Old 10-29-2012, 01:11 PM   #2101
reenmachine
Rain or Shine
Oddometer: 549
Originally Posted by reenmachine View Post
I'm about to get a 1st gen Yamaha FZ1 (2004). Any conceivable way to adapt my 36L cases from my 2011 G650GS to it?
I'm sure it's a long shot, but it can't hurt to ask.
Originally Posted by CaribouCases View Post
Sorry, but I am not finding Hepco Becker side racks for your bike. It appears Givi doesn't make a set of "PL" type racks either. Thank you for checking.
-roger
I do see a PL349 on Givi's site for this bike. Does that mean anything?
'14 KTM 1190 Adventure
'11 BMW G650GS
'02 Yamaha FZ1
reenmachine is offline   Reply With Quote
Old 10-29-2012, 06:26 PM   #2102
rc51owner
Oddometer: 197
The rack is only about 1/2" further out on the exhaust side. The total width on the bike is 38" with a set of our 35L, 36L or 40L cases.
Thank you.
-roger
Thanks Roger and sorry for calling you Peter. :)
Regards,
M
rc51owner is offline   Reply With Quote
Old 10-29-2012, 06:36 PM   #2103
VitSports6
VitSports6's Avatar
Oddometer: 193
Another very pleased customer, Here!
I only bought 2 1550 cases with the liner and some SOLAS tape, Everything was perfect and shipped quickly.
Many thanks!
Have Fun!
Brian
VitSports6 is offline   Reply With Quote
Old 10-29-2012, 06:59 PM   #2104
CaribouCases OP
Boulder CO
CaribouCases's Avatar
Location: Adventure Rider & Aftermarket Systems Manufacturer
Oddometer: 1,225
Well, that would be great. The "PL" type part number indicates a flat-sided rack rather than the ones that curve around the exhaust. Our kit is designed for the PL type flat sided rack. I would say the only other potential issue is an interference with a passenger grab rail and our latch at the top of the rack. Spacers usually take care of this problem.
-roger
Caribou Luggage Systems.
PH: 303-786-8947 Mon-Sat 8:00am-5:00pm Mountain
CaribouCases is offline   Reply With Quote
Old 10-29-2012, 07:00 PM   #2105
CaribouCases OP
Boulder CO
Oddometer: 1,225
Many thanks!
Thank you Brian. All you need now is a top case
Old 10-29-2012, 07:16 PM   #2106
VitSports6
VitSports6's Avatar
Oddometer: 193
Agreed, but my BMW case needs to wear out first
Have Fun!
Brian
Old 10-30-2012, 02:28 AM   #2107
Chef Gareth
Live 2 Ride
Chef Gareth's Avatar
Oddometer: 239
Hey mate, I may be upgrading to a 2012 mod vstrom and wandering if your racks will fit the new model? I had the old set up on my 2010 mod vstrom, thanks hope all is well !
Chef
DL650 2012 (Travel)
DRZ400 2008 (ADV)
JR50 2006 (Daughters)
Chef Gareth is offline   Reply With Quote
Old 10-30-2012, 09:04 AM   #2108
reenmachine
Rain or Shine
Oddometer: 549
-roger
I did a little more digging, and it appears the 1st gen FZ1 is indeed covered by Hepco Becker under its Euro name, FZS 1000 Fazer. So, if I get the following racks (from you, if possible), will the cases from my 2011 G650GS fit right on with no mods?
http://www.motomachines.com/Side-Car...05_p_2289.html
'11 BMW G650GS
'02 Yamaha FZ1
Old 10-30-2012, 10:00 AM   #2109
CaribouCases OP
Boulder CO
Oddometer: 1,225
That is indeed the HB rack that our luggage fits, no problem there. That muffler comes up pretty high, and I can't tell if it is in-board of the rack, so you may want to order the cases un-drilled so you have the option to move them up a little if needed.
Thank you.
-roger
Old 10-30-2012, 10:02 AM   #2110
CaribouCases OP
Boulder CO
Oddometer: 1,225
Hi Chef,
You will need to modify them (cut and weld) in order to make our rack fit the new 2012 model. If you know a fabricator or metal worker then might get it done cheapr than buying a new rack and hardware for the back of the cases.
-rog
Old 10-30-2012, 12:15 PM   #2111
reenmachine
Rain or Shine
Oddometer: 549
Thank you.
-roger
OK, what I was really wondering was if the cases I already have, which are drilled for my G650GS, will fit right onto the racks for the FZS 1000 Fazer. I think the answer is yes in theory, but there may be an interference with the exhaust.
'11 BMW G650GS
'02 Yamaha FZ1
Old 10-30-2012, 02:06 PM   #2112
CaribouCases OP
Boulder CO
Oddometer: 1,225
You have it correct. The exhaust may not be a problem, but if it is you can drill new holes in the case and fill the old ones with JB Weld. It works suprisingly well at sealing old holes. Also, our latch brackets are bolted to the rear-most tube of the racks on the G650GS, so you will need to swap them over or buy a second set of them if you plan to use both bikes and one set of luggage.
Old 10-30-2012, 02:20 PM   #2113
Chef Gareth
Live 2 Ride
Oddometer: 239
Hi Chef,
-rog
Thanks mate, do you have some picks or instructions you could send me? I would prefer to keep your racks on the new bike I think they will be stronger then sw racks.
Thanks again!!
Chef
DL650 2012 (Travel)
DRZ400 2008 (ADV)
Old 11-14-2012, 12:46 PM   #2114
CaribouCases OP
Boulder CO
Oddometer: 1,225
New 34L Top Case Lid Organizer
Introducing our new Lid Organizer for the Caribou 34L Top Case. Two mesh pockets with zippers at one end...
Perfect for keeping small items at the ready....
Held in place by 8 screws and washers through the heavy duty backing material and into the bosses molded into the lid (the screws are all internal). Pre-installed if you buy it with the top case, but it can also be easily retro-fitted if you already have our case. Makes a good X-mas stocking stuffer too. To order, please visit the Accessories category on our web site here.... http://cariboucases.com/store/?name=...=i&item=000445
Thank you!
-roger
Old 11-17-2012, 06:13 AM   #2115
rc51owner
Oddometer: 197
Questions...
Hey Roger,
so I have a question regarding the use of the Pelican 1440 top loading cases. I know that they are listed on your site in the Hepco Becker rack section. I have a set of SW-Motech racks for my Triumph 1200 explorer. Would these cases work with the Hepco Becker adapter plate for the SW-Motech racks?
Another question: Looking at replacing the quick detach mounts on the racks and see that your lock-it kit would cost $30 to ship to Canada. For a $30 part that seems excessive. Is this really what you charge to ship the kit to Canada?
Regards,
M
Times are GMT -7.   It's 03:18 PM.
