Old 11-03-2012, 03:47 PM   #1
Hootowl OP
Oddometer: 1,254
Shock Pre-Load Adjuster Oil
Looking for the amount and type of oil that can be used for '07 990A
Richard
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is online now   Reply With Quote
Old 11-04-2012, 02:06 AM   #2
Peanuts
Peanuts's Avatar
Oddometer: 1,565
The preload adjuster is mechanical....
the shock body has oil in it, that has to be bled and refilled on a proper suspension rig to get all the air bubbles out. Good KTM dealers and WP agents have the rig.
Peanuts is offline   Reply With Quote
Old 11-04-2012, 06:05 AM   #3
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,127
I thought its only the SE which has the mechanical pre-load adjuster screw and the adjuster (with the turn - handle) on the Adv are hydraulic ?
GO !!! Berglund brothers #148 #149
GO !!! CS Santosh #59
Vicks is online now   Reply With Quote
Old 11-04-2012, 08:05 AM   #4
Hootowl OP
Oddometer: 1,254
The pre load adjuster mechanism does (or did on mine) have oil in it.
'07 990A
'12 Super Tenere
Old 11-04-2012, 09:49 AM   #5
Peanuts
Peanuts's Avatar
Oddometer: 1,565
Really? Why the hell do they make it so complicated? I am please I did not try removing the movable part to clean under it!
Old 11-26-2012, 07:09 PM   #6
James Siddall
suspension guy
James Siddall's Avatar
Oddometer: 176
Hydraulic preload Adjuster
We use shock oil. Ohlins 1309-01 in our case.
The amount is more difficult to say as the process of bleeding the air out is complicated. Sufficient oil to move the spring seat through the full range. Less than 400cc is easily enough.
The large O ring seal gets dirty and fails on those. Sometimes the pivot bolt backs out as well.
Cheers
James
www.superplushsuspension.com
Never argue with stupid people, they will drag you down to their level and beat you with experience.
James Siddall is offline   Reply With Quote
Times are GMT -7.   It's 09:41 AM.
