Old 11-03-2012, 11:19 PM   #1
640Pilot OP
640Pilot's Avatar
Oddometer: 98
Wheel Balancing
Guys just a quick question,
I've just finished setting up my spare set of drop on wheels for the 950 with my off road tyres, 908RR front, Mitas E09 Enduro rear....just wondered before fitting what you guys do for balancing.
The standard Scorpion 50/50's that were on the bike when I got it aren't balanced and even at speed it doesn't seems an issue, so I'm guessing just get em on and go hard...is that the norm...?
Ride Safe, orange side toward the sun
950 Adventure
FE 550 Husaberg
82' FXR Harley Davidson
So much dirt...so little time...
640Pilot is offline   Reply With Quote
Old 11-04-2012, 03:10 AM   #2
Lc8grrr
Vtwin madness
Lc8grrr's Avatar
Oddometer: 442
Without rimlocks you really don't need to balance them particularly over 20psi.
Lc8grrr is offline   Reply With Quote
Old 11-04-2012, 07:32 AM   #3
groovyspuds
groovyspuds's Avatar
Oddometer: 54
I've never balanced mine and have no issues.
groovyspuds is offline   Reply With Quote
Old 11-04-2012, 08:11 AM   #4
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,974
I don't run rim locks on my 950s, Never balanced the tires. Many miles with out any issues.
Just swap them on and ride. You'll have them burned off soon enough.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 11-04-2012, 08:37 AM   #5
folknride
Old Adventurer
folknride's Avatar
Oddometer: 688
RideOn
I recently put RideOn in all my tires, both 50/50 and dirt - works great. Really smoothed out the road vibe on my 690, the 990 is smooth as silk, and I get some puncture/blowout protection to boot.
(But if you never ride at speed on slab, why bother)
folknride is offline   Reply With Quote
Old 11-04-2012, 09:00 AM   #6
max2
max2's Avatar
Oddometer: 219
I balance all of my wheels, nothing is perfect out of the factory. Harbor Freight sells an inexpensive wheel balancer. An old desert racer gave me a tip for the weights. Use thick gage lead solder and wrap it around the spoke and nipple. Coil it around the nipple/spoke and cinch it down with pliers. It works great and never flys off. On our big heavy rims and tires, you might have to wrap two or three spokes. I only wrap it about 3" up the spoke. The closer you get to the center of the hub the less effective the weight.
2007 Super Enduro...Finally got another one & 2008 Kawi KLX 450 - Plated
2010 KTM 690R - Sold
2006 BMW R1200GSA - SOLD...Thank Goodness...I hated that thing.
2007 KTM Super Enduro - Sold - HUGE Mistake letting it go
2006 KTM Adventure S - Sold / 2007 KTM 950 Supermoto - Sold
max2 is offline   Reply With Quote
Old 11-04-2012, 11:08 AM   #7
bloc
Oddometer: 158
I did go to the trouble of balancing my front and rear 908RRs... and the front is still trying to murder me. (headshake on hard throttle or above ~75mph)
Maybe I should pull the weight off?
bloc is offline   Reply With Quote
Old 11-04-2012, 12:54 PM   #8
DiasDePlaya
DiasDePlaya's Avatar
Oddometer: 642
Just add 2 oz of something that works like a fluid (water, oil, small pellets, Dyna Beads, etc) and you will have your tyres dinamically balanced.
DiasDePlaya
"Ya veras como quieren en Chile al amigo cuando es forastero"
Traditional song
DiasDePlaya is offline   Reply With Quote
Old 11-04-2012, 04:11 PM   #9
pfdskipper
Westside Trash
pfdskipper's Avatar
Oddometer: 1,086
Look elsewhere....like in preload setting
pfdskipper is offline   Reply With Quote
Old 11-04-2012, 04:21 PM   #10
triplenickel
triplenickel's Avatar
Oddometer: 2,430
Especially that Mitas, it should go at least three tanks of fuel though.
07 SE
PG007
Old 11-05-2012, 03:03 AM   #11
Lc8grrr
Vtwin madness
Lc8grrr's Avatar
Oddometer: 442
Its a 908 front, thats what they do...
Old 11-06-2012, 12:58 AM   #12
640Pilot OP
640Pilot's Avatar
Oddometer: 98
Thanks Team,
Appreciate the input....I've built up an Excel narrow front rim in the A 60 Series so I might get it balanced, it's got a rim lock....the rear rim is a stocker so message understood...I'll take on board the Ride-on option and look into it as well, may help on the black top
Looking forward to my first adventure off road....figure it'll be a little more of a handful than my Berg to jump and slide, but will keep you advised
Ride Safe
950 Adventure
FE 550 Husaberg
Old 11-06-2012, 04:43 AM   #13
Hipster
Hipster's Avatar
Oddometer: 1,813
I use Marc Parne's static wheel balancer, it's quick and easy to balance your +$300 set of tires http://www.marcparnes.com/Universal_...l_Balancer.htm
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is offline   Reply With Quote
Old 11-06-2012, 09:25 AM   #14
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,751
You can also build your own balancer using 1/2" drill rod and some bearings from mcmaster. I machined a couple spacers on the lathe for all my different wheels. Cost me maybe $20 and is very accurate
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 11-06-2012, 11:28 AM   #15
crofrog
Oddometer: 1,455
Originally Posted by 640Pilot View Post
Thanks Team,
Ride Safe
consider drilling it for a second rim lock. It's really hard to stick enough weight onto the rim to balance out a rim lock
crofrog is offline   Reply With Quote
Times are GMT -7.   It's 11:16 PM.
