Old 02-16-2010, 02:58 PM   #31
Dustodust
Dustodust's Avatar
Oddometer: 1,075
Originally Posted by ADVJake
I'd be nervous running a 1.60 on a big adventure... maybe its just psychological. Do you still run a 90 width tyre?
I had a sudden flat (blowout) at over 100mph with a D-606 on the stock 2.15.
the effect is a sudden pull to one side that you have to ride out until you can slow it down to 50mph , when I attempted to to correct it straight it felt like an emminent crash for sure, so I got back over it and control returned at the lower speed and I rode it another 30 miles at 50 moph before changing the tube
I would doubt that the narrower rim would be a disadvantage in this scenario. In fact it should be a benefit in that 1. the bead would hold better before allowing the tire to flop to one side causing the bike to pull to one side and 2. less friction contact of the tire with the road to build heat and blow out the tube
from a cloud of dust we race, then into the dust we return, across the finish line
04 KTM 950 S
04 KTM 525 EXC street plated
Old 02-16-2010, 07:38 PM   #32
4play
Next?
4play's Avatar
Oddometer: 2,620
I'm running a 1.6 A60 on my 990. It corners fine, no problems at hwy speeds with 606/608RR combo.
You don't understand, those boys killed my dog.
4play is offline   Reply With Quote
Old 02-16-2010, 09:35 PM   #33
crashmaster
ow, my balls!
crashmaster's Avatar
Oddometer: 5,301
Yo tambien.
Riding the Americas: No Fumar Español
_____________________________________________
crashmaster is offline   Reply With Quote
Old 02-17-2010, 06:11 AM   #34
woody's wheel works
Built to Last
woody's wheel works's Avatar
Oddometer: 3,466
Yes,,a 1.85'' is better than a 2.15'' and a 1.6'' is mo betta than both...
this question pops up perennially....
and the above is my final answer with a few caveats,,like those rims sizes work better but,,,,no buts!!!!,,,and,,,,
..and one must also take the brand,,,the model,, the terrain,,,the tire pressure,,,the velocity,,,the weight of bike ,, the riders skills and aesthetic requirements into consideration.
FYI,,,once upon a time we used many Sun rims successfully until better alloys came along...they were heavier like the Dirt Stars...but a softer alloy.
In recent years Buchananns who build these rims in their California facility decided to improve the quality..like aligning the two ends [that are butt welded together] for a change and making them rounder and lighter BWOE...they accomplished this by over-sizing the circumference and then machining the excess off in a lathe,,,voila a lighter,straighter rim BUT not as strong....a little extra beef does matter...thus i have not used or recommended a Sun rim in years for the dual sport scene.
FYI,,,,weight matters,,,not just the benefits of unsprung weight,,easier handling..thus i'd rather have a heavy n tuff rim over a lighter, soft alloyed one,,,and a light and tuff one over a heavy n tuff one
FYI,,,the off-road improvement in handling of the narrower rims is far greater than any diminishment of on road handling characteristics,,,,theoretically the wider rims would be better with lower profile/aspect ratio tires which need them to keep the sidewalls supported..
FYI,,,the Excel A-60 is clearly my favorite choice for strength/$$$ value.
unfortunately it is cursed with an obnoxious silver pinstripe etched full circle,,,there are folks that have returned the wheels and switched to other rims because it doesn't meet their aesthetic requirements...hey i'm with you..it takes an additional circa $100 to strip the color/ sand the stripe off /rebuff to a shine and re-anodize black
....and to add insult to injury,,,there are no matching rears available for 90% of the rims we need for your dual sport bikes....they only come in the standard du jour 1.85 &2.15x19 rears. excels link=
http://rkexcelamerica.com/mx_excel_rims.html
FYI,,truth be told not everyone rides like Pyndon and Neduro so have more options to choose from....which brings me to the point that there are some riders with the trickest suspensions and state of the art wheels/rims etc who simply plow through everything ,,,are cluelless to the art of modulating throttle control,,pulling on the handlebars and lofting the front end over that log or rock.....
FYI,,,some rims are better in muddy conditions....several years ago DID had rim with arounded profile that shed mud incredibly well,,,unfortunately it had a 6000 series alloy that was too soft for the serious off-roader...the dimpleless Sun and Excel rims collect les dirt and the A-60 has the next best mud slinging profile....mud buildup can seriously affect your handling
FYI,,,tire pressures......to avoid pinch flats the heavier the bike the more pressure is better circa 38psi+ for the big iron on road and 30psi off road,,,
i hear reports all the time that 20-26 psi is being used by some very respected sources...perhaps they can chime in what they use on what and where....
