Old 10-31-2012, 07:38 PM   #1
mfp4073 OP
mfp4073's Avatar
Oddometer: 2,369
Testing the charging system question 74 /6
On the way home tonight my charge light came on bright and wouldnt go off. Tested the battery and has 12.2 charge. When testing the charging with engine running it still tests about the same. So I turned to the clymers manual and am a little confused about the testing they say to do. Its first test is between the diode board and the alternator. B+ terminal and D+/- terminal at the alternator. Instructions say to remove the connector plug (seems to mean the outer one as there are two) from the diode board then start the bike. When I remove this wire, the bike is dead, no power to starter, lights or anything. Am I missing something here or does that tell me something?
Not my pic, but the F tab on the right is where it says is the B+ terminal and the outer wire is what is supposed to be removed. I also tried removing the inner wire and then both wires to the same results. What am I missing here?
thanks in advance.
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. Thatís the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is offline   Reply With Quote
Times are GMT -7.   It's 01:34 PM.
