Old 10-30-2012, 12:33 AM   #1
bens109 OP
Oddometer: 47
New Denali DX1 lights - any info?
I was looking at the Denali lights from twisted throttle today and there is a reference to a DX1 model which is apparently brighter than the D2s that I was going to buy.
Scroll down to the bottom of this page and there is a comparison which mentions them. There is nothing on the twisted throttle site and a quick google dosen't turn up anything either.............
bens109 is offline   Reply With Quote
Old 10-30-2012, 08:46 AM   #2
KingOfFleece
SplitWeight(tm)
Oddometer: 879
Every time I call their tech support it's a good experience.
Might try that.
KingOfFleece is offline   Reply With Quote
Old 10-30-2012, 10:28 AM   #3
rick3foxes
rick3foxes's Avatar
Oddometer: 105
Well, I'm confused.
I have the (round) Denali D2D lights. Supposedly much brighter than the (square) older D1 model.
According to the web page, the newest, brightest lights are the DM1:
The Denali DM1 Micro LED Light Kit is the newest addition to the Denali line of LED Lighting from Twisted Throttle. Don't let the small size and weight fool you, with an effective beam distance of 240 feet, these little buggers are BRIGHT!
But, the photo comparison doesn't seem to match the description:
Alaska blog: www.rick3foxesalaska.blogspot.com
IBA #34583
2003 Connie
"...I have promises to keep, and miles to go before I sleep." - Frost
rick3foxes is offline   Reply With Quote
Old 10-30-2012, 02:18 PM   #4
Builtdesign
Oddometer: 2
Hmmm....I'm not seeing it either. Maybe they're comparing size to output ratio?? To me the D2's make more sense as an auxilary light to provide a broad area of light (esp for the twisties), then just use the high beam if you need more distance... Thanks for the comparison pic
A superior rider is one that uses his/her superior knowledge to avoid situations that would require the use of his/her superior skills.
Builtdesign is offline   Reply With Quote
Old 10-30-2012, 04:21 PM   #5
TomVT
Oddometer: 1
Called Twisted Throttle today and asked about the Denali DX1. Person there wasn't able to provide any information, not even an issue date.
TomVT is offline   Reply With Quote
Old 10-30-2012, 10:22 PM   #6
rxcoop
persnickety curmedgeon
rxcoop's Avatar
Oddometer: 1,671
probably the janitor....they had on their FB page that they were going to be closed due to storm.
try back after weather clears...have always had good luck with their support team.
Bill Cooper (dba "drug dawg")
94 Miata M-edition, 12 vstrom 650a,
10 Trek fx7.3
<applicant for "Official Pharmacist of the Rock and Roll Hall of Fame" (r)>
rxcoop is offline   Reply With Quote
Old 11-03-2012, 03:34 AM   #7
kojack
My Hardley is a POS
kojack's Avatar
Oddometer: 970
Well, I'm confused.
I see it. You can't have both. Especially with led lights. With led, you can have wide or long beams. The dx is a long range light, therefore the beam will be narrow. Exactly what I'm looking for to spot big brown speed bump in the night also known as moose. Wide close up light matters not to me.
Sent from my ARCHOS 80G9 using Tapatalk 2
kojack is offline   Reply With Quote
Old 11-03-2012, 10:26 AM   #8
Ohio_Danimal
Midlife Crisis Man
Ohio_Danimal's Avatar
Oddometer: 646
Support your fellow Inmate
http://advrider.com/forums/showthread.php?t=607184
MUCH better value than the Twisted Throttle's overpriced stuff.
Dodging cages since 1976
Ohio_Danimal is online now   Reply With Quote
Old 11-03-2012, 05:48 PM   #9
KingOfFleece
SplitWeight(tm)
Oddometer: 879
Talk to Jim Hamlin, the new store guy at TT. Comes from a 20+ year background in bikes and is a master mach. as well as a top notch suspension guy.
There's lots of good folks on this forum and I try to spread it around some.
KingOfFleece screwed with this post 11-04-2012 at 03:40 AM
Old 11-03-2012, 06:06 PM   #10
MJS
MJS's Avatar
Oddometer: 1,928
If you're going to spend that much coin, why not just get the BD Squadron LEDs?
(no connection other than spending to much time comparing lights)
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS is offline   Reply With Quote
Times are GMT -7.   It's 09:03 AM.
