Old 10-16-2012, 01:04 AM   #571
LukasM
Oddometer: 4,900
Originally Posted by sakurama View Post
It might not be possible due to case restrictions but hopefully he'll figure it out when he opens up my old 950 mill.
Oh it's possible. Paul from OZ built his SE into a 1090cc.
"STD 950 Se Motor is 100 x 60
Mine will be 105 x 62.4
Custom made forged pistons, HC
Crankshaft from 990 (62.4 stroke)
40mm Titanium Inlet Valves
Heads ported and flowed
Balanced and lightened bottom end
990 SD R Camshafts
It made 122.4 RWHP, up from 94 STD. Most importantly, an extra 15 Nm through the middle... It wheel-stands in 4th gear, no shit... It's apart again, being treated to 50mm Akra headers and EFI. 140 here we come!"
Keep in mind before beeing rebuilt this bike was ridden 43.000 km across all of Africa and then across Asia to Magadan.... (www.donkeyandthemule.com.au)
More info here:
http://www.advrider.com/forums/showthread.php?t=328225
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 10-16-2012, 09:44 AM   #572
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,209
Mikael thanks - I've enjoyed watching your thread as well. It's nice to finally realize some gains from all the work so far. Now I'm trying to push Chris to keep the momentum going. My bike is still in NYC for the foreseeable future and there's a spare old 950 engine just sitting there waiting to taken apart.
Lukas, I just found that last night. It's super cool and the build is very clean. There's also the German company that took a SuperDuke to 102.2mm so it seems that you don't need to modify the cases to go oversize. I would love to put this on my bike and see it go to 1089cc's because every little bit larger I go makes those big ports of mine all the more useful. Plus, I did threaten Flanny over a year ago:
I threatened to open a can of fabrication whoop ass on Flanny years ago and the time has come. Since my last update here I've aquired a mill, a lathe, a tig welder and the skills to use them. I don't have the time or money for this but that won't stop me. I'm going to build a Flannymobile killer. Get ready Beeeatch!
Gregor
Really, there's little I won't do or spend to continue opening this can of whoop ass on Flanny.
Gregor
www.gregorhalenda.com
Previously on ADV: My endless rebuild: 950 Refresh or Mission Creep My ride reports: 5 Up on Two Bikes - Long way to the Trans Lab and City Blocks to Slick Rocks
sakurama is offline   Reply With Quote
Old 10-16-2012, 09:53 AM   #573
Flanny
Flanny-it-up!
Flanny's Avatar
Location: Ottawa, Ontario, Canada, the World, the Universe
Oddometer: 2,744
Send a message via Skype™ to Flanny
Gregor
Welll...you know what they say huh? (At least in Canada). Better to have your ass whooped on the dyno then on the trail....
Flanny is offline   Reply With Quote
Old 10-16-2012, 10:24 AM   #574
CosentinoEngineering
Oddometer: 127
Lots to cover!
OK, on intake splitters I am undecided. They can induce turbulence and other flow characteristics to increase fuel mixing and burn quality but also decrease overall flow area, not just by the thickness of the plate but by introducing 2 boundary layers (on top and bottom of splitter plate). I think the more modern the engine design (more downdraft ports than sidedraft) the less a splitter will help. It also goes to show why a lot of these are done on singles with a horizontal carb. The flow having to turn 90 degrees to get through the valve introduces a lot of flow compromises that a modern v engine with its largely straight ports do not experience.
On the big bore kit I have to see what the inside of the 950 looks like. The 990 superduke engine cases may be machined differenly than the 950 engine. Ducati does it with the various 7xx thru 10xx engines. I also want to make a kit that is bore only, no stroker crank needed. That would keep kit and install price down. Reboring existing cylinders is nice but if new castings are needed it is not a big problem. Will find out and let you all know.
Gregor, did you do a photoshop drop shadow curved text addition to the engine in a crate picture?
