Old 11-02-2012, 02:28 PM   #16
LanceR75 OP
LanceR75's Avatar
Oddometer: 44
Originally Posted by disston View Post
If you bent the housing you will probably have to post some pictures so we can see the damage. This is not good.
Start with, just which jet was stuck? Or is it still stuck? The idle or the main jet? It sounded to me like the idle jet because you said you were using a screw driver.
Then again the idles mix screw is made of steel and this may be more prone to being stuck. But all of the jets can be stuck at different times.
Going slow, not hurrying. Using Heat and a good corrosion attacker, Kroil is the best in my book but there are others.
It was/is the idle jet. I took it in to a local "carb guy". I asked him to dunk the carb body as it is pretty grimey. He said he can get it out but it will most likely need to be drilled out. He was actually worried that I couldn't find another jet. I'll post pics of the bottom of it when I get it back.
Thanks for all of the input/info, y'all.
LanceR75 is offline   Reply With Quote
Old 11-02-2012, 03:13 PM   #17
JonnyCash
turd polisher
Oddometer: 802
getting a new jet won't be any trouble. Any BMW parts supplier can get it to you.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is online now   Reply With Quote
Times are GMT -7.   It's 02:13 PM.
