Old 05-15-2012, 05:40 AM   #256
garabato25
garabato25's Avatar
Oddometer: 90
Originally Posted by Kainic View Post
Nice looking bike. Are those happy trail boxes? What size?
Thanks....the boxes arw custom made 6" and 8" by Desert Snake Offroad. They're awesome, just did a 1600 mile trip to BOA Rally in Hiawasse with 40% offroad and a few falls, couple of trees and not a problem
Cheers
Alex
Xplor the world....One ride at a time....Reflective Decals www.photobucket.com/arwdesigns_decals
2012 F800GS Trophy
2008 R1200GS Adventure - Magma Red :)...SOLD
BMWMOA # 138991
garabato25 is offline   Reply With Quote
Old 05-15-2012, 08:09 AM   #257
Singletrack_mind
Cave Man
Oddometer: 419
Originally Posted by HappyHighwayman View Post
Why do you guys prefer mounting your lights level with your existing headlights? I'm going to fender mount mine so that they move when I turn and create a light triangle.
Just curious!
As already stated,mounting up high reduces potential for damage when dropping the bike, but there's another reason I place mine there: The closer to the ground the lights are, the more they are going to exaggerate the irregularities in the surface ahead of you. This can tend to make big black shadows behind every bump, so it get's hard to tell what you are really dealing with. With the lights at headlight level you still get a sense of the topography of the surface you are about to ride, but with fewer "OMG, is that a bottomless pit??" moments.
Singletrack_mind is offline   Reply With Quote
Old 05-15-2012, 08:25 AM   #258
albany23
Aficionado
Oddometer: 77
Very good point, noted. I'm glad i went for the TT kit. I could hae chosen TrailTech, but risers say they're not fully waterproof. The TT ones were tried and tested by a friend of mine from Romania to Mongolia and back. Crash testing them in the tundra brought very good results. It's true, they are 2x55watts, compared to the TrailTech LED's, but the buke can handle that.
" 'cause tramps like us,
Baby, we were born to run. "
<a href="http://jupiterstravellers.org" target="_blank"><img width="120" height="60" border="0" src="http://jupiterstravellers.org/buttons/linkbutton_120x60.jpg" alt="The Ted Simon Foundation" title="The Ted Simon Foundation" /></a>
albany23 is offline   Reply With Quote
Old 05-23-2012, 11:39 AM   #259
epicxcrider
epicxcrider's Avatar
Oddometer: 645
Dually Flood lights on a home-made mounting plate. Made the switch housing too.
Old 05-23-2012, 12:36 PM   #260
rockinrog
rockinrog's Avatar
Oddometer: 2,897
Nice work Jax ----don't forget to plug them in.
rockinrog is online now   Reply With Quote
Old 05-23-2012, 02:48 PM   #261
Mark or Jack
BMW F 800 GS
Oddometer: 129
One high, one low?
Do any of the lighting options other than Touratech offer a high and low light?
I would like one light to come on automatically with my high beam and one with my low beam, aimed accordingly to not dazzle oncoming traffic but give me better light.
I have ordered a One Off HID replacement for the stock low beam so once I have that installed my question may be redundant if it is good enough.
If that is the case I will probably want both auxiliary lights on the high beam.
Cheers, Jack
my website
Mark or Jack is offline   Reply With Quote
Old 05-23-2012, 06:33 PM   #262
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,205
If the $$$ don't you might consider the Clearwater Kristas.
They infinite dim down to 20% with instant 100% via hi beam switch. Work well, lots of led light. My install post is a few pages back.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 05-24-2012, 12:38 AM   #263
Mark or Jack
BMW F 800 GS
Oddometer: 129
Yep, that's what I am chasing.
Now to look into mounting options.
Thanks very much.
my website
Old 09-11-2012, 07:10 AM   #264
TFB43
TFB43's Avatar
Oddometer: 66
Rigid?
