Old 10-31-2012, 08:36 PM   #2836
subagon
Hopelessly lost
subagon's Avatar
Oddometer: 570
sanjoh,
Will you be at the BMWNEF Winter Rally in January? Just added a R100RT to the garage and it needs some help in the lighting department.
Mike
Antioch, FL - Hopelessly lost, but making good time
Bike picts
subagon is offline   Reply With Quote
Old 11-01-2012, 07:16 AM   #2837
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
Originally Posted by subagon View Post
sanjoh,
Yes, I plan on being there. Hope we get a duplicate of last years weather
Old 11-01-2012, 11:43 AM   #2838
hunter151
Oddometer: 63
Just ordered a pair of the 44 flood lights. Should improve the 30 year old inadequate lighting on my Nighthawk quite well.
hunter151 is offline   Reply With Quote
Old 11-01-2012, 01:47 PM   #2839
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
Thanks for your business.
You might actually want to ride at night
Where are you planning on mounting the lights?
Old 11-01-2012, 03:08 PM   #2840
hunter151
Oddometer: 63
I was thinking of mounting them a bit under the headlight, something like so:
Im noticing a lot of the street tourers are mounting these down by the front wheel. Is this advantageous to avoid blinding people? Any particular advantages/disadvantages of mounting high or low?
Old 11-02-2012, 05:10 AM   #2841
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
Higher the light is mounted on the bike the better. Just a bit under the headlight should work great.
The theory on mounting lights low on the fork is that it creates a triangle of light that has a larger pattern which helps others see you. After some 60k miles behind these lights on all sorts of wheeled vehicles, I can tell you that the sooner someone see the lights, the sooner they will recongnize a vehicle, to me that means mounting them as high as possible. As a benefit you can see much further with the lights mounted high.
Old 11-02-2012, 07:29 AM   #2842
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,054
The lower down you mount lights, the more they show the shape of the surface by throwing shadows of the bumps/dips/obstacles. The higher up, the farther you can effectively throw the beam, but the less surface highlighting you get.
For visibility by others, the more different the pattern of the lights, the more likely they are to notice you. Mount one low/left, another mid/right?
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is offline   Reply With Quote
Old 11-02-2012, 11:22 AM   #2843
DirtRider....
Wandering Turtle
DirtRider....'s Avatar
Oddometer: 282
Do u have a light pattern pic for the battery powered helmet light??
DirtRider.... is offline   Reply With Quote
Old 11-02-2012, 12:00 PM   #2844
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
Here you can barely make out the wall on the other side of the field (roughly 75 yards).
Old 11-03-2012, 05:34 PM   #2845
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
Beautiful day for a ride in Central Florida
Old 11-04-2012, 03:17 AM   #2846
Sunday Rider
Adventurer Wanabe
Sunday Rider's Avatar
Oddometer: 778
[QUOTE=sanjoh;19963474/QUOTE] Beautiful day for a ride in Central Florida
Looks great, but we want the same picture at night showing off the lights, and how they can spot an alligator 10 miles ahead
'97 Honda ST1100
Sunday Rider is offline   Reply With Quote
Old 11-04-2012, 01:32 PM   #2847
marcopolos
Oddometer: 10
Help
Installed some 60s with skene design hq70 dimmer and trail tech 3 position switch as outlined on his website with the alert feature button. Ground to frame 12 volt lead horn. When I turn on ignition they just flutter. And do not enter program mode. Any ideas? I hope it has nothing to do with led rear blinkers I bought off eBay that pulse faster than usual.
marcopolos is offline   Reply With Quote
Old 11-04-2012, 09:23 PM   #2848
marcopolos
Oddometer: 10
Nvmnd. I switched to another 12 feed and it is stable now.
Programmed with trailtech switch.
low=20% (for night (safe setting)
mid=40% (gonna try it for night, see if I get flashed alot from on coming, if I do go back to 20%)
high= 70% (for Sunny bright Days)
Highbeam shoots them to 100%.
Problem though is my ferring guards. I cannot lower the light to adjust them from shining into the trees.
I cannot angle the lights too low or they hit the guards and I can't turn. I laid the klr down a few times and bent the guards..
Old 11-04-2012, 10:21 PM   #2849
marcopolos
Oddometer: 10
Old 11-05-2012, 08:26 AM   #2850
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,134
Try shimming the light mounts or flip them in bracket which will move the light back a bit.
And try to avoid the laying down part I know the KLR has a love affair with gravity
Times are GMT -7.   It's 08:02 PM.
