11-05-2012, 08:01 AM
#46 |
Andrew to most
Oddometer: 1,112
Something I wanted to ask those of you who have these carbs.
I can't get past 200kph. I hardly ever go there, especially as I have Michelin deserts on, but recently I found something that was of interest in this conundrum. I currently run a 17/42 only because that's what I needed when I had the SD gearing in. Now I have the standard Adv gearing, it's much better but just waiting for a spot of garage time to go down in sprockets. But, the current gearing with my 100 plus Hp should be a breeze, literally. But it's not. Initially, I put it down to the 39mm's just not being up to the task when in higher revs, but now that I have dropped the gearing I still end up with the same terminal velocity even though the engine is now sitting in the meat of it's torque? Last week I was going up a pass that is renown for it's wind. It is a freeway type thing with long wide corners that can be taken at speed. This day was especially windy. I noticed on one long sweeping corner, that as the wind angle changed more from side on, to the front, the bike lost a noticeable amount of power. Not suddenly, just in relation to the angle of the wind. I turned around and rode up there twice just to check I was not imagining it. I think that up to 170kph'ish, the carbs do not get so affected by wind blast, once past that there must be something going on that affects the flow. I have safari tanks on, maybe they funnel more air in that disturbs the flow. I am keen to know if any of you can easily get past 200 with your FCR's on an Adventure format bike? I am looking forward to my set of billet velocity stacks to see if it makes a difference. I also suppose that the airbox on the OEM carbs may have a role to play in shielding the carbs from the adverse effects of the wind blast.
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost |
11-05-2012, 10:40 AM
#47 | |
Oddometer: 1,376
How do you have your carbs vented? |
11-05-2012, 11:12 AM
#48 |
Andrew to most
Oddometer: 1,112
Hmmm, I hadn't thought of that.
All 4 are routed to the left and are bunched and zip tied to the frame ending near my left calf.
11-05-2012, 12:24 PM
#49 | |
Oddometer: 1,376
I think the SE had some additional plumbing to let the carbs vent during deep water crossings too. http://www.ktm950.info/how/Orange%20...carb_vents.jpg "the Super Enduro (see photo by firebolter) has an extra set of carb vent hoses that run from a brass "L" on the opposite side of each carb to a "Y" and a single line out the snorkel and into the A/C cover. This is to provide proper function of the carb vent system in deep water crossings." and the desert bikes had http://www.ktm950.info/how/Orange%20...utch_mods.html "Drill a 2mm hole into the top of the black 90 degree elbows where the fuel vent lines are connected. This helps avoid flooding the bike in case of a crash. For desert racing, its better to run the vent lines up under the steering stem and fitted with a small filter." Obviously the plumbing on the FCR is going to be different, but I think specially with the cross wind you where talking about that it's likely going to be a carb venting issue causing the bike to run either rich or lean. |
11-05-2012, 12:41 PM
#50 |
Slack Jaw Gaper
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 744
I, too, have hit the "wall" with my FCR's and kit pods. There is a point where I cannot make more RPMs, at high travel speed, and I know the RPMs are available in lower gears, from the rev limiter engagement. Could it be that we are so aerodynamically "effecient" that there is no way to press that envelope further, without some valances or displacement? The intake restriction of the standard airfilters may be showing itsself, at that point.
I have direct frontal air into the pods and don't have any lateral wind pressure changes noticibly affecting engine output. I get steady throttle RPM hunting with wind changes, but I attribute it to the venting. edit to add: jetting is a bit fat as well, in my case, could be the last few hundred heavy loaded RPM that needs a leaner main.
KTM 950 SliderMoto with 19/17 spokes, FCR41's, 2-into-1 high pipe, single side front brake and handcut flattrack style tires. Gettin Slideways is good! justin@giantloopmoto.com www.giantloopmoto.com |
11-05-2012, 08:21 PM
#51 | |
Flanny-it-up!
I don't really ever ride at 200kph, so I have no idea if this would make a difference in that regard, but it's worth investigating.
Flanny Flanny-it-up!...Check out the FlannyMedia Web Site and Blog at www.FlannyMedia.Com
11-05-2012, 08:37 PM
#52 | |
Slack Jaw Gaper
Oddometer: 744
. I felt fortunate to not get much bogging in the whoops and now will be testing the balance of that, with the mysterious drying bowl question . Thanks for the spec to work from!
11-05-2012, 11:57 PM
#53 |
Andrew to most
Oddometer: 1,112
I'll wait for the velocity stacks to arrive and put the recommended jetting in for them before I start fiddling with the carbs again.
Snowhawk, do you have a filter in the fuel line anywhere? I have one before the facet pump. I might just change that to eliminate that variable too.
11-06-2012, 06:07 AM
#54 |
Oddometer: 1,376
With a wide band you should be able to tell if the fueling ends up being off at high RPM. Might be worthwhile to install one and make your tuning allot easier an EGT could be useful too.
Target between 12.8 to 13.0 on the AFR for peak power. |
11-06-2012, 09:51 AM
#55 | ||
Slack Jaw Gaper
Oddometer: 744
My interim fiddling will be with the TPS, so I can get the right advance for start up. Saving the float adjustments for after the trumpets arrive. Heck riding season is winding into the cold, so I'm in no rush...
11-06-2012, 10:09 AM
#56 | |
Oddometer: 1,320
I think the Carb Venting at high speed is where it is happening. AdvGa screwed with this post 11-06-2012 at 02:02 PM |
11-06-2012, 11:29 AM
#57 |
Slack Jaw Gaper
Oddometer: 744
I am tempted to go with a catch can to stabilize the airpressure on the vent sys. I had a similar effect on the EXC when I put the catch can, more consistant venting(until the catch can got a load of gas in it...)
11-06-2012, 12:49 PM
#58 |
Mookish Mook
Oddometer: 4,287
Is it possible it's just a matter of wind resistance? The 950A is a bit of a barn aerodynamically.
IIRC the highest speed I've heard of for the Adv was 130mph-ish - which is only a touch above 200kmh. (and that was no wind, on a salt flat, no screen and no seat so the rider could get lower...) Wind resistance is a function of the square of velocity (if my memory of physics serves me...) |
11-07-2012, 12:24 AM
#59 | |
Andrew to most
Oddometer: 1,112
On a deserted Karoo desert road I had "slowed a bit" to take this in 2007 on;
11-07-2012, 11:50 AM
#60 | |
Slack Jaw Gaper
Oddometer: 744
edit to add: I have seen +/-113mph on the GPS with 16/45 gears, on a 17" rear. Keep in mind that was paved and I have never been able to get above +/-105mph on the dirt, same setup. My GPS crapped out and I haven't been able to GPS 17/45 or 16/42, just speedo'd and that # is questionable...
KTM 950 SliderMoto with 19/17 spokes, FCR41's, 2-into-1 high pipe, single side front brake and handcut flattrack style tires. Gettin Slideways is good! justin@giantloopmoto.com www.giantloopmoto.com snowhawk jockey screwed with this post 11-07-2012 at 11:57 AM |
