Old 10-27-2012, 02:36 PM   #1
OlyRider OP
Oddometer: 1,275
Top & Bottom Rear shock mounting bolts torque?
F800GS
I googled, but I couldn't find it.
Seems to me top bolt is 100nm?
Is bottom bolt the same?
Found out using a bunch of loctite on these is a very bad idea! *That* was a pain! What should I do re-installing them? A *drop* of low-strength?
Olyrider
Ob-la-di...Ob-la-da
OlyRider is offline   Reply With Quote
Old 10-27-2012, 07:05 PM   #2
Snowy
Oddometer: 1,765
I used Locktite every time, and then got sick of it when the bolt bent and it was painful to remove.
I started using anti seize with the Locktite.. Now I only use anti seize.
Hasn't come loose yet. Torque wise it'd be around 100Nm. Or tighten...grunt...creak...grunt...yeah that'll do.
Snowy is offline   Reply With Quote
Old 10-30-2012, 08:10 AM   #3
Wildman
In my castle
Wildman's Avatar
Oddometer: 18,067
http://www.advrider.com/forums/showp...5&postcount=89
Ridden; GBR CYM DEU FRA ESP AND MCO ITA BEL SCT LUX CHE SMR LIE AUT NLD POL LTU LVA EST SWE FIN NOR DNK CZE SVK HUN ROU BGR GRC MKD SRB ALB MNE BIH HRV SVN MYS IRL BRA MAR PRT ARE USA ISL JPN MLT Planning; AUS TUR MDA UKR MEX BLR MNG RUS KAZ TJK KGZ SEN ZAF ZMB MWI NZL IND CPN
Wildman is offline   Reply With Quote
Old 10-31-2012, 08:20 AM   #4
malloy
Oddometer: 732
There are those who say when using loctite reduce the torque some: http://advrider.com/forums/showthread.php?t=661607
F650GS (Build Date 11/11)
malloy is online now   Reply With Quote
Times are GMT -7.   It's 06:14 AM.
