Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 04-18-2010, 04:25 AM   #31
simple dr
simple dr's Avatar
Oddometer: 52
dr rattle
dr rattle
i have one of these to , ive had tank off etc, no ......cant find anything loose .
mine occurs at about the point of throttle where load starts to come on to the motor and then at the point of near coasting , or just as you roll throttle off a little but not compleatly off.
have tightened the chain tonight
I thought maybe its a to loose chain hitting the chain roller.
the sound is like from the top of motor?
any help to any one or any thoughts anyone
[IMG]images/statusiconCrash/user_online.gif[/IMG]
simple dr is offline   Reply With Quote
Old 04-19-2010, 10:52 PM   #32
dirtbikeslob
Oddometer: 301
Originally Posted by Kennif
I see that the IMS tank for the DR650 has a capacity of 4.9 US gallons. That is only about 18.5 litres. The stock tank has 13 litres. Do you reckon it is worth the expense? It looks as if it will cost around $NZ400 for the IMS tank (cost + shipping)
Any comments appreciated.
i can get 20l into my ims although its supposed to hold 18l ish ,managed to get 410km out of it on the way to cape york before it ran out of gas 10km
from coen
dirtbikeslob is offline   Reply With Quote
Old 04-19-2010, 10:55 PM   #33
dirtbikeslob
Oddometer: 301
also rode mates dr with a safari tank ,and it was a bit of a handful off road
with a full tank,having said that ,i wouldnt mind one as long as it wasn't blue
Old 04-20-2010, 01:20 AM   #34
TransalperNZ
TransalperNZ's Avatar
Oddometer: 105
Originally Posted by simple dr
dr rattle
Don't over tighten that chain.
I took my chain roller off, you could try that, if that quietens it problem solved.
If it doesn't solve it then I have no idea.
www.youtube.com/profile?user=transalpernz
It's adventure videos by me in New Zealand.
For Adventure Routes and fishing info in NZ check out www.adventureguide.co.nz.
TransalperNZ is offline   Reply With Quote
Old 04-20-2010, 03:45 AM   #35
ztaj
jatz
ztaj's Avatar
Oddometer: 934
dr rattle
Whats your valve clearances like ? and cam chain ?
ztaj is offline   Reply With Quote
Old 04-22-2010, 12:31 AM   #36
simple dr
simple dr's Avatar
Oddometer: 52
dr rattle
hi there
i have tightened the chain , not to tight but must have been a little loose .
so i guess the problem was the chain roller .
thanks all
Old 11-03-2012, 06:05 AM   #37
driftinglobo
Oddometer: 27
Hi Guys, I have been lurking for a while now. But it is time to intro my self. I m a proud owner of "Big Bird". (a yellow DR650). it is total orig at the moment while I figure out how to set it up to best suit my needs. I m also new to forum ing so if i make a mistake just educate me.
Cheers,
driftinglobo is offline   Reply With Quote
Old 11-03-2012, 08:11 AM   #38
Pete-NZ
Pete-NZ's Avatar
Oddometer: 732
wow.. where did yer fined this thread.... last post was 2 1/2 years ago..
Here.... my XR250 leaner side car build
http://www.advrider.com/forums/showthread.php?t=716993
Pete-NZ is offline   Reply With Quote
Old 11-04-2012, 02:08 AM   #39
bart-nz
bart-nz's Avatar
Oddometer: 688
Cheers,
Nordieboy is the DR guru. He'll probably be along shortly.
Standard mods are tank, exhaust, open airbox, bashplate, handguards. From there, the list is huge. Most people change the bars (bar risers), seat, tweak the suspension, heated grips. From there it's a new carb, big bore etc.
In my opinion, if you have to go that far, you should've bought a KTM 690 or similar.
Break out the plastic and take a look over here......
http://www.procycle.us/bikepages/dr650.html
Bart's adventure: http://www.advrider.com/forums/showthread.php?t=541628
bart-nz is offline   Reply With Quote
Old 11-05-2012, 03:13 AM   #40
driftinglobo
Oddometer: 27
Hi
As i mentioned I been lurking for a while. Especially since I decided to seek out SI's more remote places,that not really accessible with a road bike.
So about a year ago Big Bird "followed " me home.
Now it is time to set her up for dirt.
The mods will get done as budget allows.
First a decent bash plate. I m still debating between an MSR or a B&B or a home made one.
Then a holder for a 5 tl fuel can to increase my range to 250 km + reserve. the El Cheapo way.
Then reinstate my night vision. as my headlight is cracked and the original in the shop is a bit much.
and some protection for it .
Then some luggage set up. Got a venture pack rack but i feel I need something more solid.
Up size the orig tool holder or fit an other one to house a spare tube and other bits.
And later some different pipe?
Not really thinking re jetting or big bore kits as I think if I want more power I get something else with more power.
I wonder why is this thread died? Is there no need for it?
Thanks.
Old 11-05-2012, 03:23 AM   #41
driftinglobo
Oddometer: 27
Hi
I forgot to ask for future reference is anybody wrecking DRs in NZ?
Old 11-05-2012, 10:57 AM   #42
innathyzit
AKA Woodman
innathyzit's Avatar
Oddometer: 987
Hi
I just wreck KLRs, but lend me your DR and I can give it a go.
innathyzit is online now   Reply With Quote
Old 11-05-2012, 09:47 PM   #43
bart-nz
bart-nz's Avatar
Oddometer: 688
Think soft luggage if riding difficult terrain. Keep it low and forward. Even a small amount of weight high and way back on the bike can upset the handling. Hard luggage is just another thing to break your bones when the bike lands on you.
Old 11-06-2012, 12:40 AM   #44
dirtbikeslob
Oddometer: 301
hey Drift,have you looked at the 8lt fuel bladder,strap it anywhere on your bike and when empty,just roll it up and stash it.
made out of some tuff curtain sider type material,has eyelets at each corner for easy mounting.
used one on the cape york couple of years ago.
i think liquid containment in AU makes them @about $160
Old 11-08-2012, 04:04 AM   #45
driftinglobo
Oddometer: 27
Hi there,
Thank you for the suggestion!
Are you using these?or just for one trip? How do you find it?
I have looked them up on the net. They look ok ,but can call me old fashioned but I still not trust these bladder types.They should be ok for road use but probably need a decent support for dirt. therefore defeating the purpose of being store able. hence a 5lt plactic petrol can will do the same job for the cost of $5. ( El Cheapo!!!) Well I m thinking having a petrol can as a semi permanent fixtures to my bike to extend the range until i have $$$$$$$ to fit a larger tank.Most likely it is tiresome mucking about with petrol cans but I just want to get out and ride not to wait until the bike is all set up. so the cost of these would cover about a 1/3 of a 18.5 or 20lt tank.Which I think should be the the long term goal.
Thanks.
Times are GMT -7.   It's 04:35 PM.