'nuff for now gotta head to work
woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 02-17-2010 at 06:17 AM
Old 02-17-2010, 07:39 AM   #35
kennyd
kennyd
Oddometer: 231
dirt star comparison vs excel a 60
thanks for your insight woody! dirt star now offers LT-X lighter but tuff and ST-X 15% tuffer but a bit heavier. how do these compare with excel A-60? for strenght and weight? they both claim 7000 series aluminum. and which model is the 950 SE KTM dirt star OEM rim? LT-X or ST-X ?
kennyd is online now   Reply With Quote
Old 02-17-2010, 11:35 AM   #36
woody's wheel works
Built to Last
Oddometer: 3,466
what's the haps with DID Dirt -Star rims????
so i got all the gears at Daido moving to find out some concrete answers...regarding availability..rim weight/sizes/ models
FYI,,,the 1.85 x21 and 2.5 x18 used on the KTM 950SE are specialty items made for the manufacturer
FYI,,,the sizes for the dirt models are as follows:
1.6x21 LT-X in silver or black...
1.6x21 ST-X only in black
1.85x19 Lt-X in silver or black
1.85x19 ST-X only in black for 125cc mx/sx/
2.15x19 LT-X in silver or black for bigger ie over 200cc mx/sx
2.15x19 ST-X only in black
no 18'' available....
they are trying to find a chart that has a reference list for identifying what rim went to what model bike...i can just look at a rim and tell you pretty much what style hub /what indexing etc...that aparticular rim can be used on ..you guys
hence the need for the reference chart
will keep ya posted
woody
Old 10-26-2012, 02:08 PM   #37
Thor_with_the_KTM
Oddometer: 12
where in Europe ?
is there someone who can point me to a place in EUROPE where I can buy Excel Takasago A-60 1,6'x21 front rim for my ktm 990 adventure ?
Thor_with_the_KTM is offline   Reply With Quote
Old 10-26-2012, 02:20 PM   #38
LukasM
Oddometer: 5,427
Do you want a whole wheel or just the rim?
Old 10-26-2012, 02:25 PM   #39
Thor_with_the_KTM
Oddometer: 12
I'm interested rim only
Old 11-04-2012, 05:41 PM   #40
5 speed
Oddometer: 950
I bought an Excel 2.15x21 to replace the stocker. Rad wheel built it. They had to order the rim and then black anodize it themselves. I had a billet hub installed because I wanted to keep my other wheel for a knobby. For the road and all the weight I really like the 2.15 and the stock scorps seem to corner good; nice turn in.
5 speed is offline   Reply With Quote
Old 06-21-2015, 01:36 PM   #41
madafakinges
RALLY QUEEN
madafakinges's Avatar
Oddometer: 35
Have anyone used SE front 1,85 DID rim in ADV? Is it fit?
My BHER 2,15 ale ruined
KTM 950 BLACK
madafakinges is offline   Reply With Quote
Old 06-21-2015, 01:47 PM   #42
4play
Next?
4play's Avatar
Oddometer: 2,620
I put a 1.60 A60 Excell on mine & never had another issue
Old 06-21-2015, 01:50 PM   #43
madafakinges
RALLY QUEEN
Oddometer: 35
I want 1,85.
I can buy ecxel from haanwheels or SE did form ktm.
Which choose?
KTM 950 BLACK
madafakinges screwed with this post 06-22-2015 at 12:34 AM
Old 06-22-2015, 12:46 PM   #44
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,539
DID DirtStar KTM SE 1.85 on Adv
I've been running the KTM DID DirtStar SE 1.85 wheel on my Adv for 4 years... And it works with the SS stock spokes to the stock hub ( make sure it's the KTM Euro drilled, not the Japanese drilled pattern). I noticed a difference on the highway where the narrower rim tends to grab at any vertical asphalt seams which adds extra feedback. But the advantage in the dirt was worth it with sharper, more concise turns in loose ground surface and better impact reflection.
Good suspension valving, crisp line choices and reactive throttle response have helped maintain my DID rim but eventually a Woody's A60 will be my next wheel.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is offline   Reply With Quote
Old 06-22-2015, 12:51 PM   #45
wsmc99
wsmc99's Avatar
Oddometer: 504
Have a 1.85" on my 950, from a street perspective it makes a 90/90 a better profile over the 2.15" and is stronger for dirt as well.
It appears if you want to do really rough stuff without paying attention to lines or control then the A60 seems the way to go.
wsmc99 is offline   Reply With Quote
Times are GMT -7.   It's 10:28 AM.