Chris
moto2-usa.blogspot.com
Check out my products 10% off for ADV rider members
CosentinoEngineering is offline   Reply With Quote
Old 10-16-2012, 10:35 AM   #575
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,209
Yes, well, a little more than that but like I said... there's nothing I won't do, blah, blah, blah. That includes photoshop. Of course if we do a big bore kit I would like to suggest we incorporate that into the casting somehow and then offer it to everyone but Flanny. In fact we could offer these kits in "Flannymobile Killer Level 1" etc. I think that might prove popular.
That was a low blow Mr. Flanny. There will come a day when I will actually ride my bike again instead of just work on it endlessly. It is a difficult to imagine day, I will grant you that, but one that will come sooner than you'd like. You will know that day has come when you find your bike sand blasted down to the primer from the roost I will throw your way. Just sayin'.
Gregor
Old 10-16-2012, 11:02 AM   #576
Flanny
Flanny-it-up!
Flanny's Avatar
Oddometer: 2,744
Gregor
That is the best concept I have heard in a dog's age!
Old 10-16-2012, 01:33 PM   #577
brents347
KOTW 2010 Finisher
brents347's Avatar
Oddometer: 2,973
Oh! There is no HP cure for an on-the-trail ass whooping is there?
Brents347 Truckee, CA.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
brents347 is online now   Reply With Quote
Old 10-16-2012, 02:35 PM   #578
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 3,193
wurth
Seth S
Husaberg tank for sale: HERE
Seth S is offline   Reply With Quote
Old 10-30-2012, 12:26 PM   #579
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 744
Hope the dyno room and bike projects are safe from the storm surge!!
Best wishes to those affected...
KTM 950 SliderMoto with 19/17 spokes, FCR41's, 2-into-1 high pipe, single side front brake and handcut flattrack style tires. Gettin Slideways is good!
justin@giantloopmoto.com
www.giantloopmoto.com
snowhawk jockey is offline   Reply With Quote
Old 10-30-2012, 04:15 PM   #580
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,209
Fortunately our shop is on the third floor so while I haven't heard anything directly I'm pretty sure it's all fine there. However a friend who has a motorcycle garage across from my old East Village apartment (and where I used to park my 950) sent me a few photos from last night...
This is near the intersection of 8th Street and Ave C so not all that near the water. Pretty amazing the devastation and when you see this and realize that it's up and down the whole coast the cost to repair/replace the homes and cars and property will be beyond staggering.
Gregor
sakurama screwed with this post 11-05-2012 at 05:27 PM
Old 10-30-2012, 04:31 PM   #581
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,864
Wow, Very sad to see this.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products.
www.outriderjournal.com FREE STUFF!!
cjracer is offline   Reply With Quote
Old 10-30-2012, 07:01 PM   #582
snowhawk jockey
Slack Jaw Gaper
Oddometer: 744
Thanks for the update and I am very thankful to hear there is no physical loss or injury! Of course, I am very sad to see the poor ponies in their stable, up to their axles in salt...
All the best to anyone affected and reading this!
Old 10-31-2012, 04:52 PM   #583
slidewayes
slidewayes
slidewayes's Avatar
Oddometer: 261
plus1
slidewayes is offline   Reply With Quote
Old 11-05-2012, 03:28 PM   #584
sakurama OP
on an endless build
sakurama's Avatar
Oddometer: 1,209
So Chris is fine but the shop has been without power for the last week so everything has been on hold back there. My job that was supposed to start next week got postponed until the week after Thanksgiving so I'll be flying in on my birthday and will get my bike swapped over to the production intakes then and spend the week riding it while I'm there and then do the 41 swap the following weekend so I get a day to see what that feels like.
Gregor
Old 11-05-2012, 04:47 PM   #585
HappyGoLucky
Goeie Grys Giftige Gert!
HappyGoLucky's Avatar
Oddometer: 4,295
Gregor
Tried this in two diff browsers, just got a jpeg.
To thine own self be true....
HappyGoLucky is offline   Reply With Quote
Times are GMT -7.   It's 03:52 PM.
