
Are you a Sheeple?
blaster11's Avatar
Oddometer: 4,696
Send a message via Skype™ to blaster11
Size of fuel line
Does anybody know off the top of their head what size fuel line is on the DRZ...I can't get to my bike right now. Thanks
Bruce
IBA # 46755
Adventures of Blaster and Dorito
blaster11 is offline   Reply With Quote
Old 10-30-2012, 11:43 AM   #16770
TipsyMcStagger
TipsyMcStagger's Avatar
Oddometer: 955
Originally Posted by The Recycled Teenager View Post
So for the folks at home
Where did you purchase it and is there a number for it
Click the link in this link.
(Or just click this link )
Tipsy
2008 Buell XB12X Ulysses
2008 KTM 450 EXC-R
"There's a plane! Where there's a plane there's probably a pilot! Where there's a pilot there must be a bar! I can finally get a drink!" - Brian from Family Guy
TipsyMcStagger is offline   Reply With Quote
Times are GMT -7.   It's 01:17 PM.
