Old 10-31-2012, 08:58 AM   #1
swanker OP
Shadetree Tinkerer
Oddometer: 148
Question '83 flywheel and clutch "Plug N Play" on a '78???
Inspired by a reply in this thread http://www.advrider.com/forums/showthread.php?t=837268 I thought I'd start a new one to specifically find out what is involved.
It caught my eye because I have a '78 R100/7 and also a '83 R80RT parts bike and have been interested in lightening the R100 flywheel.
Could this be nearly as simple as a swap out?
I'm noticing a fair amount of false neutrals especially from 3rd to 4th and 5th to 4th, 4th to 3rd which having a spare tranny/clutch on hand makes me even more intriqued.
Thoughts?
Originally Posted by craydds View Post
I need a new real main seal and clutch/pressure plate, also. I was thinking about the Southland clutch rebuild, but tell us all about the late model "no flywheel" set-up. I have a '75 R90S. Is it a simple parts replacement process? Buy the late model clutch carrier, clutch plate, etc., and "plug-n-play"? Any machining involved?
from http://www.advrider.com/forums/showthread.php?t=837268
swanker is offline   Reply With Quote
Old 10-31-2012, 09:01 AM   #2
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,131
It would take swapping the flywheel (called a clutch carrier on the newer ones) clutch pack, and transmission. Sounds like you've got all the parts - go for it!
Wirespokes is online now   Reply With Quote
Old 10-31-2012, 09:33 AM   #3
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,373
You don't really have a spare transmission, wording is tricky. The '78 R100 bike has a long input shaft transmission. The '83 R80 bike has a short input shaft transmission. The two transmissions go with their respective flywheel/clutch set ups. You can change the transmissions if you also change the flywheel/clutch. So sounds like you get what you want out of this. The lighter clutch carrier and a working transmission.
The lighter clutch swap is a performance improvement many desire. I'm not sure but you may notice some more engine vibration.
---Albert Einstein
Old 10-31-2012, 10:23 AM   #4
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,498
Most people note the revvier feel the lighter clutch carrier gives, but I'd say the bigger benefit is lighter lever pull and a clutch that's not right on the edge of slipping (if not slipping) when you "give it the beans." It's just a better functioning clutch as well, not just lighter.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 10-31-2012, 12:40 PM   #5
supershaft
because I can
Oddometer: 9,116
Night and day better IMO.
Old 10-31-2012, 01:40 PM   #6
Beater
Airheaded, eg Simple
Beater's Avatar
Oddometer: 3,252
+1. I love the looks of those /5's and /6's ... but after riding a monolever, I'm sold on the technology. It's a night and day better ride.
Fred
'85 R80RT G/Sified <|> '73 R75/5 LWB
Simply Simple and getting more so.
Beater is offline   Reply With Quote
Old 10-31-2012, 02:11 PM   #7
carpetburn
Oddometer: 129
Definately worth the swap
carpetburn is offline   Reply With Quote
Old 11-01-2012, 08:33 PM   #8
supershaft
because I can
Oddometer: 9,116
Originally Posted by beater View Post
+1. I love the looks of those /5's and /6's ... But after riding a monolever, i'm sold on the technology. It's a night and day better ride.
+1
Besides, I honestly like the looks of a Monolever more than a /5 or /6. When I look at /5's and /6's, I can't get over how much better a Monolever works.
Old 11-01-2012, 10:42 PM   #9
mattcfish
R90SS/6
mattcfish's Avatar
Oddometer: 228
I agree, the post 81 clutch is much better and performance is improved. I did it to my 75 R90 using an 83 tranny.
Another reason an early, long nosed input, tranny doesn't work well with the later clutch, is the travel for the clutch activating rod is too short. The later trannies have a much different lever and rod configuration.
And don't forget that you need a 9 tooth starter.
mattcfish is offline   Reply With Quote
Old 11-02-2012, 01:57 AM   #10
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,478
Measure the flywheel height at the center and see if it is the same as you 78 flywheel. If not you will have to change out the thrust washer to insure you have the correct end play. This is a fantastic conversion. I just did one on a 76 /6.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Times are GMT -7.   It's 11:56 PM.