I have searched and can't find the post where someone installed the Rigid LEDs using only the provided brackets to the headlight bolts... Is this possible? Picture? or was this just a late night search that I dreamed up . Really liked the Desert Snake set up, but their plasma cutter is on the fritz and being repaired. Thanks
TFB43 is offline   Reply With Quote
Old 09-15-2012, 11:15 AM   #265
TFB43
TFB43's Avatar
Oddometer: 66
1200 gs Auxiliary Wiring Harness on f800gs?
I am wondering if anyone has used the 1200gs wiring harness kit on the f800gs? I have installed the rigid lights and have enough wire on the provided harness to wrap around the world. Done the search nothing comes up. Anybody?
Old 10-14-2012, 10:17 AM   #266
iJabberwocky
iJabberwocky's Avatar
Oddometer: 219
Rigid dually
I just ordered a pair of Rigid Dually and am using the PIAA wiring harness on my 2012 F800GS. Any hints, ideas and tips that I might need to know when installing. I have a bracket to attach on the side of the headlight mounting screws. I plan on wiring direct to the battery. Can I wire this into my accessory plug that is in the battery compartment? I currently have my GPS connected to this right now and know the lights put out 1 amp each which will keep me under the 5 amp Canbus requirements. Any ideas? Thanks.
Iakona
2011 KTM 990 ADV R
iJabberwocky screwed with this post 10-14-2012 at 06:12 PM
iJabberwocky is offline   Reply With Quote
Old 10-14-2012, 03:33 PM   #267
epicxcrider
Oddometer: 645
I'd just wire em right to the battery, got the same ones on my f8. Don't think I'd go through the GPS plug though.
Old 10-14-2012, 03:49 PM   #268
Sutherngintelmen
around the bend
Oddometer: 1,205
Rigid Dually's have mass. Techmounts to crash bar set up failed on my last trip. One, then the other with another 30 hours riding.
I decided to try something permanent. Nylon saddle washers with 8mm x 1.25 x 55mm SS hex bolts drilled through crash bar cross brace. I coated holes with paint then sealed with silicone to keep things from rust in the long run (and rattle canned the saddle washers.) Very cost effective. Yes, I weakened the cross member some.
I've got the Clearwaters mounted on the thin gauge steel plate - I think Ezmount? Don't know if it's stout enough for Dually.
Couple of things - I'm an aux light ho. Always have been. I like light: see and be seen. Too much? Maybe. Nice to have amber markers in pre dawn fog. Clearwaters punch a long way out and dim to 20% with instant 100% on high beam.
And yes - straight to battery for wiring.
Techmounts fail
Custom
Off
Melt
Old 11-03-2012, 11:49 AM   #269
lunaticTR
lunaticTR's Avatar
Oddometer: 97
Mine is right here
I got my rear end covered. I have hella ff50s in the front. No pics yet.
http://youtu.be/k-VlVv3xXOw
2008 BMW f650 GS Twin
2006 Regal Raptor
lunaticTR screwed with this post 11-04-2012 at 10:14 AM
lunaticTR is offline   Reply With Quote
Old 11-03-2012, 06:28 PM   #270
biodieselandon
biodieselandon's Avatar
Oddometer: 358
Techmounts fail
Did you get a Clearwater specifically for your bike? I was on their website looking for mine and it seems like after a certain year they don't show anything. Mine is a '13 so I will probably have to wait even longer. I really want something that integrates into the CANbus system.
Also, I am not sure about the previous years, but my F8 has what appears to be a cutout for a fog light switch on the left side switch block and also I can see a fog light indicator in the instrument cluster. Anyone know if that is something that can easily be used?
A little input from me: I hit a deer about a month ago on my 2013 F800 a week after I got it. I came up over a hill and I could not see the deer until it was too late. Aux lights may have helped prevent this. The stock headlight is on the F8 is not very good IMO. The one on my G650GS was way better. Eventually I will update the headlight to HID as well.
2013 BMW F800GS, Cordoba Blue, ASC, ESA, ABS
2012 BMW G650GS - 13,000 miles ***SOLD***
"If you're not mixing gas, you're not hauling ass!"
"A clean GS is a dirty shame."
biodieselandon is offline   Reply With Quote
Times are GMT -7.   It's 05:05 PM.
