Old 11-03-2012, 06:17 AM   #1
DDT Rider OP
Oddometer: 473
PDM60 install and frame grounding...
2008 R1200GSA
I just began the install of this unit today, which is my first ever fuse block install of any kind...
Today, I managed to install the basic unit and replace my can-bus socket on the left side with a Powerlet 15 amp upgrade.
For now, it's sitting where the tools were...I'd love to put it under that tray, but not sure how that will work out with my poor organizational skills...
Next: TPMS receiver and heated gear outlet(s).
The install instructions advise to ground the main unit and accessories to the frame, I ended up going direct to the battery as I could not identify frame screws that looked like spots
I could be confident in a good ground.
Has anyone used frame grounding points on this bike, and if so, where...
Cheers!
DDT Rider is offline   Reply With Quote
Old 11-04-2012, 01:39 PM   #2
DDT Rider OP
Oddometer: 473
No love on this yet, huh?
Well, I installed the TPMS unit yesterday. Removing the tank would have made it easier/cleaner, but I've not done that yet on this bike and am not going to unless absolutely necessary (unlike the 1150 tank, which I had off all the time).
For the ground, I ended up using a bolt that secures one of the seat mounts. I scuffed up the bottom of the nut before reassembly and that circuit is hot now.
The TPMS is up and running...my first time to have such a unit...nice to have that bit of info. This feature is not available OEM here as there is some issue with the frequency the units transmit on...or something like that.
The unit comes on immediately on ignition, I thought a 7-second delay was standard for the PDM60...maybe that was changed when I asked for circuit customization.
All of my circuits also stay on for a few minutes after key off...I can already see this is not the best behavior for the TPMS unit, as it's an attention grabbing light that will stay on when I walk away from the bike. Not desirable in all locations.
Will be great when future versions of this the PDM60 have a mini-USB port for the end user to reprogram the character of each circuit while still in the bike...
Old 11-04-2012, 02:59 PM   #3
John Smallberries
John Smallberries's Avatar
Oddometer: 1,273
my '05 job
I installed a PDM60 on my '05 GS a few years back (documented here). I never used frame grounding. I ran all of my accessories to ground back to a dedicated ground bus bar tied to the PDM ground. The bike is small enough to run these easily. I do recommend pulling the tank to make the wiring cleaner. I don't expect your '08 is any harder than my '05 - which is very easy to do.
Good luck....Post pics!!!
'05 BMW 1200GS
'09 Honda CRF230
'10 Yamaha TW200
'07 KTM 400 XCW/EXC
John Smallberries is offline   Reply With Quote
Old 11-04-2012, 03:38 PM   #4
DDT Rider OP
Oddometer: 473
Thanks, JS...I did read your thread...surprisingly, not too many out there yet about this unit.
I did buy a wiring unit with the PDM60 that included a dedicated ground, but I'm still thinking where to locate it. In my novice mind, two dedicated grounds would be ideal; one in the rear, and one up near the nose.
I only have one, so at the moment, I'm vacillating over which location.
I did manage to thread my TPMS wire under the tank, though much less efficiently than with tank removal.
Old 11-17-2012, 02:12 PM   #5
DDT Rider OP
Oddometer: 473
Well, this unit is installed...so far, TPMS and left side can us socked replaced. Next will be line for heated gear.
I was surprised that the circuit lights on the box stay lit when the bike is off. At first, I thought I had it hooked up wrong...
Old 11-17-2012, 03:08 PM   #6
John Smallberries
Oddometer: 1,273
TIme Delay
Watch it for a few minutes to check the time delays. Mine has a 2-step time delay before it shuts off fully (almost). My ignition signal comes from my bike (1200GS), which stays live for 90 seconds after key off. After that, the PDM60 has a 180 second delay before it shuts off. I have to watch my bike for nearly 5 minutes before the PDM60 shuts down.
BUT - after that, I still have one circuit (#3 - 5 amp) with the LED staying green. I'll have to check my wiring diagram to figure this one out.....
My battery will drain after a week or so if I don't connect to the tender. I expect these issues are tied together somehow.
'05 BMW 1200GS
'09 Honda CRF230
'10 Yamaha TW200
'07 KTM 400 XCW/EXC
Old 11-17-2012, 04:46 PM   #7
DDT Rider OP
Oddometer: 473
True, those circuits all power down and change color as they should (except the ones in designated as always on) however, they still stay lit in their respective colors.
I was wondering about the power draw of these little LEDs...I had hoped the draw was negligible...
Old 11-17-2012, 05:29 PM   #8
def
Ginger th wonder dog
def's Avatar
Oddometer: 9,755
Typically, LEDs draw only a few milliamps of current and will not discharge a healthy battery for months.
But, motorcycle batteries usually get a charge say, during the monthly ride or when you connect the battery maintainer, more than offsetting any LED drain.
def is offline   Reply With Quote
Old 11-18-2012, 03:10 AM   #9
DDT Rider OP
Oddometer: 473
Just the news I was hoping for ;>
Old 12-29-2012, 11:54 AM   #10
BitesTheDust
BitesTheDust's Avatar
Oddometer: 176
@DDT and @Smallberries
Can you post some photos? Also - did you tap into the diagnostic plug at the rear of the 1200GS for the ignition signal or elsewhere?
Much appreciated.
BitesTheDust is online now   Reply With Quote
Old 12-29-2012, 01:51 PM   #11
John Smallberries
Oddometer: 1,273
Here ya go
Much appreciated.
I started a thread 2 years ago on my install (hint for ADVRider, use Google to search> site:www.advrider.com PDM60)
http://www.advrider.com/forums/showt...=638076&page=5
It has lots of photos from my install. Originally, I used the ignition-switched power from the BMW auxiliary power feed up at the handlebars. They stash this in the wiring bundle of the GS to enable you to power up their crazy-expensive navigation systems. I switched away from this to the diagnostic plug blue/green wire. The Aux ignition power lead worked, but had a 90-second off-time delay. This then added to the 90-second PDM60 delay and kept my system alive for 3 minutes after shutdown. I used a Posi-tap to grab the ignition 12-volts from the diagnostic plug.
Good luck!
'05 BMW 1200GS
'09 Honda CRF230
'10 Yamaha TW200
'07 KTM 400 XCW/EXC
Old 12-29-2012, 02:06 PM   #12
BitesTheDust
Oddometer: 176
Good luck!
- just the info I was looking for. Thanks!
Times are GMT -7.   It's 10:48 PM.
