Old 10-24-2012, 10:21 AM   #2821
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,047
Originally Posted by sanjoh View Post
I would not hesitate to run the lights over any terrain. All interior components are secured. Many customers are running the drop in lights as their primary light, failure is not an option.
I've run the SE a couple of thousand miles in the last month thru everything from single track to the slab, without issue (except the fuel milage sucks).
Where did you get the fairing with the dual lights.
It would be perfect on my 690, with your lights of course.
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 10-24-2012, 11:08 AM   #2822
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,367
Max
Here ya go. Not on the website yet, give em a call or email for details. Available in black or white.
John
9549935581
sandjoh@gmail.com
ADVmonster...BLOG....Dirt Ninja Build...TAT 08
Old 10-24-2012, 02:51 PM   #2823
SpeedyK
Lone Rider
SpeedyK's Avatar
Oddometer: 330
Model 30s will work fine for you. You should consider one of our LED controllers. Let's you set a dimmed setting for being seen (you will need to dim them at night in traffic) and gives you full power with a flick of your high beam switch. We also offer a free PnP harness when you buy a set of lights with a controller.
Thank you.
Quate, Crepa, Rota
SpeedyK is offline   Reply With Quote
Old 10-24-2012, 09:37 PM   #2824
farrington300
No wait....What?
farrington300's Avatar
Oddometer: 527
Just ordered the husky drop in headlight, a couple of 60s, and some hd brackets for another bike. Lookin forward to some night rides this winter.
TE610
WR250R
farrington300 is offline   Reply With Quote
Old 10-25-2012, 06:17 AM   #2825
michigan400
Oddometer: 115
Model 44 and Model 30 night shots
OK, so I scrapped the Trail Tech X2 and LED idea. Could not aim the lights well and I figured air flow would be a big problem in the summer the way the backs are enclosed. I put the stock H4 headlight back on so I have a regular, traffic friendly low beam. I then mounted the Model 30 on the left hand guard and a Model 44 on the right, both with small pcs. of aluminum angle.
1st set of pics came out looking brighter than what you actually see but not by much. The 2nd set shows very accurate color and brightness but the focus is all blurry but you get a good idea between the 2 sets. Either set will show these lights make a tremendous difference in your ability to see at night. Just the 2 LED's (1 30 and 1 44) are enough to ride with at night on the street and be comfy going 50-55mph. Great lights at an even better price!! Thanks, ADVmonster! Oh ya,, these guys will have whatever you order on your doorstep by the time you close the your browser from ordering. Super fast delivery.
H4 low beam shown. 1st pic is to bright, 2nd is correct but blurry.
H4 high beam. Same deal, 1st is showing bright 2nd is correct color and brightness but blurry.
1 Model 44 only. Same deal as above pics
1 Model 44 and 1 Model 30. Same thing.
H4 high beam, 1 Model 44 and 1 Model 30. Same thing.
michigan400 is offline   Reply With Quote
Old 10-25-2012, 09:41 AM   #2826
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,230
getting darker quicker
Went riding after I got off work, and found myself coming back to the 4Runner after the sun had gone down. I quickly realized that I needed more light than the TrailTech X2 lights were giving me.
I just placed an order for one Model 60 Off-Road Flood Light, and one Model 30 Off-Road Spot light. I figure with one light on each side of the KTM 500's Fork, this should give me plenty of light for the short range and the long range. These of course will be in addition to the TrailTech X2 lights that are always on.
Using the HDB Top Clamp mount, I have room for 4 push-button switches, that can control each light separately. In addition to this setup, I have a relay that is already in play that will be used to control the lights, so nothing gets burned out or shorted out.
When these come in, I add my schematic to the existing 2012 KTM 500 EXC wiring schematic and post up for others to use....
NMOHVA.ORG - Help to keep your trails open!
Life is a mist in the wind, here today and gone tomorrow; know who you are and where you are going after you pass through death's door.
SteveO is offline   Reply With Quote
Old 10-25-2012, 10:38 AM   #2827
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,367
Thanks for your business.
You could easily ditch the X2 for our dualsport fairing. A pair of model 60s is all the light you will need. I've had a couple of customers switch from the X2 and are extremely pleased.
Old 10-30-2012, 07:18 AM   #2828
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,367
Recent quote from an ADVmonster Customer
"Told you I'd do business again - Friend needs eyes of god."
Old 10-30-2012, 09:22 AM   #2829
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,752
WR250R Install
Got my lights installed yesterday. Here's some pictures of how my install went on my WR250R.
Installed the dimmer on my HDB Top Plate. Was gonna wire in a fancy button switch, but since that has an "off" detent, figured might as well just use the Rotary Dial to control everything.
I attached it with Velco in case I need to move it later.
Used the reflector mounts to mount the lights. Clears the shrouds just fine here. Hopefully they aren't too vulnerable at this location.
Low - Just barely "On". Plan on using this setting during the day to help visability. Note can turn lights off, by just turning the dial to "Off".
High - Tied into High Beams, so Clicking my High Beam Switch turns these on full 100% (Aka High Beam Bypass). Can also just turn the dial up 100%to have them on 100% regardless of dimmer switch setting. Note - The headlight is "Off" right now because the bike is not running. On WR's the light only comes on once you start the bike. Aux lights work on separate power - the High Beam Bypass does not work unless the bike is running, but the Dial still does to adjust the brightness.
So far, so good. Next step, test these suckers off road during the wet winter.
-= Scott
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is online now   Reply With Quote
Old 10-30-2012, 10:10 AM   #2830
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
You might be able to flip the signal brackets over and/or swap sides to bring them up inside the tank ears for more protection!
Low594 is offline   Reply With Quote
Old 10-30-2012, 10:41 AM   #2831
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,752
Tried that, and also tried flipping the mounts on the lights etc. all hit the radiator etc. Other alternative was to mount them higher off the top triple tree, but that had its own set of challenges.
It's not BAD where they are now, just not sure what to expect if when/go down. There are actually cut-outs in the tank shroud that makes a nice pocket for these when I turn. Also that reflector bracket may be a good sheer point in a crash vs. breaking the lights - it's pretty thin.
Old 10-31-2012, 08:45 AM   #2832
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,367
-= Scott
Nice install!
Old 10-31-2012, 08:36 PM   #2833
subagon
Hopelessly lost
subagon's Avatar
Oddometer: 571
sanjoh,
Will you be at the BMWNEF Winter Rally in January? Just added a R100RT to the garage and it needs some help in the lighting department.
Mike
Antioch, FL - Hopelessly lost, but making good time
Bike picts
subagon is offline   Reply With Quote
Old 11-01-2012, 07:16 AM   #2834
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,367
Originally Posted by subagon View Post
sanjoh,
Yes, I plan on being there. Hope we get a duplicate of last years weather
Old 11-01-2012, 11:43 AM   #2835
hunter151
Oddometer: 67
Just ordered a pair of the 44 flood lights. Should improve the 30 year old inadequate lighting on my Nighthawk quite well.
hunter151 is offline   Reply With Quote
Times are GMT -7.   It's 12:11 AM.
